Question about Zenith B27A11Z 27" TV
Cant use any remote
The tv cant be controlled by any remotes. the remotes work, the tv not responding to them.
    Sergeant:
  • 280 Answers
On the front of the chassis is a IR detector it is probably bad. sometimes if you have and old set and the IR looks the same you can use it as a replacement.
Most of the ones I have run into have had windex drip past the edge of the picture tube. the IRD is under the tube so it gets on the IRD. sometimes you get lucky and can clean it off real good and it will work again.
Posted on May 30, 2008
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
LT-24DG42J
013/ 054/ 055/ 060/ 065/ 067/ 089 These are the three digit codes to Jvc brand TVs. As there is no remote control with you, the first thing to know is, to which code do your TV respond. Some TVs will respond to three digit codes, some others will only respond to four or five digit codes. If your TV do respond to three digit codes, a universal remote control, which have the above said codes in its code list will work. If you wish to get three, four & five digit code list to some popular remote controls, check the links given above. You can choose the proper remote control to your TV. But before buying a new remote control, make sure about the number of digits of codes that TV must have.
Feb 23, 2013 | JVC Televison & Video
I have a Sylvania 6424FF tv and i cant get it programmed to a univeral RCA remote the codes listed are NOT working
Hello
RCA- RCU 500 model universal remote has Sylvania TV coded with. The codes are:
006,007,010,011,013,016,027,
033,035,043,049,066,087,089
Programming method
[1] Press the button of the device you want to
control (for example TV).
[2] If the device turns on, press another button,
to confirm (for example CHANNEL UP)
[3] If the device you selected (TV) responds,
you will not need to program the remote.
If the device you selected (TV) does
not respond, you will need to program
the remote
There are very rare RCA remotes, with Sylvania TV can be programmed. Just try the above codes with your present RCA remote control. If it does not help, buy the above model RCA universal remote. You will get code list and all other related documents, how to programme it or so, with the device you do purchase. OK.
Jun 14, 2011 | Sylvania 6424FF TV
Cant program my rca remote for my LG tv don't have code
Hi! You try using these steps for you to program your remote control to your TV.
1. Manually turn ON your TV.
2. Press and "HOLD" CODE SEARCH
3. Press and release the TV button
4. Release CODE SEARCH.
5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second).
6. Once the TV turns off, press and release ENTER.
7. With the TV on, press any other button. If the TV responds, no further programming is required. If the device does not respond, repeat steps 1-6.
I hope this helps.
Jul 13, 2010 | RCA Universal Remote Control
Tv doesnt respond to buttons or remote
this is looking like a common LG problem our tv started doing this tonight
May 15, 2010 | LG 42LC2D 42 in. LCD HDTV
Tv not responding to new remote control
Was the replacement remote identical to the original one; or, does it need to be programmed. Also, if your replaced your old remote because it was not working, it might be that the IR sensor on your TV is bad.
Nov 04, 2008 | Aiwa VX-S205 Combo
My Sharp Aquos TV has stopped responding to remote control(s)
Unplugging my TV for 15 seconds (longer actually - at least a minute) made the remote and the satellite TV remote both work again with the TV.  Thanks for the tip!
May 14, 2008 | Televison & Video
Rcr311w remote
1) Turn on TV;
2) Press TV on the remote control;
3) Press and hold SETUP, until the red LED indicator blinks twice;
4) Enter 9-9-1-1 on the numeric keypad;
5) Press POWER on the remote;
6) If the TV doesn't respond, repeat #3, #4, #5.
Feb 13, 2008 | Universal Remote Control DIRECTV Universal...
Remote control not responding
Perhaps you can try what I do when my KV24FV300 runs through channels and will not stop.  Hard to watch and remote will not work.  Nothing works but on and off from set.
Sony Says:  Take all batteries out of ALL remotes that you use in any way for that set, VCR, etc.  ALL batteries out.  Turn TV off at set.  Unplug TV.  Wait at least 15 minutes then replace all batteries in ALL remotes.  Plug TV back in and turn TV on from set.
Maybe, just maybe it will work.  If it does not work why not call Sony, they always say that cannot happen but they have a solution for it.
niteowl@dejazzd.com
Sep 30, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Zenith B27A11Z 27" TV Logo
103 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
