Question about Pioneer DEH-P690UB CD Player
Wattage for pioneern DXT2369ub out put by channel
Having trouble under standing rms with speakers. Some speakers rms is per speaker and other are for both speakers.I am looking for soundstream speakers that would be 150 rms per speaker. Thanks
rms is a method of measuring power (wattage) delivered from an amp to a speaker. In almost every case, wattage capacity of speakers is quoted PER SPEAKER. Likewise wattage output is quoted per amp output channel. Assuming a you plan on a single speaker on each output channel of your amp, you should be in good shape if your speaker wattage capacity equals or exceeds your amp's output rating. I've never seen speakers rated as wattage per pair.
(rms is the dominant way of measuring average watts of an ac sine wave signal)
Apr 23, 2017 | Car Audio & Video
How many watts per channel do Polaroid PBT3002 bluetooth speakers put out? How many ohms resistance? Can't seem to find this info anywhere.
This tends to be make and model specific! Speakers don't 'put out' power, amplifiers do. Speakers are rated at a certain power, which if you exceed that wattage, you damage the cones or coils.
Car amps 100watts per channel PEAK power, rather then RMS which is better. 8 Ohms.
Speakers should be capable of taking 20% more power than the amp can drive.
May 17, 2016 | Audio Players & Recorders
Can I bridge my 1200watt 2channel sony xplod amplifier?
How many ohms at two channels, remenber ohms law, amp should be stable at lower ohm RMS wattage..whenn you say 1200 watts its that full wattage, now you got a RMS wattage..What is it?
Apr 04, 2016 | Sony Car Audio & Video
How do you wire a pioneer DXT2369UB to a 2001 chevy malibu?
Call Crutchfield. They will probably have an adapter kit.
http://www.crutchfield.com
Sep 02, 2014 | Cars & Trucks
Need a good 500 watt cd player not sure what to buy
Before you go off on a wattage hunt you should learn what that means.
Search the web for subjects such as "amplifier wattage vs speaker wattage" for starts.
Don't buy into what manuafacturers CLAIM for wattage if it ADDS all the channels together and FAILS to specify a bandwidth and an acceptably low distortion figure. REPUTABLE makers specify watts per channel, all channels driven at no more than X distortion (typically well under .1%) and, at minimum, across the audio bandwidth or 20Hz - 20kHz.
Any garbage cheapo amp (meaning most shelf systems or all-in-one packages) can put out a lot of dirty power which will strain THEM and possibly kill your speakers. CLEAN POWER is what you want.
Dosome reading and search the web for whatever you are considering, and add the word 'scam' to the search. Get opinions from actual owners. There are a lot of unscrupulous people out there selling garbage to people on the streets.
Aug 22, 2011 | JVC HXC6 500-Watt Stereo System with 5-CD...
My 4300hp will barely do 40 watts pep any help
is it always done this or just started? if always then theres a low wattage 2290 that could be installed @ factory and they will not do max wattage. exchange with newest production run to fix wattage. if it was doing 80watts and now down to 40watts have you checked swr's, antennna system, or power wires? if high swr's it will degrade transistors and loose wattage, and low ampres will not produce any power either...
Feb 18, 2011 | Connex 4300HP 240-Channels Base CB Radio
I want a reliable system.
if you bought that equipment today then your answer is yes your amp will power the subs but if i was you and you want more bass I would go with a two channel amp or even a mono block amp that will be 1 ohm stable and if you decide to do that you might want to get subs that are dual 4 ohm voice coils and run them in series that will get you 1 ohm of resistance
May 19, 2010 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
I need to know what the wattage the alpine mrv-f407 puts out when its bridged or only running 2 channels?
RMS Continuous Power (at 12.0V)
Per channel into 4 ohms...............40W, 0.08% THD
Per channel into 2 ohms ..............50W, 0.3% THD
Bridged into 4 ohms.....................100W, 0.3% THD
RMS Continuous Power (at 14.4V)
Per channel into 4 ohms...............60W, 0.08% THD
Per channel into 2 ohms...............80W, 0.3% THD
Bridged into 4 ohms.....................160W, 0.3% THD
Max. Power (at 14.4V)
Per channel into 4 Ohms..............120W
Bridged into 4 Ohms....................320W
This should help.
Apr 30, 2010 | Alpine MRV-F407 Car Audio Amplifier
Need to know how to wire Alpine 12" 1242D 4ohm Want to use 1 speaker in ported box with Phoenix gold 2200pro amp
As long as the total wattage of the amp does not exceed the total wattage of the speaker, you can bridge the amp. To do this, put the positive wire of the speaker on the positive terminal of channel 1 on the amp, and the speaker negative wire on the negative terminal of channel 2. This allows you to run the amp's full power into one speaker.
Aug 02, 2008 | Alpine Car Audio & Video
Pioneer DEH-P690UB CD Player Logo
59 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
