Question about Duraflame Electric Fireplace Stove DFS-750
Heater blower only runs about a minute then shuts off
Would like to know why the gas heater won't stay on. Lights for a bout 5 minutes then shuts off.
Is the fan running after furnace light because there might be an issue with the blower .if blower doesn't come on unit would shut off on a safety switch called a high pressure switch
Jun 03, 2017 | Heating & Cooling
I have an older Guardian forced air heater. I can cross the red/white wires and it will run for 10 minutes then shut off and not start again. Is there a safety cut off in the furnace?
make sure you filter is clean and your blower works, a blocked filter will shut off system on high limit, and it will reset when furnace cools off
Dec 28, 2015 | Heating & Cooling
1994 chevy kodiak with Cat 3116. Heater/AC blower shuts down
you should make a diagnostic to know what happened to your car
of course you need an auto diagnostic tool : http://www.chinasnoy.comand you can find all kinds of tools in chinasinoy.com
May 21, 2013 | Cars & Trucks
The heater does not stay on long enough to heat my garage. it will come on for 3 to 5 minutes and shut off. it comes on again in 5 to 10 minutes for 3 to 5 minutes again. the heat is good when it runs....
You could tripping the high temp limit this will be located near the heat exchanger When it shuts how long does the blower motor stay running? Do you have a meter?
Dec 15, 2010 | Fahrenheat FUH5-4 Heater
The unit will turn on and run fine for a few minutes then shut off. It won't immediately turn back on, almost as if it hans to cool back down first. Any ideas i have a lennox furnace
The ignitor will light, the blower will start up and run for a few minutes and then the system will shut down, and the blower will continue to run and cool down. The ignitor is not working properly, the ignitor has carbon build-up and need to be removed, cleaned all the black carbon from the ignitor with a little piece of sand paper and replaced, turn the heat back on and this should correct the problem.
Dec 12, 2009 | Heating & Cooling
Pentair Heater shuts off prematurely when warming spa
check gas pressure could be running out or overheating
Mar 06, 2009 | Pentair MINIMAX NT TSI IGNITER
Heater runs for appox 2-4 minutes and then shuts down..
what kind of furnace do you have? Is it electronic or standing pilot? If you have electronic then it could be flame sensor if you have standing pilot and the pilot goes out and you have to relight then it is probably the thermocouple what is going through an 1/2 flex pipe explain this a little more. Have you checked filter.
Jan 21, 2009 | Procom ML300EBC Heater
Heater runs hot for a few minutes then stops heating
I would say from what you have described your problem is a bad thermostat heat sensor (you may have to replace the whole thermostat on this model!) This is a very common problem for this unit!
Please rate my sesponse!
THANK YOU
Jan 14, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Duraflame Electric Fireplace Stove DFS-750 Logo
Top Duraflame Home Experts
Donni Steen
Tom Chichester
Are you a Duraflame Home Expert? Answer questions, earn points and help others
