Question about Canon LASER SHOT LBP-1210
My printer says " check toner cartridge". what could be the problem ?
Yesterday it was print with dirty print out today while I start printing it shows above problem
  • 3 Answers
SOURCE: Canon MP500 Printing Problem
I had same problem today. Removed print head and bathed it in alcohol for half an hour. Then I removed the two screws underneath and used a syringe to squirt alcohol into the ports and clean. I noticed clumps of ink coming out (i guess some ports were blocked). I then dried the head and reinserted and reinstalled ink tanks. All looks good so far- black printing again and printed test patterns all look correct. Good luck.
Posted on Jan 15, 2008
sitehr
  • 94 Answers
SOURCE: D880 printer won't put toner on the paper (prints blank)
make sure the replaced toner is in good condition and is placed properly in printer refilled toner often alarm about low ink but work properly
Posted on Jul 22, 2009
cene765
  • 787 Answers
SOURCE: canon mx318 u051
Try to press and hold the resume button for 5 seconds.If this not help you need to replace the ink cartridges.
Posted on Oct 26, 2009
cene765
  • 787 Answers
SOURCE: my canon pixma 180 has orange alarm light and
One or both print cartridges are defective.Look under the "check ink" what message come.If it's BLK change black cartridge, if it's CLR change the color cartridge.If BLK and CLR change both cartridges.
Posted on Nov 06, 2009
SOURCE: Printer not responding
I had the same problem after I accidentally pulled the power cord out of the printer - it turned out to be the firewall on my PC, when the printer reconnected to the wireless network it got a new IP address and the firewall was blocking incoming messages from it.
Posted on Feb 10, 2010
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Ricoh Aficio SP3510SF Toner Change Problem
Step 1:
Good day...
Before we start first make sure the machine is turn-off for our safety process.
Question: 1. Did you try to change the other toner cartridge?
Step 2:
Possible cause and way to check Toner Change Problem & No more Printing:
- Dirty Sensor (check all the sensor)
- Dirty Glass (check all the glass)
- The cartridge is not properly installed
- Full Waste Toner section
- The corona wire is dirty or broken (Inside the cartridge)
- The transfer Unit is dirty or broken (Inside the cartridge)
- Broken gear motor connected into the drum section
- If they have developer include in this model try to check it and
repalce if empty
- Broken Fuser Film
- Broken Fuser Lamp
- Broken or dirty Cleaning Blade Section
- Check if they have also chips include in the cartridge
Step 3:
Check all the possible cause and try to clean or replace the parts if broken.
Let us know if the problem is solve.
Sorry for my english
thanks
Feb 19, 2013 | Ricoh Office Equipment & Supplies
HP 4P band of grey on left side of the printed page. What should be done? change toner?
hi
very simple
Use the following troubleshooting steps to resolve this issue:
  1. The print cartridge is almost empty. Shake the cartridge gently to redistribute the toner, or replace the print cartridge.
  2. The print cartridge may be damaged. Replace the print cartridge.
  3. The printer's internal mirror may be dirty. Lift the print cartridge access cover, remove the brush from the underside of the cover, and clean off the mirror using the brush.
  4. use p/n 92274A for toner replacement
please issue 4 thumbs up
thanks for using FIXYA
Apr 05, 2011 | HP LaserJet 4p Printer
It says toner life end and it prints just fine
The toner life end message means the toner is getting low. It will continue to print without any problem. Eventually you will see the print starting to get light in spots. If it is a new cartridge, the toner level sensors are probably dirty.
Oct 08, 2009 | Brother MFC 7420 All-In-One Laser Printer
I have a C3530 MFP and it won't print because it says check toner cartridge black. Toner Sensor Error
Hi
Thanks for using FixYa. Toner sensor error is related to the agitator inside the toner cartridge, it occasionally falls out of its housing so it does not move the toner sensor which is the white plastic piece that moves up and down on the coloured handle, the toner sensors themselves see this white flag if it doesn’t move then the printer thinks the sensor is broken so toner sensor error is flagged and if the flag moves too quickly the machine thinks the toner is empty. To resolve the issue your printer is facing with please check that toner lock lever is in position and follow the following procedure---
Press the cover release and open the printer’s top cover fully. Make sure the Toner Cartridge in question is correctly positioned and the right hand clip is pushed back. While holding it by its top centre, lift the image drum, complete with its toner cartridge, up and out of the printer. On the Right hand side of the toner look for a sensor patch, make sure this is not dirty. If it is dirty clean it with a soft object such as cotton wool. Now look inside the printer opposite to where the sensor patch would sit. There is a black square with a sensor located inside and check that this is not dirty. Now replace the drum and toner, and close the printer cover. Try to print a test page and it will start printing normally.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 30, 2009 | OKI C3530N Color MFP Printer
T632 lexmark getting dirt on printed pages
Hi Krimlakh,
Try replacing the toner cartridge first. Usually when this happens the waste hopper of the toner cartridge is full and start to leak on to the page.
Rgds
S88
Dec 18, 2008 | Lexmark T632 Laser Printer
Dirty printing
The cause of this is a faulty toner cartridge. What happened was some toner spilled out of the cartridge and down into your printer. Take the toner cartridge out and with a damp paper towel just goto town and wipe everything down.
Replace the toner cartridge, and in about 20 pages it should clear up.
Aug 18, 2008 | Samsung ML1740 Laser Printer
Dirty Copies
clean the ink box from printer where the cartidge park
Mar 20, 2008 | HP LaserJet 1012 Printer
Printer is printing black line
Dirty Primary Charge roller. Change the Toner Cartridge.
Bad Toner Cartridge. Replace the Toner Cartridge.
Mar 07, 2008 | HP LaserJet 4 plus Printer
Computers & Internet Logo
48 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
