Question about Jetway V266B Motherboard
Shutdown Power supply blew a capacitor. Replaced PS, system came up, runs for about 8 to 10 minutes, then shuts down. Can't bring system up again until I wait for about 10 minutes with PS switch off. When system does shut down, it sounds like the HD makes a whirling sound. Tried another HD with the same results. I tried the PS in another system and it runs OK.
  • 656 Answers
A capacitor doesnt blow of by itself the connecting components may be faulty check resistors dides and transitors in the power supply for change in value leaky or any other defult
Posted on Nov 30, 2007
IN104 automatic shutdown
Hello, my infocus in104 will power up for a while (1- 5 minutes) when connected to the power supply and turned on, after that it automatically shuts down. Power button does not light red when it automatically shuts down and need to be unplugged for a minute or more before red power button will light up again.
Mar 21, 2013 | InFocus IN104 Projector
42 plasma tv started experiencing the well known power off red light symptoms. Was able to power on & off for a while to get the set on. Right before the capacitors came in the TV would not power on...
Only if it is completely dead. If you have lights or LED coming on then it's not the main fuse, I would say that you changed the caps, but there are some that you missed. Look hard again and also for maybe a resistor in the power supply.
Dec 14, 2010 | Philips 42PF5521D 42 in. HD-Ready Plasma...
T.V. was on several minutes later the sound and picture disappeared. Tried troubleshooting in manual but nothing worked, what should we do now.
The unit senses a fault in the power circuit. It is either in the power supply unit (PSU) peripherals or in the PSU itself.
  • One of the peripherals might be loading down the PSU causing it to shutdown.
  1. Check the power input terminals of the peripherals for any short circuit using an ohmmeter.
  2. Replace any part found to be causing the issue.
  • The power supply unit cannot run under load and shuts down. It is usually caused by bad capacitors.
  1. Check the PSU board for any bad capacitor.
  2. Replace bad capacitors with the same specifications.
  3. Make sure to replace the capacitors in correct polarity.
  4. Bad capacitors look like these:3a72a3c.jpg17dffa0.jpg
Nov 05, 2009 | Televison & Video
Ps3 shutdown?
hi..Seems like your Power Supply went dead or either a faulty button.. Since those are touch pads those sometimes wear out. Another issue could be due to overheating..
thank u
rate me
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
Computer shuts down.
Hello;
So i guess that the PSU is good. As i diagnose of what you have said, i digested a conclusion that when the computer shutdown when application run. there a problem conflicting the application to another application or such an application trigering the system to shutdown.
Some causes of this problem are:
The system is infected by known and unknown virus
The driver of the system are not properly installed
The application program committed an errors trigering the system to shutdown.
Possible solutions:
1. Scan you system with a potent anti virus
2. Remove the installed driver of the sytem and reinstall it after restarting
3. Unistall the application that causes shutdown problem and you can reinstall it after restarting.
4. remove newly installed hardware or install the correct driver of the hardware.
Note in scanning your system with antivirus you should scan it it safemode.
some usefull links: http://www.precisesecurity.com/antivirus/online-scan.htm
If all the solution did not work to your system. please notify me for further solution.
best regards, melnavz
Feb 20, 2008 | E-Machines W3052 PC Desktop
Lamp shuts down after startup
it is the power supply/ballast. when you first turn it on, the caps on the ps/bal charge then discharge when the lamp is to strike. if the caps are dried out (from excessive heat), it takes a while to build a charge. so the power drain from striking the lamp brings the ps/bal into shutdown. after you try again, the caps are now up to full power and everything is fine. but every time you unplug it, you'll have the same problem. replace the power supply and ballast.
Dec 11, 2007 | Boxlight CP 19t Multimedia Projector
Blows fuse with no load
Sure sounds like your power supply has a short and should be replaced.
Oct 30, 2007 | Codegen POWER SUPPLY CG|PS-350XA-12 RT...
HP Pavilion 752N shutting down issue
what kind of power supply is it? its it from hp or a 3 party? how many watts does it have just send me your computer specs to jose6992002@hotmail.com so i can check it out
Oct 10, 2007 | Computers & Internet
Presario S4020wm desktop
You need a new power switch. I am currently working on a S4020WM with the same problem. I cut one wire to the power switch, then used a paper clip to make a jumper to start the machine. It has run fine since then. The only trouble I am having is finding a replacement switch.
Sep 04, 2007 | Compaq (480082-001)...
Jetway V266B Motherboard Logo
75 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Tony
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
