Question about HP ProBook 6570b laptop
Touch pad drivers - HP ProBook 6570b laptop
Disable touchpad - usb mouse is installed and working
Either your driver for touch pad is missing or flex cable of your touch pad is disconnected. Check in Device Manager if your driver for touch pad is there, if that part is fine then you have to open your touch pad and reconnect the flex cable.
Mar 01, 2015 | Computers & Internet
Touch pad not working light bar not on above the touch pad
Hi Cheryll,
Make sure there are no problems with the driver installed on your machine by going to Control Panel->Device Manager and see if there are any question\exclamation marks on one of the drivers. While you are at the device manager you can check the touch pad driver version and update it to the latest from the manufacturer website if needed. To check the driver version double click the touch pad and go to the Driver tab. You will see it under driver version.
Also some netbooks got an hardware button to shutdown the Touch Pad.
Regards,
TheSmacker.
Jan 21, 2014 | Toshiba Satellite A205-S4617 Notebook
My touch pad not working probably .
Adel Heider,
You may want to first download the driver and install it into the system from the link below.
Inspiron 1545 Drivers Download Page
http://dell.to/14IpAJU
Erratic Pointer Movement
Here are some easy steps to take to determine the problem with a touch pad demonstrating erratic pointer movement:
  1. Get the latest driver from support.dell.com - Most problems can be corrected with a simple driver download. This should always be one of the first steps when diagnosing any touch pad problem.
  2. Check for hand and finger placement - The most common cause of random pointer movement is that the touch pad senses a finger or part of the hand near the surface of the device.
    • Have the customer attempt to use the touch pad normally but to pay attention to the location of his or her hands and fingers. Are any straying too close to the touch pad?
    • Adjust the Touch Sensitivity and TouchCheck settings in the Touch Pad Settings section of the Dell Touchpad Properties.
  3. Try an external mouse - Does this problem happen with an external mouse attached?
    • The Device Select section of the Dell Touchpad Properties has options to enable or disable the touch pad or external mouse. Try several combinations of these settings.
    • If the problems only occur when the touch pad is enabled and do not occur any time a mouse or other external device is used, then the issue is related to the touch pad.
  4. Check for mechanical problems - If the problem cannot be corrected by adjusting the settings mentioned above and only occurs with the touch pad enabled, then this could indicate a mechanical problem.
    • Press down on the palm rest on first the left side of the touch pad and then the right. See if the cursor starts moving on its own.
    • Run Dell 32-bit Diagnostics and try to recreate the problems there. If either of these situations occur, then replace the palm rest.
No Pointer Movement
No pointer movement from the touch pad (or track stick, if available) usually is the result of one of two things: The touch pad has been disabled in the driver interface, or the touch pad cable is damaged or disconnected. Follow the steps below to determine the problem.
  1. Connect an external mouse - In either situation, an external mouse should still function. If it does not, try booting into Safe Mode and testing both devices again.
  2. Enable the touch pad in the driver settings - Using the external mouse (or key strokes if no mouse is available), go into the Dell Touchpad Properties. Go to the Device Select section and enable the touch pad. If already enabled, get the latest driver from support.dell.com.
  3. Test the device in Dell 32-bit Diagnostics - To eliminate a potential software problem, run the Dell 32-bit Diagnostics and test the device here.
  4. Check for mechanical problems - As a last resort, press down on the palm rest where the touch pad connector is located on the system board. If the pointer reacts in some way, then the cable may just need to be reseated. Otherwise, replace the palm rest.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Sep 07, 2013 | Dell Inspiron 1545 Notebook
Cannot scroll on my touch pad
This usually means you need a driver for the touch pad. Though, not all touch pads are designed to scroll. Go your your PC manufacture and look up your model for support. You should see a driver for the touch pad.
Nov 19, 2010 | Microsoft Windows XP Professional
The arrow on the mouse kepts junping around ?
You are probably using a laptop with a touchpad. What is happening is that your thumbs are touching the touch-pad as you type and the cursor is jumping around. Solution: disable your touch pad. You can go to Start > Control Panel > Mouse > Touch Pad > Disable
Another solution is to go to the Dell website > Support and Drivers > download and install the Synaptics Pointing Device driver and disable your touch pad using the options in this new driver.
Oct 15, 2010 | Dell U0636 Mouse
Dell touchpad tab gone from mouse settings. tried installing driver with no luck. Also tried uninstalling and reinstalling driver.
Customizing the Touch Pad
You can use the Mouse Properties window to disable the touch pad or adjust
the touch pad settings.
1 Click Start , and then click Control Panel.
2 Click Hardware and Sound.
3 Click Keyboard.
4 In the Mouse Properties window:
• Click the Device Select tab to disable the touch pad.
• Click the Touch Pad tab to adjust touch pad settings.
5 Click OK to save the settings and close the window.
Apr 06, 2010 | Dell Studio 17 Laptop
Touch pad not working nor mouse buttons
touch pad driver is download is your laptop.
see site and download your laptop touchpad driver
http://driversdownloadsfree.com/get.php
download mirror ok
Feb 25, 2010 | HP Compaq nx5000 Notebook
Touchpad
When the touch pad stops working it's one of three things. 1- A driver glitch, unistall the touch pad drivers from the device manager, then reboot. The machine will find the touch pad and reinstall the drivers automatically. 2- The touch pad connector has worked loose. Take the palm rest with the touch pad off, disconnect the cable, clean the connectors, and reseat the cable firmly. 3- the touch pad has failed and will need to be replaced. The driver glitch is the most common, I believe that it should take care of the problem. Let me know.
Aug 06, 2008 | Dell Inspiron E1705 Notebook
Touch pad driver.
Uninstall the driver from the device manager, then reboot. The machine will find the touch pad and reinstall the drive automatically. If this doesn't work, check the touch pad connection, they will sometimes work loose ar get a little dirt/corrosion build up. The connection is under the keyboard. At this point, if it's still not working, then it has failed and will need replaced.
Jul 20, 2008 | HP Compaq nc6220 Notebook
Touchpad
This may be a simple driver glitch. Try uninstalling the touch pad drivers from the device manager, then reboot. The machine will find the touch pad and reinstall the drivers. The touch pad either works or it doesn't, there's no in between, so if this doesn't work, then I'm afraid you'll have to replace the touch pad.
Jul 17, 2008 | Toshiba Satellite A205-S4617 Notebook
HP ProBook 6570b laptop Logo
12 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
