Question about Acer Televison & Video
Westing house tv vr3235 how do i get back to wizard tuner setup
Westing House LD-3235 will not scan
It could be the tuner but you have a few options.
First is unplug the set and or a cable or sat box and wait a while. Plug back in to see if set/box will reboot.
Another option if you have or get a Box is get one with the audio/video output jacks on the back and connect it to the same type on the rear of your set-----Bypass the tuner and operate via that input changing channels on the box.
May 27, 2012 | Westinghouse LD-3235 32in LED 720p Flat...
My Brand New 40" westing
To get HD channel form your cable TV without using the cable provider HD tuner box but using your TV Clear QAM tuner (your TV has Clear QAM tuner, my TV also has QAM tuner so I do not have to use the cabel box, but my COMCAST does not provide may Clear QAM signals like they use to) to get the unscrambled HD, the cable provider must provide those unscrambled Clear QAMsignals for your TV to pick up the signalS.
Learn more about Clear QAM cable signals:
http://en.wikipedia.org/wiki/QAM_(television)
Did you use the correct setup during the tuner setup to scan the availabel cable channel per user manual?
Dec 30, 2010 | Westinghouse SK-40H520S 40 in. LCD TV
Is there a way to reset a westing house flat panel tv? It is frozen
call sears they charge $99 to come out free estimate. mine cost $300 to fix, get your estimate and go from there good luck
Dec 19, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
I need driver for saa7130 tv card
This particular device is tricky as Philips does not have drivers on their website, however there is a way to get this up and running.
First thing you are going to do is download two zipped folders, each containing the software that you will need. The first driver package is located here (unzip but do not install).
Second you will download the software package, located here (but do not unzip or install yet install).
Third, uninstall the TV tuner card if is showing up in Device Manager. You can get to Device manager by right clicking on My Computer and selecting Manage. In the left side click Device Manager. When all the devices are shown, right-click on the TV tuner card and click uninstall. Also, because the TV tuner card may be hooked up and no drivers are installed, you may see an "unknown device". Uninstall the "unknown device". Now run the installation/setup program from the first download and follow the step by step instructions.
After setup has finished installing the drivers, go ahead and restart your computer. After you have logged back into your computer, your operating system will recognize the TV tuner and may prompt you for the driver files via the Found New Hardware wizard. When prompted for a driver, browse to the first folder that you downloaded and select the driver file. Now that your computer has recognized and successfully installed the hardware, you will unzip and run the setup file from the second folder you downloaded. This is the software application that will use to interact with your new tuner card.
Oct 29, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
I want to get driver tv tuner for acer aspire l3600
It's a problem for us to assume since you didn't mention the Operating System installed on the Acer Aspire... moreover there are two types of tv tuner card that comes with this model. I hope you'll not mind letting us know all these next time so that we can help you better.
If the operating system install on your system is Windows 7 the click the below links to download
Acer Aspire L3600 Connexant Tv Tuner driver for windows 7
Acer Aspire L3600 Yuan Tv Tuner driver for windows 7
Once you click the link, download will automatically begin. You'll need winrar or winzip to extract the files. Extract the files and run the setup or as per your convenience.
Acer Aspire L3600 Yuan Tv Tuner driver for windows vista
Currently, there's no drivers available for windows xp but you can still run it by using the "Device Manager" > "Update Drivers" wizard after extracting the windows vista drivers.
Good luck.
Thanks for using FixYa.
Jul 08, 2010 | Computers & Internet
I need installation cd for philips saa7130 tv tuner. where do i go get one?
May 18, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
It gives me error when i setup tuner
Upon installing your Philips SAA7130 TV tuner/Fm radio/ Video PCI Capture Card. You can switch your PC on, and get connected to the internet without opening any window. Left click the Control Panel, and the Add hardware wizard. Then follow the instruction. You will be prompted to load your CD installer software driver, if the PC cannot find any driver soft-
ware in the O.S., In case you don't have a CD, your
PC will look it by itself at the internet since you are already connected, just follow and wait to get it installed. Hope this helps.
Dec 12, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Channel Scan on my Philips 26" TV only finds the local channels.
Hi.
you should go into your tv's setup menu and go to the tuner settings and make sure it is set to CATV (cable tv) and not Antenna/Air also splitting a cable to many times can cause the signal to weaken and gain a lot of noise/distortion that could be an issue that can only be solved by having the company come to the house and do a test ALSO when your in the tuner menu in under your tv's setup menu try adding a non local channel manualy and then see if the tv will tune to it, if so then you might have to add them manually at the worst... my guess is that it is not set to CATV/cable tv hope this helps and if not i hope someone else can.
May 24, 2009 | Philips 26PF5320 26 in. LCD Television
Won't keep digital signal
If you're connected to a digital cable box, I would try using the external component connections and bypass the TV's tuner. If all you have is straight cable coming into the house, it could be the cable signal itself or a defective tuner in the TV assuming all the menu settings are correct in the TV.
Jul 25, 2008 | Toshiba MW20H63 TV
RCA D61W130 tv
this unit has two tuner modules. one is the main tuner and the other is the slave or the pip tuner. it would apear from your description that the main tuner has failed. it is possible that this can be replaced.
Jan 28, 2008 | RCA D61W130 61" Rear Projection Television
Televison & Video Logo
12 people viewed this question
Top Acer Televison & Video Experts
Gareth Cockram
Gareth Cockram
Martin Murray
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
