Question about Monroe Ultimate Desktop Print- Display Calculator
Prints commas instead of decimals - Monroe Ultimate Desktop Print- Display Calculator
Define algebra:decimal
Decimal is the base-10 notational system for representing real numbers. The expression of a number using the decimal system is called its decimal expansion, examples of which include 1, 13, 2028, 12.1, and 3.14159.
Each of the arabic numerals 0 to 9 is called a decimal digit, and the period placed to the right of the units place in a decimal number is called the decimal point (or, in the case that a comma is instead used for this purpose, the decimal comma).
The decimal is a way of managing numbers that has ten as a starting point, or base. It is sometimes called the base ten or denary numeral system. The word "decimal" is also used instead of the word "period" to point out the dot that is sometimes used separates the positions of the numbers in this system. Almost everyone uses this nowadays and prefers the convenience of it probably because it shows up most often in calculations in nature and has "one" as another starting point for the system. The number one is usually the easiest to work with in calculations.
You may go to the link below for decimal tutorial:
http://www.algebra1help.com/flash/noflash/3.html
Jun 16, 2011 | Computers & Internet
My decimal changed to a comma, how do i change it back?
P12c display from Comma to Point This document describes how to change the display of the decimal point on the HP 12C (HP12C) Calculator from a comma (commas) back to a decimal point.
Instructions
  1. Turn off the calculator.
  2. Hold down the decimal point.
  3. Continue to hold the decimal point key, while turning on the calculator.
The comma should change back to a decimal point.
Explanation The comma is the European equivalent of the decimal point.
This procedure is also applicable to HP12CP (Hewlett-Packard 12c Platinum) and HP12CPA (Hewlett-Packard 12c Platinum 25th Anniversary Edition).
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 04, 2010 | HP 12c Calculator
I have a comma instead of a . how do I chage
Here is help from the calculator manual.
If you wish, you can set the calculator to display a comma for the decimal point and a dot for the three-digit separator. To do so, turn the calculator off, then press and hold down the [ . ] key while you press [ON]. Doing so again sets the calculator to use the original digit separators in the display.
Hope it helps.
Oct 12, 2009 | HP 12c Calculator
I just replaced the batteries in my HP 12C calculator and when I turned it back on the display looks like this 0,000. How do I get the display to show decimals instead of a comma?
Here is what the manual for the HP 12C Platimum financial calculator says on page 17 of 275
Digit Separators
As a number is keyed in, each group of three digits to the left of the decimal point is automatically separated in the display. When the calculator is first turned on after coming from the factory — or after Continuous Memory is reset — the decimal point in displayed numbers is a dot, and the separator between each group of three digits is a comma. If you wish, you can set the calculator to display a comma for the decimal point and a dot for the three-digit separator. To do so,
turn the calculator off, then press and hold down the [ . ] key while you press [ON] Doing so again sets the calculator to use the original digit separators in the display.
Hope it helps.
Oct 06, 2009 | HP 12c Calculator
There is a comma where the decimal point should be and vise versa.
From HP12c FAQ:
This document describes how to change the display of the decimal point on the HP 12C Calculator from a comma back to a decimal point. Instructions
The comma should change back to a decimal point. Explanation The comma is the European equivalent of the decimal point. *
For more information about your machine (data sheets, learning modules, manuals, FAQs, etc), check this link:
http://h10010.www1.hp.com/wwpc/us/en/sm/WF05a/215348-215348-64232-20036-215349-33525.html
Aug 08, 2009 | HP 12c Calculator
500 x 16 reads 8.000,0 instead of 8,000.00
The calculator has two digit-separation marks: The dot [.] and the comma [,].
By default the decimal (radix) mark is the dot, and the comma serves as a 3-digit separator. In European countries (especially France) the radix mark is the comma and the 3-digit separator is the dot.
To switch the marks:
  1. Turn calculator OFF
  2. Press and HOLD the [.] key while pressing [ON].
Apr 26, 2009 | HP 12c Calculator
Decimal point is replaced with comma
Check to see if the calculator is in European mode where the comma is sometimes used rather than the period.
Dan
Feb 20, 2009 | HP 33s Calculator
Hpochange decimal point
The following site solves both issues.
http://www.tvmcalcs.com/calculators/faq/hp10b_faq
Apr 24, 2008 | HP 17bII Calculator
Display a decimal point
Turn the calculator off, then press and hold down the .(decimal key) while you press the on button. Doing so again sets the calculator to use the original digit separators in the display
May 10, 2007 | HP 12c Calculator
Monroe Ultimate Desktop Print- Display Calculator Logo
Top Monroe Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Monroe Office Equipment and Supply Expert? Answer questions, earn points and help others
