Question about Pontiac Vehicle Parts & Accessories
05 Bonneville dash gauge issues
05 Bonne: Left side dash gauges [oil psi/RPM/temp]do not work properly, if the needles move at all.
    Sergeant:
  • 406 Answers
Unfortunately you are experiencing one of GM non reported non recall issues..It is the entire computer gauge cluster that is bad..many have the problem. I have a 2003 GMC Sonoma others I know have Chevys and Buicks and such..my biggest problem is the gas gauge will not move until I turn the off the switch have to use my trip to watch the miles traveled...all .same problem..there are places that can do a fix on them..not too expensive..just have to find a place..good luck
Posted on Oct 03, 2014
2 Suggested Answers
criss_michae
  • 63 Answers
SOURCE: My 05 Suzuki swift, has
This problem may be in your computer. Have a qualified service technician check it with a scan tool to see if any error codes come up. They will be able to tell you what's wrong once they see those codes.
Hope that helps!
Posted on Feb 11, 2011
96 Chevy blazer how do I get out of safe mode ran low on oil now runs an drives but won't let car go fast past 2000rpms
The computing system on your vehicle has no safe mode for running low on oil . The only thing that will happen is the check gauges light will come on.
The oil pressure gauge is an analog device that is located in the IPC. The oil pressure gauge is operated directly by the oil pressure sensor circuit. As the engine oil pressure changes, the resistance of the sensor and the current flow in the oil pressure gauge changes. The current flow in the oil pressure gauge causes the needle to move in order to appropriately display the engine oil pressure. A sensor resistance of 1ohms will display as 0 kPa (0 PSI) and a resistance of 88 ohms will display as 80 kPa (80 PSI ). The IPC also monitors the oil pressure sensor circuit and interprets the current flow in this circuit in order to determine when the engine oil pressure is too low. If the oil pressure is too low, the check gauges tell tale will turn on. The oil pressure sender is located on the left side of the 2.2L. The 4.3L engine, oil pressure sender is located at the top left side, near the distributor/high voltage switch.
Try disconnecting the battery cables an hold them together for ten minutes , reset ECM !
Nov 08, 2015 | Cars & Trucks
Dash gagues not working
maybe pixels gone bad check that.
Oct 07, 2017 | 1998 Ford Taurus
Guages not working,
If all voltages checked ok,then most probably its faulty instrument cluster board on which gauges are connected.Yes if cluster circuit board looks ok,then also it can be faulty.Somewhere there is minute short or burn on board then such prolem arises.
Also check the fuse box.One under hood and other under dash.Inspect each and every fuse and see if all are fine or not.
---------------For more troubleshooting on these cluster gauges i suggest you to refer the list of help links mentioned below.Its step by step instructions will help you to confirm the exact cause of problem in these conditions:---------
Click the link below:------
2004 Toyota Tundra: Oil Gauge and Temp Gauge Not Working?
http://howtobyme.blogspot.in/2012/05/2004-toyota-tundra-oil-gauge-and-temp.html
2005 Lexus SC430: Fuel Door, Dome light and Fuel Gauge Fuse Location?
http://howtobyme.blogspot.in/2012/05/2005-lexus-sc430-fuel-door-will-not.html
Toyota 4Runner: Temperature Gauge Sensor
http://technoanswers.blogspot.in/2012/04/toyota-4runner-temperature-gauge-sensor.html
Temperature gauge sits over half way mark?
http://schematicsdiagram.blogspot.in/2012/04/temperature-gauge-sits-over-half-way.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Temperature gauge does not move and no heat when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
2003 Pontiac Grand Prix: Erratic Fuel Gauge?
http://technoanswers.blogspot.in/2012/06/2003-pontiac-grand-prix-erratic-fuel.html
Temperature gauge keeps fluctuating up and down close to red?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-keeps-fluctuating-up.html
Temperature gauge on the dash quit working on Pontiac Grand Prix?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-on-dash-quit-working.html
Fuel gauge jumps from empty to full?
http://schematicsdiagram.blogspot.com/2011/12/fuel-gauge-jumps-from-empty-to-full.html
Gas gauge stuck on empty on 2002 Mercedes Benz 240c?
http://repairhelpcenter.blogspot.in/2012/02/gas-gauge-stuck-on-empty-on-2002.html
Oldsmobile Temperature Gauge Lamp Switch?
