How o adjust samsung syncmaster sa10 lcd monitor
tantong
  • 138 Answers
SOURCE: Samsung LCD Monitor SyncMaster 203B
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen blacked out or stopped working, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 26, 2008
  • 406 Answers
SOURCE: How do you open up Samsung LCD 740N monitor?
This monitor contains a latches to open. Its recommended that you use suitable tools and service manual.
If the unit is in warranty its recommended that unit to be serviced by service Engineer.
Posted on Dec 30, 2009
budmrtn
  • 11361 Answers
SOURCE: Samsung SyncMaster 730B LCD monitor isn't backlit at all
Most failure in LCD monitors are due to cheaply made caps being use. If you are going to DIY repair, please read below, or if you are going to have it fixed then at least you will know if you are being ripoff or not.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Apr 22, 2010
  • 6771 Answers
SOURCE: Samsung SyncMaster 740N 17" LCD
The problem is in the power supply and inverter board, cause normally bad capacitors that sometimes bulge at the top indicating they are open.
Posted on Feb 21, 2011
I have a samsung syncmaster sa10. The monitor screen needs to be adjusted to the right. How do I make the adjustment?
I will admit, have never seen you monitor before. But looked up in Google and found this. Hope this helps.
1 Press and hold the power button for 5 seconds. Then a menu should appear...
2 Press and hold it until it is over AUTO. Then tap the button once.
Let us know if it helps. It would not break your monitor to do the above. But be patient and follow the above simple procedures. This could help others same as you.
Jul 01, 2014 | Dell E173FP 17" LCD Monitor
Rayas Horizontales Monitor LCD Samsung SyncMaster SA10
The monitor is defective, probably a power surge blew some components.
Apr 04, 2014 | Computers & Internet
How to adjust brightness for samsung syncmaster SA10 monitor ?
Download Magictune from Samsung, it will allow you to adjust the brightness. It can be found here:
http://www.samsung.com/us/consumer/learningresources/monitor/magetune/pop_download.html
Jan 30, 2014 | Gateway FPD2275W LCD Monitor
Samsung syncmaster SA10 auto adjust display settings
press d only botton untill menu pop ups than press d only button it switches to other option when it is on auto leave the button and press it quickli again untill its auto start u done !
Dec 13, 2012 | Computers & Internet
SyncMaster SA10, my screen turned green, i've tried everything but it's still the same. Help ?
The Blue and Red drives are missing and the TV needs attention by a qualified service technician.
Jul 14, 2012 | Samsung SyncMaster 940MW 19 in. LCD...
Samsung SyncMaster 740N 17" auto adjustment locked
I just had my Samsung 740N LCD monitor auto adjustment lock 2hours ago.
But i found this cool solution at
www.fixya.com
"Press down
the menu button(1st button on the left) for 5sec or until the menu display gone?"
and it works for me. Hope it will work on you
Thanks
http://www.fixya.com/
Apr 28, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
LCD Monitor SAMSUNG Syncmaster 172x
change the potentiometre(three broches) and adjust it.
you find it near circuits which switch on the lampes (card has smalls tranformers)
good luck,Mustapha(Casablanca,
Morocco)
Apr 08, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
