Question about Cooktops
Siemens er 22 error - Cooktops
How do i unlock chidproof lock on my siemens induction hob
By holding down the key symbol for a period of 5 secs to remove lock
Oct 30, 2016 | Siemens Cooktops
When turning a knob on my Siemens cooktop, a blinking "0" appears, and a red lock sign shows.I pressed the lock sign for min 5 sec but it stays on. How doi turn the lock off in order to use the stove?
Hi,maybe if you have not tried it already,maybe switch it off at the mains and swich it back on it may reset its self,hope it works for you.
Aug 16, 2016 | Siemens Cooktops
Error code er22 is showing, any ideas?
Google search your manufacturer make and model and the words error code 22. You can find your answer in the search results.
May 02, 2015 | Cooktops
How do you clear er
Hi friend, thank you for your inquiry!
I understand that you are receiving an "ER" error code on your Frigidaire range and you want to clear the code. "ER" stands for error, I would recommend performing a reset which can be done by flipping the household circuit breaker for roughly ten minutes. That should clear any false error codes. If you continue to receive an "ER" or any different codes please provide that feedback. I hope this helps. -Matt
Aug 23, 2014 | Frigidaire Stove / Oven / Range Cooktop...
NET7452UC Electric Cooktop shows errors 26 and 42. What do they mean?
Problem: Error codes 26 or 42 after turning on too many heating elements.
Potential issue: Damaged main electronic board
Specific case: Error code 42 after turning on more than 3 elements, then already after 2, 1 until none of the cooking element could be turned on, over a period of a few weeks.
Root cause: Dying/blown electrolytic capacitor on the main electronics board.
Solution:
1) Turn off power (circuit breaker) - caution high voltage inside the cooktop
2) Lift the cooktop out of the hole in the countertop and slide it on a flat surface
3) Remove all screws around the metal housing using a torx screwdriver
4) Carefully tilt the glass top out of the housing on the front, noting that there are electrical connections in the rear, and place the rear end of the glass on a stable surface. You may need someone's assistance here.
5) After double-checking that there is no power, record the color coding of the four wires connected to the glass assembly (green for ground, white, black, red from left to right)
6) Next open the black plastic cover by removing four Torx screws.
7) Carefully remove from the connector on the left the the plastic strip connecting to the display board.
8) Carefully remove the circuit board with relays and capacitors that is held in place by plastic tabs.
9) If one of the capacitors is bulging out or showing sings of damage on top, replacing it may fix the appliance. De-soldering a bad capacitor requires some tools and skill. Replace the capacitor with at least the same capacity, voltage and use high-temp. 105C version) Alternatively, instead of replacing a $2 component you will have to replace the entire board.
10) Reassemble and done.
May 04, 2012 | Bosch 30 in. NET7452UC Electric Cooktop
The oven was on at 350 degrees. All of a sudden the oven increased the temperature and displayed ER F2 error on the display. What was in the overn was instantly burnt.
If you have a Kenmore or Dacor, Thermador, Amana Caloric, Westinghouse, Admirals, or if you have some retagged oven from this brands, F2 is temperature runaway, usually a bad temperature probe.
On Admirals you may need to test the relay board.
Try disconnecting power (trip circuit breaker or disconnect power cord).
If the error is still there, test if the probe has continuity, then eventually replace it.
On Whirlpool ovens F2 is a faulty keypad assembly.
To get a technician to do the repair call the support number listed on the manual.
Dec 15, 2009 | Cooktops
T1683 .. Er 22 after power on, any suggestions ? Anyone know startup sequence & operation of temperature limiter.
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jun 06, 2009 | Neff 32 in. T1683SS Electric Cooktop
Siemens glass stove top - locked mode
you have to hold the powerbutton for a few seconds, and the children security lock should come off
Sep 18, 2008 | Siemens 32 in. EH78754EU Electric Cooktop
Cooktops Logo
126 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