Fuel gauge drops to Empty?
http://technoanswers.blogspot.com/2012/01/fuel-gauge-drops-to-empty.html
Dodge neon gauges not working?
http://technoanswers.blogspot.in/2012/02/dodge-neon-gauges-not-working.html
Temperature gauge went up?
http://schematicsdiagram.blogspot.com/2011/12/temperature-gauge-went-up.html
Temperature gauge stays At cold on jaguar?
http://technoanswers.blogspot.in/2012/02/temperature-gauge-stays-at-cold-on.html
How to replace Instrument panel and dashboard on Toyota car?
http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-instrument-panel-and.html
How to remove instrument panel on Chevrolet car?
http://technoanswers.blogspot.in/2012/02/how-to-remove-instrument-panel-on.html
How to remove control panel on Buick regal?
http://howtobyme.blogspot.in/2012/02/how-to-remove-control-panel-on-buick.html
These details will help.Thanks.
Nov 28, 2012 | 2000 Mitsubishi Lancer
No guages working
If all voltages checked ok, then most probably its faulty instrument cluster board on which gauges are connected. Yes if cluster circuit board looks ok, then also it can be faulty. Somewhere there is minute short or burn on board then such problem arises.
Also check the fuse box. One under hood and other under dash.
For more troubleshooting on these cluster gauges I suggest you to refer the list of help links mentioned below. Its step by step instructions will help you to confirm the exact cause of problem in these conditions: ---------
Click the link below: ------
Thanks.
Heat gauge goes way up,then by reeving motor it will go down.blows cold air
Check out related help links with solutions to troubleshoot the problem:---
Toyota 4Runner: Temperature Gauge Sensor http://technoanswers.blogspot.in/2012/04/toyota-4runner-temperature-gauge-sensor.html
Temperature gauge sits over half way mark? http://schematicsdiagram.blogspot.in/2012/04/temperature-gauge-sits-over-half-way.html
------------- No heat on Oldsmobile Silhouette? http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Temperature gauge does not move and no heat when heater is ON? http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
Temperature gauge keeps fluctuating up and down close to red? http://technoanswers.blogspot.com/2012/01/temperature-gauge-keeps-fluctuating-up.html
----------- Temperature gauge on the dash quit working on Pontiac Grand Prix? http://technoanswers.blogspot.com/2012/01/temperature-gauge-on-dash-quit-working.html
Dodge neon gauges not working? http://technoanswers.blogspot.in/2012/02/dodge-neon-gauges-not-working.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
1992 Lexus LS400: Engine overheats, Antifreeze out of reservoir and heater Blows Cold Air? http://whatisbyme.blogspot.in/2012/05/1992-lexus-ls400-engine-overheats.html
Thanks.
Nov 22, 2012 | 1997 Ford Taurus
I have an 02 wrangler and the oil preasure goes down when Idling is that an oil pump going bad?
First we would need to know when this occurs. Asuming the oil level is at the full mark!. If the pressure goes up during acceleration and down at idle when engine is fully warmed up, then this is normal. An engine requires 10 psi of oil pressure per 1,000 rpm ( ex. 20 psi at 2,000 rpm, 25 psi at 2,500 rpm, and so on ) . If the gauge is moving back and forth erratically at idle , i would say the gauge is bad. If it drops to 0 while accelerating I would say your oil pump is bad. If from time to time it seems to work and other times it seems not to work, I would say the oil pressure sending unit for the gauge is bad. If the pump failed you would start to here a Knocking noise from the engine in a short period of time. Use the above scenario's to narrow down what it may be.
Oct 16, 2010 | 2002 Jeep Wrangler
Oil pump is going bad in my 1999 chevy lumina
Jul 02, 2010 | 1999 Chevrolet Lumina
The oil pressure gauge goes from 0 to all the way up and the needle moves back and forth while driving it checked oil its good now its clicking underneath the car and it felt like the transmission was...
Mar 27, 2010 | 2005 Nissan Altima
My gas gauge doesn't work in my 2003 bonneville. What can i do to fix this problem, along with my broken gas gauge my heater in my drivers side seat is no longer working, i would appreciate any help thanks...
It might not be anything wrong with your fuel sending unit. Keep an eye on your other gauges. I own a 2004 Pontiac Bonneville GXP. All of my gauges have started acting erratically. It started with my Temp. gauge, moved on to my speedometer, and now my oil pressure , fuel level and batty volt gauges are affected too. Its a very common problem with GM vehicles.
Nov 12, 2009 | 2004 Pontiac Bonneville
Vehicle Parts & Accessories Logo
73 people viewed this question
Top Pontiac Vehicle Parts & Accessories Experts
jerry emmons
Jeffrey Turcotte
Jeffrey Turcotte
Dan Shibata
Dan Shibata
Are you a Pontiac Vehicle Part and Accessory Expert? Answer questions, earn points and help others
