Question about Motorola Mobility S305 Bluetooth Headset
S305 not connecting
Red and green not flashing
Why does the battery flash from red to green while charging?
If it changes from red to green and stays green while being charged, it is just a sign that it is being charged and there is nothing wrong.
If it flashes back and forth between red and green while charging, there might be something wrong with your charger's connection.
Jan 26, 2014 | PANDIGITAL 7 Android with 2GB Internal...
Two red flashing lights on top and two green on bottom
Two red lights generally indicate hardware failure. Two green lights indicate two controllers are connected. Both green and red lights will not be lit at the same time. The green light in the middle indicates that the console is turned on. For more help deciphering red light flashing errors, see this guide HERE.
Feb 02, 2011 | Microsoft Xbox 360 Console
Red light, turn on, goes green, flashes yellow then flashes green
connection problems or power surge connect to surge protecter
May 01, 2010 | Sony Playstation 3 (PS3) Console
Ive got a toshiba 2455-s305 laptop that won't turn on. I've tried it using the power cord, with and without the battery, and when I plug it in it start's flashing in the front, but won't turn on.
Remove battery and disconnect power cord. Press power button for about 5-10 seconds (without battery and power cord) Connect power cord only then turn it on.
Dec 01, 2009 | Toshiba Satellite 2455-S305 Notebook
Battery light green, then flashes four times red, repeats
remove the battery
clean the connecting ends of ur laptop & battery,
plug it back in & then start it...
Aug 27, 2009 | Dell Latitude D600 Notebook
When connecting up to charge red light comes on 'power on' button on front and no charging happens - any ideas? thanks
What does indicator light mean?
  • Steady red light: Battery is charging.
  • Steady green light: Battery is fully charged.
  • Flashing red light: Battery needs charging.
  • Flashing green light: The music receiver is switched on.
  • Flashing red/green light: The music receiver is available to be added to your phone.
Aug 24, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
Kyocera fS-920KX. Not printing
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Sep 08, 2008 | Epson Stylus Photo 1280 InkJet Printer
Treo 680 charging light flashes red when disconnected from charger
Have you activated phone yet? When phone is activated and in service it flashes green. It's hard to believe it would flash green without a SIM card, as there is no service...unless AT&T is providing emergency service only and you're getting a flashing green which means you're in range of their towers.
Jun 14, 2008 | Palm Treo 650 Handheld
Motorola Mobility S305 Bluetooth Headset Logo
91 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
