Question about AT&T Lands Phones
IT dose not take call - AT&T Lands Phones
Is there mercury in flu vaccines given to children?
The short answer is no.
The Food and Drug Administration (FDA) has approved several formulations of the seasonal flu vaccine, including multi-dose vials and single-dose units. (See Table of Approved Influenza Vaccines for the U.S. 2014-2015 Season.) Since seasonal influenza vaccine is produced in large quantities for annual vaccination campaigns, some of the vaccine is produced in multi-dose vials, and contains thimerosal to safeguard against possible contamination of the vial once it is opened.
The single-dose units are made without thimerosal as a preservative because they are intended to be opened and used only once. Additionally, the live-attenuated version of the vaccine (the nasal spray vaccine), is produced in single-dose units and does not contain thimerosal.
Thimerosal is mercury based compound but its use has decreased as most vaccines are single dose today.
Dec 22, 2014 | Health & Beauty
Why dose the speaker/stereo echo the turn signal? Why dose it play random music when it's on AUX mode? How can I fix the USB problem?
First disconnect the battery then wait ten secondsand reconnect this should reset your radio and other electronocs in the car
Apr 03, 2013 | Audio Players & Recorders
My car starts once then wont start again. Its a 92 Subaru. We tested the starter and it tested fine. Could it be the armiture?
What dose it do after starting then you turn it off whet dose it do /how and wheat type of sound dose it make ,,dose it just go clonk and nothing else/or dose it turn over slowly and dont fire Iwant to get all information before stating the problem.
If it tested ok then the starter should be good
Let me know how it sounds Ron
Oct 02, 2009 | 1992 Subaru Legacy
My picture dose not work but my sound dose how do i fix this problem
go for the HORIZONTAL OUTPUT TRANS or THE VERTICAL IC , , check those 2 sections , good luck AJ
May 15, 2009 | Panasonic CT-32E13 32" TV
Need to adjust coffee dose for odea go
SEE THE VIODEO AND OTHER LINKS ON TYHAT SAME PAGE:
ALSO:
Saeco Odea Go adjusting coffee dose Questions
May 21, 2017 | Saeco Odea Go
MICROWAVE NOT WORKING PROPERLY
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
Otherwise, it sounds like a bad door switch or door switch mount.
Aug 20, 2008 | Daewoo Microwave Ovens
Lands Phones Logo
18 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
