Question about Mitel 5330 IP Phone
How do i send a call to voicemail box
Semding a call to voicemail
I need an activation code for zesuimshop.net Mobile pdf. Application code: 0093025 registraition code: 548017 I'd really apreciate your help, my email: lindokuhlenzama4@gmail.com
Please send me pdf activation code application code-0093026 andregistration number a9fe17 send my mob number 7600370743
Aug 17, 2013 | Cell Phones
Everything on the dash works except for my fuel gauge?
I tink your problem is the semding unit located inside the tank but before check the harnes. orwires bethwing cluster and fuel lebel sending unit.
Sep 01, 2012 | 2006 Suzuki Vitara
Need to connect dvd to play
Hello
Inform your Email Adress to me by Fixya comment box. I've the user manual for your DVD player, Sany DWM-450. All details and connections [illustrations] are there it it. I cannot send that document to you by this window, as it does not allow me to upload PDF files by it. I'll semd a copy of it to you by returm mail, if you send your Email address to me. OK.
Oct 26, 2011 | Sanyo Cinematic Progressive Scan DVD...
I cant get my new greeting on norstar telephone to save.
Chances are you're logging into your voicemail system and pressing the REC button ... that's to record a greeting that you send to someone else's voicemail box. You need to login to your voicemail, go to ADMIN (or dial 8), then select GREET, REC, PRIM, ... should be straight forward from then on. If you have trouble still, send me more details about what you're doing.
Apr 22, 2011 | NorStar M7310 Corded Phone
Does not wait for the 4th ring; sends call to verizon voice mail box after the second ring
Sounds like your service provider(Verizon) has your phone line setup to forward to voicemail on no answer after 2 rings. Call your service provider's customer service number and request that the number of rings for forward no answer be increased to at least 5, then your answer machine can receive and answer your calls after 4 rings but if your line is busy callers can leave a message with your Verizon voicemail service. If you don't want Verizon voicemail to answer any of your calls, you could have them disable the voicemail service. When you call the service provider have a recent bill ready because they may request your account number before they will make any changes.
Feb 25, 2011 | Uniden EXA15580 Cordless Telephone
CP100 Auto Attendant transfers direct to voicemail
The norstar extension may be setup up for Call Fwd to voicemail, or call fwd/busy. Also, Custom Call Routing may be setup to send the caller directly to the mailbox.
Nov 10, 2009 | NorStar CallPilot 100 Voice Mail, 10 mail...
Right click on desktop semd to not avilable
http://www.dougknox.com/xp/scripts/xp_sendtodesktop.vbs
download the above file and run it. it will fix the problem.
Revert back for any clarifications.
Mar 20, 2009 | Microsoft Windows Vista Home Basic Edition
IPhone voicemail doesn't work?
call 611 from the phone you can press I think option 1 then option 3 you should be able to reset your voicemail pwd. however before you do that you should call your phone from another phone not just press 1 send. by calling your phone it will let you know if you have a voicemail box actually setup porperly.
Jan 25, 2009 | Apple iPhone Smartphone
Avaya ip office manager setting issue
That is for voicemail to email.
Copy, send a wav file as an attachment to email as well as leaving a copy in the phone
Forward, only send voicemail to email address.
Alert, only sends an email to say that you have voicemail, still need to access phone to get vociemail
Dec 17, 2008 | Avaya Lands Phones
Mitel 5330 IP Phone Logo
22 people viewed this question
Top Mitel Computers & Internet Experts
Martin Murray
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
