What mixed number equals 32.088 - Computers & Internet
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Computers & ... Master
  • 102,366 Answers
32 22/25
Posted on May 26, 2014
Owens is 147.3 cm tall. What is Owens height as a mixed number? What is Owens height as an improper fraction?
4 feet and 10 inches MIXED (you just convert to feet and inches. http://www.miniwebtool.com/cm-to-feet-and-inches-converter/?cm=147.3
58/12 IMPROPER FRACTION
(10 inches is 10 parts of 12 as there are 12 inches to a foot. Each foot is 12 inches, so we multiply the 4 feet by 12, which makes 48, plus the 10 <inches> equals 58. As we are using12 as the divisor, it is 58 twelfths.
It is important that you are taught how to do this rather than just getting the answer :>)
Aug 20, 2015 | Office Equipment & Supplies
When making a mixed drink that calls for 2mls or 10 mls or 20 mls of alcohol,what is that equal to in u.s. ounces,please answer for each mls above,,thank you
10mls equals .338 US fl ounces (roughly one third)
20mls equals .676 US fl ounces (two thirds)
2mls equals .068 US fl ounces (too little to measure without a pipette)
Feb 12, 2015 | Motorcycles
How many liters of 20% alcohol solution should be added to 40 liters of 50% alcohol solution to make 30% solution
I will assume that the percentage is per volume (20% per volume, 40 per volume.
Let x be the number of liters of the 20% solution.
What is the volume of alcohol in x-liters @20%?-----> .2x
What is the volume of alcohol in the 40 liters of solution @ 50%? Obviously 20 liters.
Amount of alcohol in the two solutions =.2x+20
After you mix the two solutions what is the resulting volume?
Resultant volume=x+40
Percentage of alcohol in final solution: 30% or 0.3
Quantity of alcohol in final solution =.3*(x+40)
When mixing the two solutions, no alcohol is lost: The amount of alcohol before mixing is equal to the volume of alcohol after mixing
(.2*x+.5*40) =.3*(x+40)
Solve this equation for x. (Show your work) You get x=36 Liters.
Check the result by replacing x in the equation.
Nov 12, 2013 | Casio FX-300MS Calculator
How to figure percentage
Nov 12, 2013 | Office Equipment & Supplies
How do you do a fraction on a sharp el531w
Hi eamon at hom,
Doing fraction on the Sharp El 531W really isn't that bad. I had to use pictures because, the symbols will not transfer over to your posting for me to show you. When you select the [ON/C] this clears the calculator of previous calculations and, data so that they won't interfere with your new calculations.
Let take the first example where a mix number is being added to a improper fraction. Because I used the [a^b/c] key this makes the calculator display the answer in a mixed fraction format or, a proper fraction format. If I press the [a^b/c] key again after the answer the format will change to a decimal format. The fractional formats are displayed in a mixed number, improper or, proper fraction formats. A improper fraction is really a proper fraction number with the top number (numerator) is greater than or equal to the bottom number (denominator).
[ON/C] [3] [a^b/c] [1] [ [a^b/c] [2] [+] [4] [a^b/c] [3] [=] mixed number results. Now let's do the same calculation as a improper or, proper fraction format.
[ON/C] [7] [a^b/c] [2] [+] [2] [a^b/c] [3] [=] still a mixed number result. Even though I enter the fractions in a improper and, proper fraction formats the calculator will still display in a mixed number format. This is because the calculator first displays as a mixed number if it can. If it can't then it will display the value as a proper fraction and, never as a improper fraction. To convert from a mixed number to a improper fraction format if the calculator did not convert it to a proper fraction, I have to use [2ndF] [d/c] keys on the command line.
This show a little more complex raised power use of the [a^b/c] key.
This shows the [2ndf] [x^-1] keys being used to calculate fractions.
When I first saw this question being asked it, was answered with just use the / command. Which that isn't really a good answer because, in math we like to use elimination. If you use the / command eventually the numbers are going to be rounded off and, your not going to be able to eliminate anything. If you have any further question on how to preform fractions with this calculator be sure to post your comment and, I'll be glad to help.
Jan 13, 2011 | Sharp EL-501WBBL Calculator
Whan connecting a graphic equilizer to a mixer do i go from my mixer to graphi inputs then from my graphic outputs to my amp
You could do that if you only need to EQ the end result of the mix.
Or if your mixer has an external processor loop you could place the EQ there and use the EQ on the mix first, or on a source within the mix. It would all depend on the mixer's capabilities.
Feb 23, 2010 | Audio Players & Recorders
I have a hq-31 mono 31 band eq with feedback
first connect your sound source(dvd player-vcr-...)to eq-input-------eq output--------line in in mixing desk.
Oct 13, 2009 | Audio Players & Recorders
How to hook the eq up??
take output from left and right from equalizer and go to line in any two channels inputs in peavey mixing console and adjust your level with faders and other control knobs.
Mar 02, 2008 | Phonic PEQ3400 2x15-band Graphic Equalizer...
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
