Question about COBY-PERSONAL & PORTABLE Bluetooth Speaker System For IPad/IPod/IPhone / Mfr. no.: CSMP135
How to get bluetooth pin - COBY-PERSONAL & PORTABLE Bluetooth Speaker System For IPad/IPod/IPhone / Mfr. no.: CSMP135
What in the pin to use with the smartphone?
Try "0000," "1111" or "1234". These are some of the most common default Bluetooth PINs. If this doesn't work, contact the manufacturer of your bluetooth device (after reading the manual).
Aug 01, 2014 | Universal BK3001 Mini 2.4GHz Bluetooth...
Usb dongle is not working
Step 1:
A Bluetooth dongle is an external Bluetooth device used to enable your PC's Bluetooth connection. Many Bluetooth dongles come without installation disks since the software is pre-programmed into the actual USB stick. These Bluetooth dongles are very useful on netbooks that don't have Bluetooth connection, since netbooks have no CD-Rom drives. Turn on your PC. Insert the USB Bluetooth dongle into the USB port on your desktop tower, or the USB ports located on the perimeter of your laptop. Wait for the program to auto run. Once you connect your dongle, the driver program should launch. Follow the onscreen prompts to install the dongle. A dialogue box should open that says "Installing Drivers" from the taskbar. Allow the driver to install completely before closing the box. Unplug the dongle and restart your PC. Once the PC has been switched on, insert the dongle. Double-click "My Bluetooth Places." This is the Bluetooth icon located in your taskbar, and it should launch the "Initial Bluetooth Configuration Wizard." Click "Next" on the first screen. Next, type in the name of your computer and select your computer type from the drop-down menu, then click "Next." Click "Skip" on the onscreen prompts, then finish. Pairing the Devices Turn on your external Bluetooth device. Double-click "My Bluetooth Places." Select "Find Bluetooth Devices." The name your Bluetooth device should display in the next window. Right click the icon for your Bluetooth device, and scroll down to "Pair Device." Enter the Bluetooth pin code for your external device in the "Bluetooth Pin Code Request" pop-up window. Then click "OK." The default pin code is normally "0000" or "12345." You can find your pin code in your user manual. If you are pairing a cell phone to your PC, you will have to enter the same pin code on your cell phone to establish the Bluetooth connection.
Apr 10, 2013 | Computers & Internet
My friend gave me his bluetooth but i need the pin to connect it to my phone and i cant get it .how can I pair it to my phone without using a pin or making a new pin?
The pin or the passkey is "0000". To pair the SGH-T749 (Highlight) handset with a Bluetooth Device follow the steps below:
  1. Place the Bluetooth device in discoverable mode
  2. From the standby screen, press on Menu
  3. Press on Settings
  4. Press on Bluetooth
  5. Search for the Bluetooth device by pressing on Search, located at the bottom
  6. Press on Yes to Activate Bluetooth and start the search
  7. Press on the desired Bluetooth Device (if not shown press on the left or right arrows until displayed)
  8. If prompted, press the Passkey "0000" then press on OK
  9. You will get a brief message stating connecting followed by connected, if prompted press OK again
Note: The first time you try to pair with another handset, you and the owner of the other handset must enter the same PIN. Once the handsets have been paired, you will not need to use the PIN again.
Mar 30, 2011 | Samsung OEM Travel Wall Charger for...
Lost Pin for Emerson Bluetooth Pairing to IPhone,
Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Aug 17, 2009 | MyNetDeals BlueAction Wireless Bluetooth...
I don't know the pin number to my bluetooth HBM-730
Are you trying to pair these two devices? In that case enter any number as your PIN when prompted and enter the exact number in the other device when it asks for. PIN number is asked when you try to pair two or more bluetooth devices. PIN can be any number but make sure you enter the same number in all devices.
I hope it helped.
Feb 10, 2009 | Cell Phones
Don't know the pin to set up my bluetooth
Most Motorola bluetooths have a default passcode of 0000 and cannot be changed.
Mar 14, 2008 | Motorola Mobility RAZR V3
Pioneer Bluetooth
The Z2 default code is 1111
Oct 23, 2007 | Pioneer AVIC-Z2 Car DVD Player
COBY-PERSONAL & PORTABLE Bluetooth Speaker System For IPad/IPod/IPhone / Mfr. no.: CSMP135 Logo
56 people viewed this question
Top COBY-PERSONAL & PORTABLE Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a COBY-PERSONAL & PORTABLE Audio Player and Recorder Expert? Answer questions, earn points and help others
