Question about Pioneer CDJ-1000 CD Player
Pioneer mechanical lazer alignment - Pioneer CDJ-1000 CD Player
Pioneer cd/dvd player Why do not read the disc? just keep loading but don't play none of the discs. (cd or dvd)
You might have to go inside and clean the lazer unit lens, but try a lens cleaning disc first.
Feb 10, 2017 | Pioneer Televison & Video
307 alternator
You have a few problems here first let's try to help with the belt. If the belt is not put on straight it will shred into pieces by straight I mean aligned with the 2 or more pullies including the tensioner. The steering not being straight means the tire alignment is off this can be sorted by going to do a lazer alignment.
Feb 19, 2014 | Peugeot Cars & Trucks
Pioneer dv-2010 dvd player makes a whirring noise
That's because the lazer on the tray is trying to read the disc. Does this happen to other discs? When the lazer can't read the file, the drive spins up the disc to help it read it.
Dec 09, 2013 | Televison & Video
My pioneer pd f505 is lock how can i unlocked it
The loading mechanism is out of alignment and needs to be fixed before the door will operate correctly.
Feb 26, 2013 | Pioneer PD-F505 CD Player
Have pioneer pdr w839 needs new lazer where do i get one
Hello
Just contact the authorised service center for Pioneer at your town. You can buy it locally too, form any of electronic spare part selling shops at your town.
Feb 29, 2012 | Audio Players & Recorders
Cd tray won't stay open--when you press the "open" button, it opens but then closes again immediately.
It has a misaligned loading mechanism. I have dealt with this kind of problem before. What is happening is that before the tray have a chance to open all the way it gets stuck and gets pulled back in.
May 24, 2011 | Marantz CD5001 CD Player
My phillips HTS3090 system keeps saying BAD DISC
for some reason the unit is not happy with the disc have you tried running a lazer cleaner through it? although i wonder if that will work as the words bad disc does seem to mean a lazer read problem but then it can only be either a dirty lazer or the lazer is miss aligned withch means it need s a pro service .... try cleaning the laser
Jul 03, 2010 | Televison & Video
I am trying to burn using Pioneer DVR-110 DVD RW its starts to burn then after 1 or 2 min it stop and says cannot burn why is that what can i do to fix it please???
You can try and clean the lazer and the 2 chrome rails that the lazer moves along as it reads the disk.To clean the lazer use get some Isopropanol from your local chemist.Use a cotton bud NOT SOAKED with a small amount of Isopropanol and gently clean the glass using a circular motion and and polish with a clean and dry cotton bud.To clean the rails use special fine machine oil. Do not use WD40 as it contains water.Hope this helps you.
Regards Bill
May 08, 2010 | Pioneer DVR-110D DVD RW Dual Layer Burner
Print dos text file to a lazer printer
You are on the right track, but you need to change the font (typeface) that is being used to one that has a fixed character width.
Mar 17, 2009 | Microsoft Computers & Internet
Won't load or play disc or dvd
It's a well known fact PS2's had a cheap lazer fitted to them, that's why when it gets chiped to play copy games, not long after it starts playing up. The lazer may just need aligning, purchase a cd/dvd cleaning cd rom as these can check audio, lazer alignment and clean the lens.
Jan 07, 2007 | Sony PlayStation 2 (PS2) Console
Pioneer CDJ-1000 CD Player Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
