Question about Cadet Manufacturing 67507 Heater
Cadet wall mount and thermostat
I have two cadet wall mounts ea. 1500/240.  The thermostat has two romex w/ one being 240-  I connected ea. of the white leads together and then connected the remaining blk leads to a single pole therm. The issue is it keeps triping the duel 20/20 breaker and to add- when I connect the two white leads I have 120 at ea. heater but when I connect the remaing blk leads to therm. the breaker will trip-any suggestions?  Thanks John at docmann89@yahoo.com
  • Anonymous Jan 04, 2008
    my cadet wall heater's fan wont work all the time sill gives off heat can I fix that or should I buya new heater
  • 625 Answers
Your wiring is all wrong. for a 240 heater a 20/20 tandem breaker will not work with a 240 heater. you need a 20 amp two pole breaker. the two wires at the heater need to be connected to the line. you probably have two black wires at the heater. one connects to the white romex which should be taped black, and the other romex black connects to the other black wire. at the panel one white goes to one side of the breaker and the black to the other. the bare ground goes to the neutral bar.
Posted on Nov 05, 2007
Cadet baseboard heater
If I have your information right you have a black wire and a white wire marked red coming to the heater with 240 volts between them. You have a double pole unit mounted thermostat with a red and a black wire. Most double pole thermostats have two red and two black wires on them so I am not sure if you have a double or a single pole thermostat.There are also two wires going to the baseboard heater. One is connected to the element the other to a high limit switch which is then connected to the other end of the element. If the thermostat is a double pole the two red (or load) wires should connect one to each of the baseboard wires. The two black (line) wires should connect one each to the two incoming power leads. If it is a single pole thermostat the one red wire should connect to one of the baseboard wires the black should connect to one of the incoming power wires the remaining baseboard and power wires should then be connected together. Hope this helps
Dec 12, 2013 | Heating & Cooling
I have a White Rodgers digital thermostat .I do not have the manual.I am getting a lo battery message. How do I replace the battery? Does it come off the wall or is there an easy way to open it? I dont...
The outer shell of the thermostat pushes on(clips) to mounting bracket attached to wall.
1. Remove the packing material from the thermostat. Gently
pull the cover straight off the base. Forcing or prying on
the thermostat will cause damage to the unit
http://www.emersonclimate.com/Documents/White-Rodgers/0037-6488.pdf
This is the manual for your unit.
May 24, 2011 | White Rodgers White-Rodgers 1F85RF-275...
Hello i have a williams wall Furnace model#25-35-50. I need to know if its a base board heat and also if you could tell me which wires are which. 1 red and 1 white
What you have is a Direct Vent, Gas WALL Heater. It is normally mounted about 6" off the floor on an exterior wall (since it has to be direct vented out). Not sure what the red and white wires are for, but suspect it's for the optional thermostatically controlled blower connection.
In any event, to help you install this heater properly, I have included a link to the Owner/Installation Manual, which should provide all the information you need to complete the installation correctly.
http://shopfnc.com/pdffiles/williams2man.pdf
You can download and print the manual for future reference.
Feb 26, 2011 | Williams 3003622 Ceramic Wall Mounted...
I am trying to install a fahrenheat f2543 heater with a fta2a double pole thermostat. there is a 12/2 wire coming into where the heater is being installed. how do i connect the red and black to the white...
Hi, this is very easy for you to do.The 12/2 Romex wire coming in is the power which you know. What you do need to know, is the voltage coming in? Sometimes they will use 12/2 Romex with ground for 220, 240, operation. You need to know if the T-stat is Line voltage 220, or 240 volt. You have to have the same voltage for both for it to control. Reguardless of the voltage, lets say it is in the 220 and up range. You take one of the 12/2 wires, white or black and hook it to the black or red on the T-stat and the white to the other one, red or black. Thats it, you are done! If the T-stat is 2-pole I am sure it is a high, Line votage T-stat. Best of Luck,
Shastalaker7
Nov 09, 2009 | Fahrenheat Built-In Baseboard Thermostat...
Trying to replace regular phone mount with a wall mount
If your just changing the jack to a hanging type, the fix is easy. You remove the old jack, replace with new one connecting the original wiring...red/green or blue/white.
Apr 16, 2009 | Lands Phones
Re: wiring the FV-08VKS1
The black and white in the fan box are the main power and neutral for normal (low speed) of the fan. The two reds are the signal wires. It is basically a switch loop. You will actually need a total of 4 conductors (plus a ground) in order to run the high and low speed of the fan. The four conductors consist of 1) power from one switch to power up the fan, 2) neutral, 3) signal going to second switch, 4) signal going back to fan from second switch in order to run high speed. Without four conductors you can still run the high speed only by tying the two red wires in the fan together. This would be like always having the second swith in the on position. Hope this helps.
Jan 05, 2009 | Panasonic FV-08VKS1 WhisperGreen Ceiling...
Audio buzz
Check to see if reversing the plug takes away the buzz. Some times turning the plug over in the wall socket i.e. reversing polarity, will remove the buzz.
Dec 09, 2008 | Philips HTS3400/37B System
Connecting 240 volt singer baseboard heater
Need front grill for singer model WJA-12 wall heater Cat # 9756-A
single phase 60 HZ
240 volts 5.2 Amps
1250 Watts
Where can I find it?
Nov 28, 2007 | Heating & Cooling
Cadet Manufacturing 67507 Heater Logo
665 people viewed this question
Top Cadet Manufacturing Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
Are you a Cadet Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
