Question about Canon Faxphone L170 Monochrome Laser Fax 0815B002AB
Black verticle line,left side
Hi, the printing output works normally, but when i make copy,there is black line(about 1 inch wide)at left side of the paper. i was check the cartridge but no ink mess as well as fuser are still ok. All part of the printing area are clean. I was download and read the pdf manuals but no help. please help me the solution. thanks
    Sergeant:
  • 274 Answers
Problem will either be in the toner or fuser.
If you have a spare toner, try that first.
Posted on Feb 12, 2014
3 Suggested Answers
SOURCE: Printing problem
I solved the problem on the MP530 printer of a friend of mine.
BUT: If you are not a DIY, I would strongly recommend not opening this machine.
It took me more than a couple of hours to disassemble, clean and reassemble again.
If you follow the disassembly instructions below, you might be able to do this faster than I did, because I had to figure out how to open the case without breaking anything.
Also, in the end, you will need some less ordinary tools like a very tiny crosshead screwdriver and a slim stick with a hook at the end to get the springs back on their places again. I used a steel instrument with a hook my dentist gave me but I guess one can fix a tool with a bent paperclip.
SECOND BUT: I cleaned up the consequences of this problem so the printer works fine again without that black streak on the back side of the paper. This does not mean that I found and fixed the problem.
Because I have not been able to find out where all this ink comes from in the first place. It is obvious that this ink is NOT produced when the printer prints because in that case it would have been on the front side of the paper and not the back side.
In this printer, once I had disassembled all and was left with the bare printer basement and the unit which does the sheet transport out to the front, I discovered a real mountain of nearly dry ink. The bottom of this mountain was sitting on the basement of the printer which is covered with a special kind of absorbing material which is supposed to deal with waste ink. And the mountain was high enough to rise through the sheet transport unit. Which explains the black streak.
As someone else said, the top of the mountain is underneath the big black cartridge.
So, one might say that this cartridge is/was leaking. But I have not changed the cartridge and the printer does not leak anymore.
To check this, once up and running again, I have been sliding a small piece of paper underneath the inner cover (the one you have to open if you want to change a cartridge).
By inserting this piece of paper while you pull down the cover (which enlarges the inner height of the sheet transport unit) you will be able to push the paper way in, underneath the area where the leak should be.
Whether the printer is off or on, in economy mode or cleaning heads, no single drop of ink came out.
It might of course be that my friend had not completely inserted the cartridge as it should, but in that case the printer should have warned, don’t you think?
I also found that exactly on the spot where the mountain was sitting, there is a small plastic tube which goes right, to the area where the heads are cleaned. I know that this tube is to transport waste ink, but I don’t know in which direction. If it is supposed to suck ink out of this place and spit it out in a lower level absorbing reservoir then fine, but what if it operates in the opposite direction? Then it would be able to spit ink underneath the paper even while you are printing… I am sure that real printer technicians have the answer to this question, so if someone wants to help us out with this one…
Do you still want to clean your printer? (Because that is all I did in the end).
Here you go then:
Next steps in the next post, since apparently text length is very limited here.
Posted on Jan 27, 2008
daryn720
  • 113 Answers
SOURCE: black ink cartridge is leaking and black line is running down back of page
YOU CAN TRY PULLING THE CARTRIDGE OUT AND WITH A CLEAN , VERY SOFT CLOTH , CLEAN THE HEAD GENTLY ....SOME CARTRIDGES ARE JUST FAULTY ....HAVE YOU TRIED RETURNING IT OR GOING TO CANON SITE AND TROUBLESHOOTING ?
Posted on Jun 02, 2009
B&w 6800 lots of horizontal black line areas. also, a vertical white strip about 3/4 inch wide about 3 inches from left side of paper
Hi!
the best thing is to make a copy using the glass and not the document feeder!If there is no lines on the copy simply lift up the cover and on the left side of the glass will be a thin strip of glass,Clean it with a dampened cloth and all line and marks should be gone1
Good Luck!
Apr 02, 2011 | Brother MFC 6800 All-In-One Laser Printer
Getting black strip about 9/16"
it may be due to either malfunctioning of the scanner tube within the printer itself or whenever you copy a certain page the lid is not properly pace resulting to excess light on that side giving you black line when the copying is in process
Mar 06, 2011 | HP Officejet 5610 All-In-One InkJet...
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
1/2 inch wide black line appears on the copies
Please use the link provided below to download the user guide. The user guide and the troubleshooting guide will have detailed steps to solve this issue.
http://safemanuals.com/user-guide-instructions-owner-manual/HP/PSC%201510-_E
May 20, 2009 | HP PSC 1510 All-In-One InkJet Printer
One big black verticle line 2 inches from left side...Help
Honestly you have a big problem because the driver IC & Tape Carrier Package inside controller board at vertical area are damage or itself defective could cause you have 2 inches line appear in your display. The best solutions for this replace lcd panel to fix vertical line.
Mar 28, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
3-INCH WIDE VERTICAL LINES RUND DOWN LEFT SIDE OF FAX MACHINE
Do your incoming faxes have the same marks?
If not you might find that the scanning part of your machine has a dirty mark on the glass or that the unit has become faulty.
Try and take a copy from the machine and print from a report or any print from memory.
If you have the black lines on both then i'd suggest getting a new drum unit, if u have it only on the copy I would have a look at your scanner glass and see if there is a dirty mark on it. if not maybe call out an engineer as the scanner unit maybe faulty.
Need anymore help msg me.
Dec 11, 2008 | Office Equipment & Supplies
Thin black lines (mp 530)
Here's the link for how to clean the unit... I was going to post the instructions here, but there are pictures that might be helpful to you.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13371
Before doing anything more drastic, I would try this.. let us know how it turns out.. if it doesn't work, we'll go from there.
Maggie B
Feb 23, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Black Line printing on copies
Just clean the glass top of the scanner and the slit of glass on the left hand side of the scanner.
Dec 04, 2006 | Canon PIXMA MP780 All-In-One InkJet...
Canon Faxphone L170 Monochrome Laser Fax 0815B002AB Logo
old marine
old marine
