LG735T sound goes out of sync after 8 - 10 minutes
To get the sync back you either turn the unit off and on or go out of input and back again. It is playing through an analogue tv. No other model of dvd player has done this with this tv. We have Panasonic and LG dvd and Blueray.
Danmart
  • 291 Answers
SOURCE: Panasonic DVD-LS855 wont play to LCD TV
Did you turn on the input of the tv to receive 'external' input.? Did you plug the DVD into the right input?
Posted on Nov 07, 2008
notsomot
  • 67 Answers
SOURCE: blueray player bdp1500--won't play disc it should play??
Hmmm, thats annoying and you say that you have tried this as two differenct discs, you can region free your dvd player here
http://www.videohelp.com/dvdhacks/samsung-bd-p1500/9441
See if that helps, other than that mate I am lost to why it will not play the disc. Does it have any scratches?
Posted on Jan 11, 2009
SOURCE: Panasonic dvd/vcr DMR-EZ47V model.Code OOOOOO keeps going across.
You must manually hold in the on/off button on the machine itself (NOT on the remote) for approximately 30 seconds. This will shut the unit off. Then you can restart it.
Posted on Feb 26, 2009
SOURCE: I cant play DVDs on my Lg DVD player
See my workaround at http://www.fixya.com/support/t622687-unknown_disc_please_check_disc_again
Posted on Jul 10, 2009
SOURCE: LG DB370 Blue Ray player DVD Compatibility problem
Visit the LG website and download the latest software for this product. That solves the problem.
Posted on Nov 04, 2010
Hyundai monitor on for 5 minutes and screen goes black
Have you ever opened up the monitor to clean the dust out,it could be your heating up and then letting it sit will bring it back.If your unsure how to do this ask a tech.
Apr 21, 2017 | Hyundai X224W
3 beeper beeped at 300. The beepers beep @8,10,and 12 minutes respectively. What time will the beep at the same time again.
If the beeper beeped at 300 then it will beep at the Lowest Common Denominator. The LCD for 8, 10, and 12 is 120. So add that 120 to 300 and you end up at 420. The Beepers will next Beep at 420.
Feb 28, 2011 | Computers & Internet
Problem with the Denon AVR-4802 7.1 Channels Receiver Denon avr-4802 h/p input issues. Ads by Google Custom Cable Installation www.consolidateddatacom.com/Network and Data Cabling for your business....
you need to find a headphones, put a drop of contact cleaner on headphone plug and plug it into receiver's h/p input several times. It cleanes internal h/p connector contacts and unit will work fine. If doen't help the receiver most likely has bad h/p connector soldering.
Jan 20, 2011 | Denon AVR-4802 Receiver
When I turn my hitachi flat screen tv on,
you are not getting a signal change soure ie box or dvd player and input jack then try
Jul 26, 2010 | Hitachi 32HDT20 32 in. Plasma Television
Unit keeps turning off
I had the same problem with my unit (The Harmon Kardon Play & Go was turning off after 10 minutes. It was very frustrating.). It ended up that my auxiliary input jack was not plugged in all the way, and only one channel was being played. Apparently, the unit detects whether or not sound is being played, and it turns off after a certain amount of time if no sound is detected. Also, apparently, that detection circuitry is only on one channel -- not both. So if you don't have the input wire plugged in all the way, the unit does not detect sound properly.
To solve the problem, make sure that the input wire is plugged in ALL the way. :)
Other than this little issue, this unit is fantastic! Highly recommended.
~Christopher Sebastian, Phoenix Arizona.
Aug 14, 2009 | Harman Kardon Go + Play Portable Speaker...
Solid red light - Don't search to sync after new drivers and firmware update.
20 minutes after posting the same problem.... I figured it out, ahah... So one case is that you turned off your unit before the firmware update was ready (caused internal damage to your unit) so you might have to send it back. However, what I did was I uninstalled the firestudio cd/driver w/e the heck it is that came with it and then installed it again. That way the universal driver deals with the software for the firestudio the way it should. After doing that and restarting it, simply turn on your unit and it should be red for a few seconds (i thought i was still screwed) but then it turnes blue and syncs... so try that... i might just work.
May 17, 2009 | PreSonus FIREPOD (673454000539) Audio...
Sound lost
I don't know if this will solve your problem, but I have a question.  Does the receiver sit under another piece of hardware?  Especially one that gives off a lot of heat?  It is possible that the amp or power supply is overheating.  The heat forces the receiver off until it has a chance to cool down.  Then when it turns back on, it starts to generate heat again.  Try moving it out from under any other gear or out from under a shelf so that lots of air can get in the top.  Maybe even try putting a fan over it, just as a test to see if this helps.  I work at a recording studio in Toronto, and we were having the same problem with one of our digital multitrack tape machines (No the studio is not trapped 10 years in the past - we just use tape for backing up and client delivery).  Anyway, early in the day, the unit worked fine.  If we tried to use it later in the day, we would get glitches all over the tape, or the transport would freeze up altogether.  We found that when we moved the unit into a rack where it could really breath, and where it wasn't right under an 8 channel mic pre-amp, that it worked without any problem.  I hope this helps.  Good Luck!
Sep 03, 2008 | Sony STR-DE975 Receiver
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Surround help
Hmm. let me see if I get U correctly. you use u'r theater system with a TV and the audio is fed via optical or U have DVD player that you can feed the audio via optical or coax. I think it is the later, if it is U could be having trouble with sound decoding setting of the DVD player itself. It's like mpeg out or PCM out instead of full DTS or 5.1 dolby digital decoding. If this is the case just use u'r dvd remote and check the audio play back settings. If this does not solve u'r problem, pls state u'r set up briefly, so tht I can understand the type of connection u use. Happy troubleshooting Rifaa
Jun 11, 2007 | RCA RT2390 System
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
