Question about STATEO-MAINE Mens Lounging Robe Vintage Smoking Jacket Dressing Gown
Knee Length Smoking Jacket Accessories
Wat should I wear with a knee length smoking jacket to a 20's theme party? Thanks for helping me. I'm lost.
How do I fix the zipper in my jacket?
I found a answer on google that helped me never heard before but it worked on a pair of knee high winter boots. I would have bet against it working only wore the leather boots one year. it said to get pair of pliers and gently squeeze the part the moves up and down along the teeth, the zipper had split and was a plasticky one. teeth would not join. hope this helps. it saved my boots.
Oct 07, 2015 | Clothing
How long is the brake cable for a 1991 Honda Z50 pit bike?
Hello Cecil,
  1. Front Brake Cable - Extended for aftermarket tall bar and fork kits. Overall Length 40.25inches or 1022.35mm. Jacket measures 35.25inches or 895.35mm.
    Try that for sizing on your Z50 Pit Bike.
    Hope that helps you out.
Nov 19, 2014 | Honda Motorcycles
What is the best cable to connect nad7050 to a pc in 24' length?
Stereo shielded coax. BT3002 would work very well as it is double shielded micro-coax, so it is small enough for two cables to fit in to the shield jacket of a 3.5mm plug.
Aug 22, 2014 | NAD Electronics NAD D 7050
Okley half jacket glasses . lost hinge pin that rotates lens retainer for lens removal
I don't know if this helps but I went to Lenscrafters and got my glasses (a different kind) fixed, I think about the same problem.
Sep 22, 2013 | Oakley Half Jacket
Can children wear adults life jacket?
No. It is very important that life jackets will properly fit the person that wears it. Life Jacket first and main purpose is to keep your head and shoulder above water. If the jacket is loose the floatation will push the jacket around the face and if it's too small it will not float.
Jan 17, 2013 | Boating
What is a duffel coat?
This is a coat with toggles on the front and a hood in the back. It is knee length or sometimes shorter. It is made from duffel (coarse, woolen material). Duffel bags used to be made from duffel also.
Jan 17, 2013 | Clothing
How to kill yellow jackets
wait till winter and the you can get rid of them...if it's in a car...
Yellow jackets are notorious stinging insects that belong to the wasp family. They are identified by their black and yellow stripes and they are usually 3/4-1 inch in length. Yellow jackets are social insects and they protect their nests fiercely. These insects will sting at the slightest provocation and they sting repeatedly. Reactions to the sting from yellow jackets can range from irritating welts to death. If you have a yellow jacket nest in your yard and you want to exterminate them, here are some suggestions on how this can be safely done.
A yellow jacket nest can measure up to six inches across. The nests are usually built in piles of leaves, in trees, under eaves, on the ceilings of outdoor buildings or in the ground. If you live in a region that experiences cold climate conditions during winter, you can safely remove the yellow jacket nest without being harmed. During cold weather the colonies die when the temperature falls below freezing and only the hibernating fertilized queens survive. Remove the nest and destroy the hibernating queen.
Underground yellow jacket nests are usually discovered by accident, i.e., when a lawnmower or other vehicle runs over them. If you discover an underground nest, you can either have a pest control representative destroy it or kill the yellow jackets yourself. Before you begin the job, ask a friend to assist you with the task. Both of you should wear protective clothing. This includes rubber gloves, and a bee veiled hat or bug baffler. Ensure that your entire body is covered. Pull your pant legs over your boots, tie them in place and tie your jacket cuffs to your gloves. If possible wear clothing that is not easily penetrated by yellow jackets. You will need a half gallon wide-mouthed glass jar with kerosene or diesel fuel (never use gasoline), a shovel-full of dirt, and a large non-porous cloth that is big enough to cover the opening of the nest.
When you have collected everything you need to destroy the nest, approach the colony either very early in the morning or just after sunset. During these times the yellow jackets are not as active and are easily caught off guard. Walk to the nest cautiously and quietly, pour the fuel into the nest opening and immediately cover the hole with the cloth. Ask your friend to place the shovel-full of dirt over the cloth. Do not ignite the nest, the fumes you poured in the opening will kill the yellow jackets almost immediately. After you have covered the hole with dirt, leave the area quickly. Never try to destroy any yellow jacket nest if you have had allergic reactions or are unsure about your reaction to stings; call a pest control company instead.
If the yellow jackets have made a nest above ground, i.e., in trees, eaves etc. destroy them with a commercial grade pesticide. Wear protective clothing and follow the manufacture's directions carefully. Always stand at the suggested distance (usually eight to ten feet) away from the nest and aim for the nest opening. If you cannot pinpoint the opening, soak the entire nest to kill the colony.
Another way that yellow jackets can be killed is to construct a trap for them. Fill a large tub or bucket with water and laundry detergent. Secure three poles of similar length in a teepee style fashion above the bucket. Tie the poles securely together with rope. Leave one foot of the rope length hanging from the middle of the poles. Attach a raw fish to the rope and let it dangle about two inches from the water's surface. **** the sides of the fish so that it is easily accessible to the yellow jackets. When they arrive to take pieces of the fish, the slices will be too heavy for them to carry, causing them to fall and drown in the detergent water. Cover the trap with chicken wire to ensure that large animals do not eat the fish.
Yellow jackets can also be killed with lure traps. Most of these traps are devices that use heat, moisture, chemical attraction, and color to lure the yellow jackets. Once they get inside the device they are trapped and eventually die. Before you purchase any of these devices, research their reliability and performance level.
There are also many chemical pesticides available but you should buy only those that are specifically designed for yellow jackets. Although pesticides are quick and easy to use, they can also be harmful to pets, lawns, and people. Read the labels carefully, follow all recommendations and adhere to all warnings. If you use pesticides to kill yellow jackets wear protective clothing that is nonflammable. Launder them after using the pesticide and wash any part of your skin that has been exposed.
Yellow jackets can be safely exterminated if you follow the suggestions given in this article. Whatever method you choose, remember that with careful planning you will be able to eliminate these aggressive pests from your home and yard.
Sep 06, 2012 | Cars & Trucks
I have never had problems with my teeth.Now that I have quit smoking,and I also used Darvercet for a knee fracture Iam having trouble with my theeth cracking,..I had one crack and fall out.Now out of the...
no as we are not a medical or dental forum
talk with your dentist about the problem
however it ids probably connected to your smoking and dental hygiene procedures
Jul 18, 2017 | Cell Phones
I got a 1950 sewing machine set in a table with a knee control for the pedal. The light comes on, but I am not sure how to make the knee pedal work. There is a lever and I have moved it, but nothing...
Have you tried getting a copy of the owners manual? You can usually download one for $10 at www.sewingmanuals.com or go through Sears. I remember having a machine with a knee control and it seems to me that you only had to pick your stitch length and press the knee control to make it sew. Mine was a straight stitch only Singer. Do some research online with your model number, google it and see what you find. Good luck
Nov 10, 2010 | Kenmore Sewing Machines
STATEO-MAINE Mens Lounging Robe Vintage Smoking Jacket Dressing Gown Logo
98 people viewed this question
Top STATEO-MAINE Clothing Experts
treeeee
treeeee
shuyumeng
shuyumeng
Erin Wood
Erin Wood
Are you a STATEO-MAINE Clothing Expert? Answer questions, earn points and help others
