Question about Sentry Fire Safe Waterproof Security Chest F2300
Key works but can't get the lid to open - Sentry Fire Safe Waterproof Security Chest F2300
2008 bmw 750li the trunk not open
There is a valet switch in he center console and make sure it is switched on so it will open. Does it open from trunk switch on the trunk or from the manual key cylindr in the trunk deck lid? If it does not work from the manual key release on the deck lid then the lock in the trunk is faulty and will need to be drilled and removed unless your a lucky one and have the ski boot opening in the center of backseat fold down arm rest ? If there is a opening then use a hanger and grab the emergency release handle at the right rear of the trunk deck lid underneath, it is glow in the dark colored.
Oct 15, 2014 | 2008 BMW 750Li
Tip
Toyota Trunk Lid Mysteriously Opens!
I am submitting this tip about Toyota trunk lids. I have owned three Corollas in consistent sequence. My current model is a 2010 Corolla LE.
What really surprised me was being parked somewhere and being away from the vehicle for anywhere from 3 minutes to a few hours, only to discover that when I returned to the vehicle, the trunk lid was wide open!
I was able to find a resolution that I can live with. The "culprit" is the remote key device, which gets activated (unknown to the owner at the time of opening) if the owner and the vehicle are close enough in proximity to open the lid. When the remote is in one's pocket, the trunk lid can easily open and the owner may have no knowledge of it at all. Imagine going shopping and the entire trunk is full of items (groceries, department store items etc) and coming back to your vehicle and finding that everything is GONE! This happened to me at least three or four times a week (Thank God no one took anything..!!!)
The dealer told me to just turn the lock cylinder with the key so that the lock cylinder has the key hole orientated to a "horizontal position". They told me that the lid wouldn't open with the lock cylinder in that position. NOT TRUE!!! This feature only prevents the internal trunk release inside the vehicle from having the ability to open the trunk lid. To my surprise, the lock cylinder can be orientated to the horizontal position and the remote device can STILL open the trunk lid. Since I work at a place where high security is required 24/7, I HAD to come up with a solution that would put a confirmed kill on the problem.
I reached up inside the trunk lid door and disconnected the electrical connector from the automatic lock release. NOW, the trunk lid can ONLY be opened with the key MANUALLY!
I'm sure every Toyota owner has or eventually will face this issue and hopefully, all of the contents of the trunk are still intact. I decided to never give it anymore chances. It is only a very minor inconvenience to use the key to unlock the trunk lid. I can STILL disable the trunk lid release cable by turning the lock cylinder horizontal when I am parked anywhere in public.
I certainly hope this provides everyone with a simple fix!
on Nov 11, 2014 | Vehicle Parts & Accessories
Power windows do not work
disconnect trunk switch and see what happens when you perform the above actions.also is the trunk switch located with the window switch and does your door lock unlock normally when you turn car off.
Dec 31, 2013 | 1997 Lincoln Town Car
Ford Focus 2005 central locking problem. how to open trunk and petrol lid manually
I have a key to start my car but no key to unlock my trunk and i have look for a lach it is a 2000 ford focus how can i get in or if i get a key made would it work
Feb 24, 2013 | 2005 Ford Focus 2.0
Trunk on totota sienna wont open
do you have a remote lock or is it a key or both make sure the trung lid it latched press down on the lid while working the key
Aug 27, 2012 | Toyota Cars & Trucks
Trunk (rear lid) wont open 2001 2.0 beetle
look for a round plug on the cover remove the plug and you will see a lever inside to push
Aug 22, 2012 | 2001 Volkswagen Beetle
1999 Toyota Camry the cab interior trunk release will not open the trunk.
TRUNK LID ELECTRIC LATCH NOT WORKING MORE LIKELY ITS BROKEN.YOU HAVE TO USE KEY THE OPEN THE TRUNK LID, IF TRUNK LID GETTING POWER, THE ELECTRIC LATCH HAS TO BE REPLACED.
Aug 02, 2011 | Toyota Camry Cars & Trucks
My trunk will not open on my wife's 2001 slk Mercedes. It's not locked. I think something is stuck in the lock. Can you help me?
your can check is it something stuck in the lock, first operate your roof either way, if you are going to open the roof as a first action boot lid will open to backward, let boot lid fully open and stop operating the roof, ignition off and have a look if something stuck you can see, if you are going to close the roof let close the roof and before close the boot lid stop operating roof switch, otherwise faulty boot lid lock, if faulty lock but you can try by mettle key blade which is in your electronic key, first take out mettle key from electronic key then insert mettle key in to the key hole in boot lid turn fully left and open boot if not work turn fully left and push it in, is this information helped you?
Oct 22, 2010 | 2000 Mercedes-Benz SLK
My rear lid wont open on my 2001 vw jetta 2.0L
central locking device on the boot is not working and needs replaced
Jul 12, 2009 | 2001 Volkswagen Jetta TDI
Sentry Fire Safe Waterproof Security Chest F2300 Logo
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
