Question about Candy 11 cu. ft. / 311 liter Chest Freezer CC330
Green light not working on front lower panel of candy chest freezer
I have a Skandiluxe CF 136 chest freezer & the orange (fast freeze) light is on all the time.
The compressor won't burn out just because it's running all the time. The plastic fascia pops out easily from behind(take the little panel off on the side) Set the thermostat to the middle of its range and switch the fast freeze off.
Oct 08, 2015 | Freezers
My chest freezer bush cf143gb works ok but the green light does not show it is
Good day James.
There must be a loose cable for the green light to come on. Your thermostat might need replacement especially if doesn't go on defost which happens automatically.
Feb 12, 2014 | Bush BSCF145 Chest Freezer
Magic Chef Chest Freezer MCCF5WBX is not getting power, green light not on
Check your outlet with something else that will work, like a radio. If the green light does not come on, then check the wiring. The green light should be on even if the freezer has reached it's temperature. That is simply a light to indicate that power is at the receptacle.
Jan 27, 2013 | Magic Chef Chest Freezer MCCF5WBX
5 foot chest freezer by HOLIDAY, green light on bottom front not lit,less than one year old
I have the same issue, the green light on the bottom is not lit. Looked in manual and do not see anything about that. Freezer is working otherwise, everything frozen like it should be.
Apr 11, 2012 | Freezers
The green light on the front indicator panel is not working, although the ppliance is operating normally. Is the lamp replaceable, and how do I get to it? Does the front indicator panel open, and how?...
to be honest the price would not be worth the cost. but yes you can replace bulb. all you have to do is click it off. but do get in touch with manifactors Manual for blub size and info.
Oct 29, 2009 | Zanussi 14.62 cu. ft. / 414 liter Chest...
GE 5CF CHEST FREEZER
I got delivery today for the same freezer and had the same question.
I just called GE's customer service number (800-626-2005) and the agent told me that GE uses this button panel (which has the green on/off light switch, the two white switches, and the round control dial) for all or most of its freezers. But the buttons do not do anything on the 5 cubic foot chest freezer. They are not connected to anything and are non-active buttons. On other freezer models above this one, the two switches serve a purpose, but not the 5CF model. This is a simple, inexpensive freezer and it doesn't have bells and whistles--but it does have the same control panel as the multi-feature freezers. Hope that helps.
Sep 05, 2009 | GE 5 cu. ft. / 142 liter Chest Freezer...
I have a GE chest freezer and the exterior green light has started flashing. The freezer is less than a year old.
Is this just a "Power-on" light to let you know it's plugged in and has power? This is probably just a "neon" (although the actual gas inside is hydrogen for the green color) bulb and sometimes they will do the flickering thing literally forever. In a way it's a good thing as it makes you look at it. If it really concerns you, or if it is actually a warning that something is going wrong (it should say in the manual, you DO have the manual don't you?) have it fixed under the warranty.
Jul 07, 2009 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Apr 30, 2009 | Zanussi 5.76 cu. ft. / 163 liter Chest...
Green light on the front
Your problem is more than likely in the light itself. The green light is the indicator that the temperature is in acceptable range.
May 15, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Green light
could be a possible short in the electrical
Jan 19, 2008 | Danby 5.5 cu. ft. / 156 liter Chest...
Candy 11 cu. ft. / 311 liter Chest Freezer CC330 Logo
41 people viewed this question
Top Candy Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Candy Freezer Expert? Answer questions, earn points and help others
