Question about Konica Minolta Office Equipment & Supplies
Di470 printing a full black image - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,680 Answers
Check the charge Conora assy above the drum. ensure it is properly secure and install you mite have a charge corona power supply problem
Posted on Jan 23, 2016
Printer has all full cartridges, not printing clearly
Does this machine have drum units, image units and toner units? what combination? Replacing the toner cartridge will not fix the issue with the drum or image unit.
Nov 20, 2015 | Office Equipment & Supplies
Blank copies from copier
You don't say what model your fax is.
In general. If when copying you get a Full BLACK page printed then the scanner lamp is not lit. As no light is reflected into the image scanner, it interprets this as BLACK information so therefore only black is printed. Look into the ADF while the document is being scanned and I bet you will see no green light at all. A new Contact image sensor should cure it.
Jan 13, 2014 | Canon Duplex Automatic Document Feeder
Copying a document prints out black page
Its CCD(scan camera) unit faulty, replace it..see the idle snap shot
Jan 09, 2012 | HP Officejet Pro L7680 All-In-One Printer
I have a hp 3310 wireless. It prints in colour well but if you print in black most will be not clear although a line every so often is printed clearly. If you print the same document the same lines...
What you are trying to print is created in RGB. This means it is a photo that has been created in a color format that will ONLY print if you print it in full color. If you try to print your photo item in only black, it will only print what it sees in TV Colors, a combination of RED GREEN BLUE. This is why you will only get part of the image printed when only in black.
The only way to change it to print the whole image in all black, is to open the image you are trying to print in Photoshop or another professional grade photo program, and to change the settings of the image to CMYK, effectively, Cyan, Magenta, Yellow, Black. Then, change the image once again - to GREYSCALE. This will effectively change all the colors to a SHADE OF GREY, in different HUES.
Save the picture as a JPEG, and then print from the desktop, from your picture viewing software that came with your computer, and you will see everything print out from the black ink, in greyscale.
Nov 16, 2010 | HP Photosmart 3310 Printer
Changed inks, pages are being pinted however very faint in the black areas, changed toner which was still half full but no change in quality of print. coloured areas are excellent with black areas almost...
You must print a lot of black and white documents. The problem is with the black developer in your imaging unit. The problem can be fixed by either replacing your imaging unit for $100+ or you can fix it yourself by cleaning the imaging unit. I have a link to describe the problem and how you can clean it using simple household tools. http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
Oct 27, 2010 | Samsung CLP 300 Laser Printer
Minolta Di470 Error code C-0F24
COF24 is an AIDC or Automatic Image Density Control failure code. It means that the machine can not properly detect the developer to toner mixture or ratio in the process/developer unit. This can be caused by an AIDC sensor failure, Developer Drive problem or for some reason the machine is not getting toner as it should. Has the machine been running low on toner?
Before calling for service I would try resetting the code by opening then closing the front door(s). Do this a few times and see if the code will go away. If not then you will need a service person to diagnose and repair which part is defective.
Good Luck and Thank You for using Fixya.
Apr 22, 2010 | Office Equipment & Supplies
My black ink will not print. Do I have to have
The larger of the two black cartridges is used for text only printing.
The saller cartridge is used for black in graphic images or pictures.
This saves you color ink . It allows you to put the black ink on the image without making the color inks blend the black ink.
Don
Jan 31, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Epson Stylus Photo 870 only prints black and white
WHen your p;;rinter name comes up, check the printing p;references. You have "P:rint colors as black & white" checked. Un check it. It is in the printer dialog box, not PSP.
Sep 15, 2009 | Epson Stylus Photo 870 InkJet Printer
Not printing color images/print MFC-210c
sure it is set correctly inyour desktop???
right click on you printer and go to properties
device settings and look if set to color or black
Sep 01, 2008 | Office Equipment & Supplies
COF37 error code
C0F37: Abnormally high toner density detected by Black ATDC Sensor
Toner density that is 4 % or more higher than the target level is detected ten consecutive times during a print1.gif cycle, ATVC, or image stabilization sequence.
The sensor for this error is in the black imaging unit not the toner hopper. See the steps below. If that doesn't work then visit my website1.gif for contact and I will sell you a full service and or parts manual on CD.
Step
Check Item
Result
Action
Imaging Unit Bk is installed correctly.
NO
Check and correct ATDC
drawer CN of imaging unit Bk.
Each of Imaging Unit Bk contacts makes
NO
Clean or correct.
good contact.
ATDC Sensor harness is open-circuited.
YES
Change Imaging Unit Bk.
Jan 20, 2008 | Minolta CF2001 Copier
21 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
