Question about Sony Car Audio & Video
Sony cdx-gt260 tuner faulty. cd and aux in work.
  • 6 Answers
SOURCE: sony cdx gt200
I HAVE A SIMILAR MODEL AND I HAVE TO HIT THE SOURCE BUTTON TILL AUX APPEARS MAY BE A RADIO MALFUNCTIO
Posted on Nov 13, 2008
thefazool
  • 3 Answers
SOURCE: No sound from cd or aux on CDX-GT32W
Just connect together the solid blue wire on the main harness to the radio with the blue/striped wire. The blue wire is for the power antenna and the blue striped is for the remote amp. but if not connected together only the fm/am has outputs to the line output RCA jacks. I learned this through Sony's tech line and it works perfectly now.
Posted on Dec 15, 2008
  • 87 Answers
SOURCE: Sony CDX-CA810X / CD-playback drops aux amplifier
Do you have the remote turn on lead hooked up to solid blue wire from the back of the deck? Your amp shoild be hooked up to Bluw w/ white strip as the solid blue wire shuts off when the tuner is off, its used only for the power antenna.
Use Blu w/ Wht strip for amps
Posted on Jun 03, 2009
SOURCE: sony cdx ca650x has no audio output from tuner, CD is OK
Tuner might be defective , check to see if tuning voltage varies
Posted on Jun 11, 2009
  • 227 Answers
SOURCE: aux problem
You have to go into the standby menu and turn aux on. Go to standby, push menu button and scroll down to aux and turn on
Posted on Aug 05, 2009
My sony 52wx4 tuner will not work. cd and aux does, but not tuner. Lights up but no sound
some of the sony tuners did have inherent problems, if your unit is a cdx-gt260 then most of these had tuner problems. best to change the entire tuner "circuit can/module" in the unit. or check out your sony service center for repair advice/cost. cheers.
Jun 10, 2012 | Car Audio & Video
Hello, I have a Sony cdx-gt350mp. When using the front auxiliary in", there is no sound heard. You can see the equalizer display receiving the signals....just cannot hear the music. AUX is...
you might have to enable the aux imput...my manual for 350s and 300 says its an item in the setup...first clock then beep then aux ,sub,dim,contrast...ect( Hold the select knob in 3 sec)
Jun 18, 2011 | Sony CDX-GT350MP
I have a sony cdx-gt45ip wen playing a cd or using the tuner my sub works but wen using the aux all bas dissaperes, the sub still has power why is this happening ?
use the blue/white wire (amplifier remote turn on) to turn the amp on instead of the blue wire (power antenna remote turn on). the blue wire turns off when leaving tuner mode.
Mar 02, 2011 | Sony XPlod CD Player w/MP3 Playback...
Yes, also.... I am trying to use my AUX input but "AUX" is not an option on the Source menu. The only options are tuner and CD.
In order to use the Aux, you must connect the source to aux port, then using the source select aux and you should hear the sound coming out.
Here is the link to the manual:
http://www.docs.sony.com/release/CDXGT20W_200.pdf
Feb 06, 2011 | Sony XPLOD CDX-GT200 CD Player
How to wire a sony cdx-gt640ui in a 1999 dodge intrepid...I get sound with the tuner, but no sound with cd, aux, and usb. I'm assuming its only an incorrect wiring setup...
instead of used the blue wire on the Sony head unit to the car wiring harness use the blue/whit wire
  • Blue - powers on only when am/fm is active
  • Blue/White - powers on when when radio is on am/fm/cd/ ect.
Jun 13, 2010 | Sony CDX-GT610Ui CD Player
Sony CDX-F5700 no longer sees Sony 10-disc changer
face plate is going bad lcd is fading solution--replace face
Jun 21, 2009 | Sony CDX-F5700 CD Player
Jun 03, 2009 | Sony CDX-CA810X CD Player
Sony cdx gt200
Nov 13, 2008 | Sony XPLOD CDX-GT200 CD Player
May 17, 2008 | Sony CDX-GT300 CD Player
Car Audio & Video Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
