Question about Umax Avision AV220
Avision error 2023 - Umax Avision AV220
Tip
Bush DVD-2023 Region Free Fix Would you like to unlock your Bush...
Would you like to unlock your Bush DVD-2023 to Region Free?
Follow these steps to unlock your Bush DVD-2023:
  1. Press the Open button on your remote control
  2. Using your remote control, press 2, 8, 1, then 2
  3. Press the Close button on your remote control
Your Bush DVD-2023 is now Region Free.
I hope that helps.
on Apr 25, 2010 | Televison & Video
Error code (E8)
Error E08 In Avision AV 121, what's wrong with that?
Aug 11, 2011 | Avision AV220 Pass-Through Scanner
Avision AV8350??? the error led is on, first time the led on & off For 8 number Sequence. then on for ever.
When you first turn the scanner back on, the READY light will blink, indicating that the diagnostics are in progress. If the Ready LED and Paper Jam LED blink 8 times, the error indication is "Light Check Fail (ADF)" or "Flatbed /ADF inverter check error".
Followings are the solution for the above problem:
1. Lamp is on? Yes. CCD error, Optical assembly is to be replaced.
2. Lamp is on? No. Flatbed or ADF Inverter error. Lamp inverter circuit is to be replaced.
3. Lamp is on? Yes. Issue resolved.
4. If the Lamp is still off, then Lamp is to be replaced.
5. If the issue still persists, then you may have to contact the authorized Avision Service personnel for further diagnosis and suggested repair or replacement.
Hope the above information is helpful.
Please revert if you have any doubt.
Thank you for contacting FixYa.
Regards,
TechSatya
Jan 16, 2010 | Avision AV 8350 Flatbed Scanner
Once i powered the avision 220 on, The moniter shows E and 7
When you first turn the scanner on, the READY light will blink, indicating that the diagnostics are in progress. Observe
the front panel Error LED (Red) closely. In a short time, the Error LED indicates the results of the offline diagnostics as
explained below.
Ready LED(Green) is off and Error LED(Red) indicates 7, the error indication is"Face down light check failure".
1. CCFL is on? Yes. CCD error, Optical assembly is to be replaced.
2. CCFL is on? No. Inverter error. Lamp inverter circuit is to be replaced.
3. CCFL is on? Yes. Issue resolved.
4. If the CCFL is still off, then CCFL is to be replaced.
Regards,
TechSatya
Nov 01, 2009 | Ambir Technology Avision 220 Pass-Through...
Lost my Driver and software CD for my scanner AV220c2, pls let me know from where to download
you can download the driver from www.avision.com. I dont know where to download the tool (avscan or svcapture).
Mar 27, 2009 | Umax Avision AV220
Please tell me where is available Avision AV830C Plus 30ppm Color Simplex 8.5x14" ADF/Flatbed in india (mumbai)
Dear Mr. Sanjay,
The Avision AV830C Plus scanner is available with the following company:
ADi e-logic
HIG-1, Rajiv Nagar, Aiginia
Bhubaneswar
Email:adi.elogic@gmail.com
Contact No: 919853339333
Regards,
TechSatya
Feb 19, 2009 | Avision AV 3200 C Flatbed Scanner
Can't read many of my emails as they come out with 'text encoding', so I get a page with garbage letters in it, and I do not know with what program to reopen the download. ppt & Jpeg open, otherwise, just...
�����ߧ��اէ֧� �����ӧ������ڧ�������, �ߧڧ��֧ԧ� �ߧ� �����ߧ���! �� ���֧��֧��ڧ��ѧ� ���ӧ��� ���ڧ����ާ� 100 ���ѧ�, �ӧߧڧާѧ��֧ݧ��ߧ� �ڧ٧����ѧ�, �ܧѧاէ��� �����ѧ٧� �� �ߧڧ��֧ԧ� �ߧ� �����ߧ���. �� ���ק� ���� �ԧ��ӧ����ڧ���? ���ѧܧ��� ������ �ާ��� ���ܧ����ا֧ߧڧ�? ���ѧܧ��� ������ ���ӧ��� ���ܧ����ا֧ߧڧ�? ���ѧ٧ӧ� �� �ߧѧ� �� �����ҧ��� �ߧ�
Jul 07, 2008 | Brother MFC 210C All-In-One InkJet Printer
Avision AV830c plus scnaner paper jam error
Hi, Can you provide the detailed description of the issue? Is there any on screen error message or panel error code? regards, TechSatya
Mar 08, 2008 | Avision AV 3200 C Flatbed Scanner
Umax Avision AV220 Logo
423 people viewed this question
Top Umax Office Equipment & Supplies Experts
Tony
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
