Stopped reading Discs
SOURCE: Unable to program Universal Remote. provided codes do not work.
Problem solved. I decided to use the learning function of my remote to learn the wanted commands of the original remote. The remote I used was a Sony RM-VL610 which could learn the original remotes functions easy and quickly. This is a very good remote for only $30 purchased at Target. The Macro commands were also entered rather easily. I did not try this method originally,because I thought it would be too time consuming and difficult.
pcwg
SOURCE: Unit plays DVD but no longer Blu Rays
That is because of a dirty or defective lens. When lens is dirty, the unit may still operate on regular CDs and DVDs and not be reading BD.
Try first using a lens cleaner for Blue Ray:
Maxell 190054 Blu-Ray Lens Cleaner
If that does not work, the unit may be disassembled, and lense cleaned
with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Being this a blue ray unit , I would suggest calling support instead of disassembling the unit by yourself.
Regards
SOURCE: Samsumg BD-P1500 Blu-Ray Multizone
possibly because the regions are different to dvd than blu ray, there are 8-9 for Dvd and 3 for blu ray.
SOURCE: Samsung BD-P1500 will not play blu-ray discs
it seems that samsung is posting it's firm updates online @ samsung.com i had same problem with my BD-UP5000 its connected to the internet when i go to the menue to update on the bluray player it said i had the latest update went online and found a new firmware on there web site, check samsung web site
SOURCE: my samsung bd-p1500 blu-ray player won't play
I'm having the same problem. had my Blu-ray and my cable box plugged into my reciever. Blu-ray kept cutting out and not finding a signal while watching my Rome DVDs. I swapped HDMI cables by just switch which cable went out of my blu-ray ( I didn't change what ports they were plugged into on the reciever. That cleared up that problem. I'd assume it was a faulty HDMI cable except that it works fine on the cable box. Anyways, we were watching Iron Man on Blue-Ray and it starts to skip about 2 thirds through the movie. Same as you I updated the firmware, disabled BC-Live, No luck Don't know if the problem is hte Bluray player , the reciever or what. Everything is up to date so I don't get it at all.
