Question about Canon C3380i Color Copier
CONFIGURAR BANDEJAS CANON IR 5055 - Canon C3380i Color Copier
  • 523 Answers
SOURCE: installing staples in a Canon imagerunner 5055
Open the finisher door and you will find the place, it is in the front side. Regards
Posted on Mar 02, 2009
  • 199 Answers
SOURCE: which one is better to buy IR 5075 or IR 5065
The all above models are same with minor change for speed
You need model as your daily output requirement
All models are heavy duty.
you can select any one for upto 10,000 print or copy per day or for 20,000 & up print/copy select ir 5075
Posted on Jun 15, 2009
  • 62 Answers
SOURCE: jam code 0211 in canon
Clean or replace roller after fusing unit.(heater) Slide out middle section>Lift green handle on left to expose rollers.
Posted on Sep 03, 2010
muleskinner2
  • 270 Answers
SOURCE: canon ir 5055 has an
This is a fixing error code - there is too much temperature difference detected by the thermistors. Mostly a error reset will take care of the problem. You have to get into service mode first. Press the additional function key, then press the 2 & 8 keys at the same time, then the additional function key again. Then copier, function, clear, err, then OK. This clears the error code from the copier. Then power cycle the copier and the copier should be operational. If this doesn't work then you will have to have a technician fix it. DO NOT keep resetting the code. There is something wrong with the copier that needs to be taken care before major damage is done to the copier. Good Luck
Posted on Dec 09, 2010
Cogz
  • 1326 Answers
SOURCE: The window on the canon ir 5055 says the waste
Basicly, the waste toner bottle is emptied out by your service person or if you work on it, then it is you. There is a counter that will display that it is nearly full. The counter will need to be rest and the waste toner has to be looked at and emptied if needs be. The waste toner & the cleaning web have about the same life / couter life. It is not a big deal..... I've never saw a waste toner bottle over file before, but if it is not looked at or checked it may cause some problem. Good Luck
Posted on Mar 30, 2011
IR 5065. Where is waste toner receptacle located?
You must empty the toner box and with soft clothes try to clean all the sensor window on used toner box and put it again.
Mar 03, 2016 | Canon Image Runner Toner Black...
I have error sc 00001-01 in my copier canon ir-5055
Check the connector of each thermistor,replace if neccesary.After fixing the problem reset the error in service mode:COPIER<FUNCTION<CLEAR <ERR,and turn machine OFF
Jan 14, 2015 | Canon Office Equipment & Supplies
Error 000400-0100 canon ir 5055
Call the cannon support team (877-690-9305) Help you to resolve the issue
Jan 01, 2014 | Canon CLC 1140 Copier
I have canon ir 5055. It has written RE INSERT UNIT 1. I cheked MIcro scwich next to the green arm.(it is good). I cheked two conectors on the UNIT 1's back and maschine's back. Is it passible the DC...
first check the lock lever green maybe if you pull up that lever to lock the metal who hit in the middle of the sensor is not hit by that metal or check the harness or wiring in front of unit 1 maybe the wire is loose connection if the same after you check those check the connector at the rear side of unit 1 maybe the gold pin connector is mis align
Dec 10, 2010 | Canon NP 6551 Black and White Copier
Jam code 0211 in ir 5055
try to clean all rollers and look for any sensor damadges.
... or call service!
Aug 18, 2010 | Canon imageRUNNER 5000 Copier
Jam code 0211 in canon ir 5055
Aug 18, 2010 | Canon ImageRUNNER 1670F Copier
Which one is better to buy IR 5075 or IR 5065
Jun 15, 2009 | Canon imageRUNNER 5000 Copier
Waste toner
to change the waste toner on your IR 5055, stand directly in front of machine and look on the right hand side of it where the power switch is a black button on right hand sdie at the back and you will see 4 screws and a metal plate that will come off the waste toner bottle is in there just empty it out and refit to machine all will work, now on your IRC3170 just undo front door and you will see a clear bottle just undo the black screw and take out the bottle and you will see a couple of little clear windows in the bottle make sure you take them out and clean them before you emtpy the bottle, this is where the machines shines a light through it to tell if the bottle is full or not so make sure you have them clean. refit the bottle and all will be ok
May 26, 2009 | Canon imageRUNNER C3170U Color Copier
Installing staples in a Canon imagerunner 5055
Feb 20, 2009 | Canon imageRUNNER 5000 Copier
Canon imageRunner 5055 copying in landscape instead of portrait
Double check paper orientation when you put paper into the feeder and how the paper is loaded.
The orientation of the page in the feeder and the page in the drawer should match.
Dec 16, 2008 | Canon imageRUNNER 5000 Copier
Canon C3380i Color Copier Logo
old marine
old marine
