Question about Nokia Cell Phones
Nokia browser 113 does not ring when someone calls
Bought a new phone yesterday but cannot get it to ring when someone calls it is a nokia 113
  • 14 Answers
SOURCE: can't hear phone ringing
There are many reasons for this to occur, first select a profile and set the ringer to an audible tone and adjust the volume to a lever you can hear clearly. To do this first try pressing the silver button on the left side when the main screen is facing you(Open phone) and if you look closely you'll notice one button on the side has a top and a bottom half the top increases the volume and the bottom decreases the volume. If the volume it up all the way and you still hear nothing then press the menu button and go to settings, followed by going to sounds and select the profile "normal" and adjust as necessary to make your ringer alert you, if the tone is not heard try a different one, if all else fails remove the battery and leave it out for two minutes, then put it back in and turn your phone back on. This sometimes is necessay to make a newer phone clear a "bug" as newer phones are much like MS Windows and require a re-boot from time to time. I hope this helps...
Posted on Nov 22, 2007
vrabhilash
  • 52 Answers
SOURCE: my phone is not ringing on incoming calls
did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from oter phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
Posted on Jul 17, 2008
SOURCE: Nokia 5300 xpress music mobile phone won't ring
1.mmmdeaaaa but my when i put it on silence ont to vibrate only apears that someone call!!!!
2.And The music player doesnt Work!!!!!!
plzzzz help ME!!!!! when i started the player apear that he didnt find The music!!!!! plz email me if you now ho w to fix that!!!!!my phone is a 5300 grean!!!!
Posted on Oct 21, 2008
  • 8 Answers
SOURCE: When someone texts or calls me my phone vibrates instead of ring
You probably have silent mode on. Try pressing and holding the pound or the star key. One of those will probably release silent mode, so that whatever ring setting you have can be used.
Posted on Nov 10, 2009
SOURCE: Problem with Nokia 6300 - Can't hear anything
You need to changed,Your mouth piece, and you earpiece.
As for your ringer, it can be changed,but sometimes the problems always from the panel of the phone,and when it's from there, and ones is from there,it's damaged.
For your mouth piece and your earpiece it will workafter changing it.
Posted on Jan 20, 2010
Nokia113
is there someone in your country to unlock phone you need a special program but you cannot get it on internet
Mar 31, 2014 | Nokia 113 Black Mobile Phone - Unlocked 64...
I have Nokia 1661-A and model: 1661-2b. When
I had the same problem with mine. when I would go to tone settings every time I tried to hit ring tone it would turn off the phone and restart, by the way in ring tone it was blank. No matter what I did it wouldn't work. So I went to settings then restore factory settings entered the code. It reset the factory settings, then when I went back to tone settings the ring tone said Nokia Tune so I hit enter and it gave a list of all other ring tones, then it worked so my phone finally rings.... Hope it works for you.
Mar 23, 2010 | Nokia 1661 Cell Phone
We just bought a new Uniden phone yesterday. When
You need to adjust the setting that determines how many rings before the phone automatically answers and plays the pre-recorded outgoing message. Instructions will be in the manual, but if you want me to help further please include the model number here as an additional comment.
Feb 23, 2010 | Uniden Cordless Phone EXAI985
Panasonic phone rings but line is silent and can't make calls
Tossed out the phone and bought a new much better Uniden. All works great now.
Aug 28, 2009 | Panasonic Lands Phones
Phone will not ring
please check the call settings of the phone
Go to main menu>> settings>> calling check here if ther is any restriction for any number. ideally there shouldn't be any problem
Mar 26, 2009 | Nokia 5800 XpressMusic Smartphone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
Nokia 6800 won't ring
go to profiles settings, then select GENERAL........
sexy-ym
Sep 04, 2008 | Cell Phones
Caller ID on the Nokia 6500 classic
i had to ring network provider (orange), the sim needed updating- apparently common with 6500 and this prob.- i had the same problem and is sorted now
Apr 04, 2008 | Lands Phones
Adjust ringer length Nokia 7250
Hi the only way you can make the phone ring longer is to goto settings scroll down to call select call then select call divert then select cancel all diverts after you have dont this then select divert if busy turn this on then divert if out of reach turn this on the select divert if not available now leave them like that then when your phone is switched on it wont goto answer unless your on phone to someone else or you hang up on someone.
With the settings like that it will goto answer phone if phone is off or if you have no signal or if you are on phone to someone else but now your phone will ring for aslong as someone rings you for.
Let me know if you need further assistance
Jan 15, 2008 | Nokia 7250i
Cell Phones Logo
16 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
