Question about Android Apps
Who is 7424c549@plus.click - Android Apps
HL-DT-ST DVDRAM GH20NS10 is not reading any disc.
1. Click Start -> Run (for XP) or Start Search (Vista) or search for programs and files (Windows 7)
2. Type Regedit
3. Click on the plus sign beside HKEY_LOCAL_MACHINE
4. Click on the plus sign beside SYSTEM
5. Click on the plus sign beside CurrentControlSet
6. Click on the plus sign beside Control
7. Click on the plus sign beside Class
8. Under Class Click on the Folder {4D36E965-E325- ....} (note that the alpha numeric numbers are quite similar we only need ....65)
9. Look for UpperFilters and Delete it
10. Look for LowerFilters and Delete It
11. Restart the computer
Jun 04, 2011 | Computers & Internet
Tip
Deleting upper and lower filters
This procedure is to be used as last resort. This is for software issues dealing with the CD-ROM or DVD-ROM drive.This procedure can fix an issue on not being able to see the DVD drivel.
Follow these steps
  1. Click on Start (Windows Logo)
  2. Click on Run
  3. Type in REGEDIT
  4. Click on OK
  5. Click on the plus sign (+) next to HKEY_LOCAL_MACHINE
  6. Click on the plus sign (+) next to SYSTEM
  7. Click on the plus sign (+) next to CurrentControlSet
  8. Click on the plus sign (+) next to Control
  9. Click on the plus sign (+) next to Class
  10. Click on the plus sign (+) next to {4D36E965-E325-11CE-BFG1-08002BE10318}
  11. On the right pane, click to highlight Upperfilters
  12. Right click on Upperfilters
  13. Click on Delete
  14. Click on OK
  15. On the right pane, click to highlight Lowerfilters
  16. Right click on Lowerfilters
  17. Click on Delete
  18. Click on OK
  19. Close the Registry Editor
  20. Reboot the computer
on Feb 23, 2011 | Computers & Internet
Laptop HP NC6230 . My CD-ROM have problems , can not issue on list disk ....i restart Laptop then sometime CD_ROM issue but using sudden cd-rom can not see ...i dont understand . can you help me...
Removing Upper and Lower Filters on registry normally fix problems with CD-Rom Not detected under My Computer
*note do this at your own risk, messing up with the registry might mess up the system. Please follow instruction accordingly. :)
  1. Click on Start
  2. Click on Run
  3. Type in REGEDIT
  4. Click on OK
  13. Click on Delete
  14. Click on OK
  17. Click on Delete
  18. Click on OK
May 10, 2011 | HP Compaq nc6230 Notebook
Mydvd drives not work
1. Go to start, run, type regedit, click ok.
2. Back up your registry before making any changes:
Click on file, export, type reg backup as file name and save it wherever you want. (If something goes wrong after doing the next steps, just open this backup and it will restore everything back).
3. Click on the plus sign next to HKEY_LOCAL_MACHINE
4. Click on the plus sign next to SYSTEM
5. Click on the plus sign next to CurrentControlSet
6. Click on the plus sign next to Control
7. Click on the plus sign next to Class
8. Click on the plus sign next to {4D36E965-E325-11CE-BFG1-08002BE10318}
9. On the right pane, click to highlight Upperfilters
10. Right click on Upperfilters
11. Click on Delete
12. Click on OK
13. On the right pane, click to highlight Lowerfilters
14. Right click on Lowerfilters
15. Click on Delete
16. Click on OK
17. Close the Registry Editor
18. Reboot the computer
Apr 04, 2011 | Samsung SH-S222A/BSBF DVDRW Drive - DVD+R...
Driver missing - device wont work DDU1613
if you tried to reinstall the drivers already do this step:
ollow these steps
  1. Click on Start
  2. Click on Run
  3. Type in REGEDIT
  4. Click on OK
  13. Click on Delete
  14. Click on OK
  17. Click on Delete
  18. Click on OK
Mar 23, 2011 | Sony DDU1613 16X DVD-ROM Drive, Black...
My dvd drive did not detect cd's and dvd's
try to delete upper and lower filters,,,
Follow these steps
  1. Click on Start
  2. Click on Run
  3. Type in REGEDIT
  4. Click on OK
  13. Click on Delete
  14. Click on OK
  17. Click on Delete
  18. Click on OK
Jul 04, 2010 | Samsung SH-S202J 20x DVD?±RW DL IDE Drive ...
If i put any cd or dvd in my computer it will not play. the cd or the dvd will not even turn in d computer i dont know why pls help me
Follow these steps
  1. Click on Start
  2. Click on Run
  3. Type in REGEDIT
  4. Click on OK
  13. Click on Delete
  14. Click on OK
  17. Click on Delete
  18. Click on OK
Jun 28, 2010 | Adobe Flash® CS3 Professional Full Version...
DVDdrives repeat message: insert disk,while disks are in. any answers?
This procedure is to be used as last resort. This is for software issues dealing with the CD-ROM or DVD-ROM drive. This procedure is designed to fix issues after removing Roxio Easy CD Creator but it may help other issues also. This procedure can fix an issue but can also cause issues, so don't use it till last resort before doing a re-install.
Follow these steps
  1. Click on Start
  2. Click on Run
  3. Type in REGEDIT
  4. Click on OK
  13. Click on Delete
  14. Click on OK
  17. Click on Delete
  18. Click on OK
Jun 15, 2010 | Computers & Internet
I have a Gateway model M-6881 with a Sony AD-7563A optical drive. When a dvd or any disc is inserted it does not auto play and when I open up my computer and double click on D: drive I get an error message...
Follow these steps
  1. Click on Start
  2. Click on Run
  3. Type in REGEDIT
  4. Click on OK
  13. Click on Delete
  14. Click on OK
  17. Click on Delete
  18. Click on OK
May 21, 2010 | Gateway (5500652) (  5500652)...
My computer will not read a c d or dvd
Follow these steps
  1. Click on Start
  2. Click on Run
  3. Type in REGEDIT
  4. Click on OK
  13. Click on Delete
  14. Click on OK
  17. Click on Delete
  18. Click on OK
Dec 13, 2009 | Toshiba (WMD070AC) Magneto-Optical Disk...
Android Apps Logo
743 people viewed this question
Top Apps Experts
Are you an App Expert? Answer questions, earn points and help others
