Question about LG GX300 Dual Sim GSM Unlocked Phone
What is usim removed handset will restart
I took off my head phone and this came up usim removed handset will restart
I need my pin2 unlock code for my phone... IMEI is : 011741000973608
PIN 2 code is not a handset dependent, for you to get the Pin2 code of your handset try calling your Network Service Provider because that code is encrypted on your USIM or SIM card. 1234 is the default PIN and PIN2 code.
Cheers!
Jul 02, 2011 | Nokia 2680 Slide Cell Phone
There is this E icon on the left side, does this mean that the internet is running? Because I will be charged for this, how can I remove this? Thank you very much and God Bless!
With that, it will not charge you, That is just the indicator that you do have EGPRS signal in your location. With Samsung handset, if your USIM or SIMCARD is activated for GPRS/EDGE/3G/HSPA
it is not possible to remove the Signal indicator. Even if you will delete all the configuration settings in your handset.
Cheers!
May 30, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
It says usim blocked
please make sure that you are using the correct usim provided with that handset. your phone is locked with a specific service provider.
please dont forget to click on 4 thumbs up
thanks
Apr 02, 2011 | Cell Phones
KC910 Renoir Cell Phone: when the Renoir says others in the phone memory wh...
in a renoir cellphone you can use the handset (phone memory) ,USIM (SIM Card) or both it displays files on a certain memory if its on handset it displays files ONLY on the handset
May 16, 2010 | LG KC910 Renoir Cell Phone
Insert smartchip
There could be a fault with the contacts on the USIM reader of your handset
Oct 10, 2009 | LG Vu CU920 Cellular Phone
Insert correct usim on a sony ericsson w595.
You need to purchase a network unlock code from '3'. This will enable you to put any sim in the handset.
Local markets somtimes do a phone unlock service too.
Aug 19, 2009 | Cell Phones
UNLOCKING USIM
my LG CEO168/KC550 previously a contract phone with virgin i have put a pay as you go virgin sim in it but its telling me emergency calls only help
Jul 20, 2009 | LG CU500 Cellular Phone
What should i do when USIM-MEP and usim error appear?
pls help me i cant use my phone because USIM-MEP what should i do ???
Aug 21, 2008 | Sharp Lands Phones
My skype phone is not turning on
- First check if your phone is charging at all when plugged in.
- Switch the phone off and on (obviously not if it's switched off)
- Take out the battery, put it back in (making sure it's charged), and try again
- Take out the memory card (and restart)
- If you can, check the memory card for errors.
- Take out the usim and check what happens when you restart the phone without it.
- If you can, check the usim in another 3usim-compatible phone.
With every step, make sure the contacts (sim/mem/batt) aren't covered in dust
If it's still not starting up, give the customer service centre and they should be able to help you further
May 12, 2008 | Lands Phones
PHILIPS ID937 phone.
Fixed:) Ok so I bought 2 extension handsets from different people off of Ebay, both new. First one wouldnt register or would say incorrect pin (0000). So I tried the second one, same thing. Here is what I did: When attempting registering, make sure the handset is physically on top of the main base station, IE charging. Start the registration process on the handset and press-hold (dont let go) the locate handset button instead of press and hold for 3 seconds (like the manual says to). If that didnt work, I removed the batteries and tried pressing and holding the same button for 3 seconds, then release. Wait 10 seconds, then press and hold for 3 seconds. Repeat. If the handset timed out and went back to the main unregistered instruction screen. I took the batteries out and tried again. It was a bit of trial and error but each cycle I removed the batteries to reset the handset. First extension handset took 20 minutes of head scratching, the second 2 minutes. Hope this helps someone. The build and sound quality on these units are great, the tech support....not so much.
Apr 02, 2008 | Uniden Cordless Phone
LG GX300 Dual Sim GSM Unlocked Phone Logo
83 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
