Question about The First Years Single Set Pressure Gate For Baby
I need baby gate parts
Where can I find replacement parts for the end screw parts?
Where can i get the end part that screws into the wall?
here is the phone number Carlson Pet Products 952-435-1084.
Mar 28, 2014 | Top Paw Extra Tall Pet Gate with Small Pet...
Need replacement parts for tall pet gate
I have the same gate and have the paper work that came with it.
Top Paw is Carlson Pet Products, Inc. Their # is 952-435-1084
Dec 01, 2013 | Top Paw Extra Tall Pet Gate with Small Pet...
I need the same, but this is the best I can find but not sure if will do the trick for the Top Paw tall gate I have. Did you find a solution? http://www.gates4pets.com/bindaboo-pet-gates/gate-accessories/replacement-hardware-parts-for-gates-white.html
Looking for assembly instructins for Evenflo baby gate model 1196 and extension panels model 1106.
Go to:
https://plweb.evenflo.com/replacement_parts.aspx
You will have to put in the gate model number and date of manufacture. The date of manufacture can be found on the warning label at the bottom of the gate. This above link will bring up a web page with all replacement parts and manuals available for this model. If you need any further assistance please feel free to contact me with follow up questions. If this answer was helpful please do not forget to leave me with positive feedback
Jul 09, 2011 | Toys
How do I purchase new hinges for the baby gate?
Looks like you have to call the company.
I need to replace hinges for the safety 1st Perfect Fit gate and will do soon. If I remember, I'll provide an update.
Dec 27, 2010 | Safety 1st Perfect Fit Gate Fits 30" 42"...
I lost the instruction Manuel and I need to convert the crib into the toddler bed
First I unbolted the four arms that hold the metal bed support up and pushed it down as flat as I could. I had to do it a couple of times and go kind of slow, to get the loose arms tucked away as best I could. They still stick up a little above the rest of the frame.
After much wrestling with the wooden front panel (gate) of the crib (the one I need to remove), here is what I did:
1. Find the wooden piece that crosses the bed just behind the gate. This is an approximately 1.5-inch by 3/4-inch piece. On ours, it's just above and in front of the drawer under the crib.
2. Find the metal screw at one end of this cross piece. You will see that it is on the outside of the bed, on the short end of the bed, in line with the cross piece.
3. Unscrew it. Note that this screw actually threads into a threaded piece inserted into the cross piece in a little hole on the back side of the cross piece, about 3/4 inch from the end. If this little silver metal piece falls out, you will need to find it and put it back in the hole with the threads facing the screw hole. The piece is the size of a pea.
4. Anyway, use an allen wrench to remove the screw, without losing that little inserted thingy.
5. I'm not saying this is textbook, but I then forced the end of the crib away from the rest of the crib while moving the gate up and down and pulling gently toward me (to pull the gate from its track). You have to move the end of the crib to create about a 1/2-inch gap before the gate will pop free.
6. The gate has two pins on each side, so when you get it freed on the site that you removed the screw on, the other side will come off without removing the second screw on that side.
7. I then got the drawer back on its tracks properly (it jumped the tracks a bit in the process), pushed everything back together the way it was, and screwed the screw back in. (if the screw wont thread, either you lost the aforementioned little silver piece, or that little silver piece is turned in the hold the wrong way)
8. With the gate removed, the crib (now toddler bed I guess) has four little tabs where the gate was once attached. Two I had to unscrew, and the other two I grabbed with a pliers and pulled out.
It wasn't elegant, but I certainly have an intact toddler bed now.
Hope helps. Good luck.
Oct 04, 2010 | Toys
I need to remove the drop side of the crib so convert it into a daybed. I can't find a manual anywhere on the web.
Aunt Sissy 588,
The sliding 'gate' is fixed with screws which will require a flat tip or star tip screw driver and likely a small Allen key of between 3 and 5mm (1/8" and 3/16"). With a little thought and removing all items associated with the vertically sliding 'gate' ONLY you should end up with a lovely stable day bed at no cost.
Sep 15, 2010 | Alta Baby Mimosa Crib
Hardware parts for jenny lind baby bed
I need the 2 gate shows for the drop side and the hooks to hold the mattress spring. Please help!!!!
May 15, 2009 | Evenflo Jenny Lind Crib
Evenflo model 10502 baby gate
Here is a link to Evenflo's website.
http://safety.evenflo.com/cs/sc/cssc_RD.phtml/
You can register your product, order instruction manuals and replacement parts. They also offer instructional videos, checklists and suggestions for keeping your baby safe. The site asks for the Model #10502, also the manufacture date (show example of where to locate.) I believe the instructions are free.
I order replacements parts in advance for items I can not live without. Living all over the world makes it difficult to get assistance in a timely manner. Also for gates that have permanently mounted hardware, I buy extra sets of mounting hardware. This allows me to move the gate, saving money by not having to purchase multiple gates.
This is not one of those times to "wing-it." Safety gates need to be installed per manufacturer specifications.
I hope this helps, good luck.
Kym McC
Oct 01, 2008 | Baby Gear
The First Years Single Set Pressure Gate For Baby Logo
75 people viewed this question
Top The First Years Baby Gear Experts
Alan Matzke
Dorel UK
Dorel UK
Tom Chichester
Are you a The First Years Baby Gear Expert? Answer questions, earn points and help others
