Question about Pioneer DEH-P3500 CD Player
Usb on pioneer deh 3500 not working
I plugged my Blackberry into the usb port and it work for a while and then i got error-17 which when researched has to do with CD plaback. But now when i check the deck the option for USB isnt even there anymore. I tried resetting the deck by taking out the car battery, but to no avail. So if anyone can help it would be greatly appreciated :)
KaeZoo
  • 156 Answers
SOURCE: new pioneer deh-p4800mp doesn't work
How about the red (switched power) wire? The unit will not turn on unless you have 11+ volts on the yellow AND the red power leads.
Posted on Mar 15, 2007
  • 87 Answers
SOURCE: wire colours for my pioneer deh 2300
here are the wiring for the deck and the car:
Deck:
12v - red
ignition: yellow
blk - ground
orange - dimmer
white - frt left +
white /blk - frt left -
gray - frt right +
gray /blk - frt right -
green - left rear +
green /blk - left rear _
Purple - right rear +
Purple w/blk right rear -
Car:
2002 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger: Dark Green
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Posted on Jun 02, 2009
  • 7 Answers
SOURCE: Car Radio just stoped working.
My same model did this too. The wiring harness may have gone bad. Try direct wiring the stereo or replacing the wiring harness if you can get one. This fixed the problem for me.
Posted on Jun 28, 2009
  • 11 Answers
SOURCE: pioneer car cd player stuck on mute
You have to isolate yellow-black cabel. This cabel was in contact with earth and it was the reason, why you have Mute on the display.
Posted on Sep 14, 2009
SOURCE: My pioneer DEH-P6000UB doesnt read USB
I have a pioneer dehp-6000ub but there is not cord for the usb at the back,, what cord if any can I use to use a usb drive on it..
Posted on Jun 01, 2010
I have a pioneer deh-p6600 head unit and when I put a disk in it says error 17 and error 12 what does that mean?
Error codes 12 and 17 are for a dirty or scratched disc. First thing to try would be a different disc. If this does not work most higher-end pioneer head units have a software reset button which is not well marked but usually located behind the face plate and you can use a pen or a pin to push this. It needs to be held down for a few seconds and this will reset all of the settings to factory standard. This does mean that you will lose all saved radio stations, clock settings, audio settings etc. If it still wont play any discs after that it will likely need more detailed attention from a technician. Cheers, Dan
Apr 27, 2011 | Pioneer DEH-P6600 CD Player
I have a pioneer car radio and i am receving and error 12 message
I found the following information on Page 28 of the Pioneer manual for your DEH-P2900MP through the pioneer website:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/370967683DEHP2900MPOperationManual1027.pdf
ERROR-11, 12,
17, 30
Dirty disc Clean disc.
ERROR-11, 12,
17, 30
Scratched disc Replace disc.
ERROR-10, 11,
12, 15, 17, 30,
A0
Electrical or me-
chanical
Turn the ignition
ON and OFF, or
switch to a differ-
ent source, then
back to the CD
player.
I hope that helps
Jun 22, 2010 | Pioneer DEH-P2900MP CD Receiver...
My Pioneer car stereo recognizing the songs on my IPod 3G
I had this exact same problem. Here is how I just figured out how to fix it. First of all, my friend as an iTouch as well, so I plugged his iTouch into my DEH-P4000UB, similar to your 3100UB, and it actually worked and played music. So I went to my Music then selected a song and pressed pause. I turned on the car and then plugged the USB cable into my iTouch, exactly the same as yours. When I replugged my iTouch into my deck it gave me a different error this time, Error-19. Refreshing but still frustrating. So I turned off the car, unplugged the USB cable and tried it one more time. This time I selected "Repeat" on the song, don't ask me why, but this is exactly what I just did. I turned on the car, plugged the USB and it worked!!!
I understand your frustration and I've been dealing with it for a while now. So hopefully this helps. Good Luck!
Mar 09, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
How can i use an mp3 player with deh-3500
get the adapter for the mp3 player to use in the car and plug it right into the radio itself hope this helps u
Cheers
Johnthetr870
May 15, 2009 | Pioneer DEH-P3500 CD Player
Dec 28, 2008 | Pioneer DEH-P6000 CD Player
Pioneer DEH-50UB
Hi again,
Appreciate the direct "Ask Me".
Let's try a process of elimination based on:
  • the Pioneer DEH-50UB is working OK other than it displays error communicating with the iPod at certain times (intermittent);
  • the iPod when played alone/by itself does not exhibit any freezing/hanging problems;
  • the iPod to DEH-50UB connector/cable CD-IU50 is in good working order since if it is not, then the iPod would not even be heard on the Pioneer;
  • the Pioneer's wiring are OK otherwise it would not be working.
Which leaves us the possibilities of:
  • corroded/dirty USB port/interface on the Pioneer DEH-50UB;
  • loose USB port on the DEH-50UB;
  • loose or corroded terminals on the CD-IU50;
  • corroded/dirty contacts on the iPod;
  • RF interference from communications equipment such as CB radios, 2mtr Amateur, mobile phones;
  • electrical interference/noise from the vehicle such as horn relay, A/C relay, fan relay, alternator;
  • electronic noise from navigation/GPS mobile equipment;
  • keyless/remote alarm/security system.
Additional actions that could be explored/done:
  • installation of choke/filter capacitor along the red & yellow wiring of the DEH-50UB;
  • additional grounding/groundstrap of the DEH-50UB to the chassis/metal/body of the vehicle.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 12, 2008 | Car Audio & Video
Erroe 17
manual said electrical / mechanical. As it's to do with the CD it's probably mechanical. not a lot you could do, Probably the motor is jammed, lens needs cleaning something like that. Best think without opening it up. shoot some air down into the CD slot
Sep 12, 2008 | Pioneer DEH-P6800MP CD Player
How to hook up mp3
cant open the manual off pioneer.com i wanted to hook my ipod up does anyone know what the aux port is? for a pioneer deh-3500
Apr 22, 2008 | Pioneer DEH-P3500 CD Player
Pioneer DEH-P6900UB iPod Control
My suggestion is that the ipod-connector is bad. Try changing the ipod connector. If that doesn't work, unplug your Pioneer device for 24 hours, and then plug it back in. This will reset all the configuration options and should reset the devices that it recognizes. If that doesn't work, try calling Pioneer's support.
Nov 13, 2007 | Pioneer DEH-P6900UB CD Player
Pioneer DEH-P6900UB & Sandisk Sasa e280r
Did you format it while connected to a PC? If so check that you didn't format as NTFS, the Pioneer HU can only read FAT32 I think.
Sep 20, 2007 | Pioneer DEH-P6900UB CD Player
Pioneer DEH-P3500 CD Player Logo
21 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
