How do i clear the jam in the exit area of my samsung CLP-620ND printer
SOURCE: Paper jam at exit
The rollers at the exit area are worn out. They can be changed, in the mean time you can use something like sand paper to rub across the rollers to take the smoothness out of them. That will help them get a grip on the paper as it is exiting.
SOURCE: samsung laser printer clp-550
When I this error on any printer my first question is 'Has somebody pulled on some stuck paper and torn it?' If people are honest and say 'yes' then there may be tiny piece of paper covering a sensor. Pull out the toner(s), fusers and paper tray(s) and look closely for any scraps of paper. They may be jammed in the parts that you just removed. If you have another of the eact same model you could simply swap parts to check none of them are faulty. Lastly, it may be worth buying a can of air and blowing it through the printer in case there is paper dust covering any sensors. Failing these, get the printer servied.
Please rate me if any of this helped J
SOURCE: my samsung printer clp 315 has a paper jam with
From You Tube:
http://www.youtube.com/watch?v=5fJHykzkfww
DIY video tutorial on how to repair the Samsung CLP-315, CLP-301 laser printer "paper jam" problem, where the paper stops printing about halfway through for no apparent reason. My printer worked great otherwise, but was out of warranty. It would have been less expensive to get a new printer.
The problem is a very cheap sensor.
This repair takes 15 minutes and is inexpensive. Read the comments below.
I got the part from SamsungParts.com. Search for part #0604-001393
