Question about Exercise & Fitness
Why is my Precor Efx 546i elliptical showing an error message?
  • 914 Answers
Precor Error 29, Excessive AC Input Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Bad lower PCA.
3. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good lower PCA. Replace lower PCA if necessary.
  3. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 29
Posted on Feb 04, 2015
2 Suggested Answers
SOURCE: looking for repair manuals and error codes for
Could you please advice about ERROR 29 fo C956i/C966i treadmill.
Posted on Mar 04, 2010
Can I adjust the stride length?
Precor EFX 546 Version 1 Elliptical Trainer (Refurbished)
www.amazon.com > ... > Elliptical Trainers
Amazon.com, Inc.
Rating: 4.3 - ‎9 reviews
Working out on an elliptical can burn as many calories as working out on a treadmill. ...allowing you to go forward and backward, as well as adjust stride length to target ...The Precor EFX 546 allows you to stride smoothly while holding the ...
EFX® 546i Elliptical Fitness Crosstrainer™ ' Precor
www.precor.com/en-us/.../efx-546i-elliptical-fitness-crosstrainer-33
With the unique Precor CrossRamp® technology, users can alter the path of the EFX®546i between 13 and 40 degrees in both forward and reverse stride motions, cross ...Excellent stability and freedom of movement for users of all sizes.
FAQ - Precor
Dec 28, 2015 | Precor 546 Elliptical
CROSSRAMP ON PRECOR 546i DOESNT GO UP OR DOWN
I would definitely check the battery first. The battery may not have enough charge to power everything plus the lift motor.
Here's a link to the various 546i models:
Repair Parts for Precor EFX 546i Ellipticals SPORTSMITH net
Drill it down on the left side under "narrow your search" and look for the serial number prefix. This will let you find all the correct parts and information specific to your model and serial number.
Jan 17, 2014 | Precor EFX 546i Elliptical Version 4
"stuck key" message on efx 546i, will not engage, already replaced batttery
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Feb 17, 2013 | Precor EFX 546i Elliptical Version 4
Where is the battery located in the 546i
It should be located under the lower electronic board. If you have your serial number, you can go to our Website and get a diagram of your machine. This will show you exactly where your battery is located. Precor Elliptical EFX Repair Parts Belts Wheels Pedals SPORTSMITH net
Mar 21, 2012 | Precor EFX 546i Elliptical Version 4
Precor efx 556
Here you will find parts and other information for the Precor EFX 556.
Repair Parts for Precor EFX 556 Ellipticals SPORTSMITH net
Jan 07, 2012 | Precor EFX 546i Elliptical Version 4
Dead battery on Precor EFX 546i Elliptical - options on how to handle, please? Thanks very much.
This link will allow you to use your model and serial number to find the correct battery along with the service manual with replacement instructions.
Feb 13, 2011 | Precor EFX 546i Elliptical Version 4
Error message "key depressed" and no resistance on elliptical.
you will need a keypad and overlay call National Gym Supply @ 1-800 496-7278 they will need M & S #
Feb 06, 2010 | Precor EFX 546i Elliptical Version 4
Exercise & Fitness Logo
226 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
