Question about Ricoh Aficio 1018D All-In-One Laser Printer
Use ricoh aficio 1018d as scanner
We want to use this copier as a scanner. Is it possible ? What is the solution ? Need an urgent reply
  • 20 Answers
First do u hv a scanner and printer connection board in ur machine.if not its imossibal to work u must get one and install it.
Posted on Apr 28, 2014
  • 5 Answers
SOURCE: problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
Posted on Jul 22, 2008
NALDZ
  • 38 Answers
SOURCE: Ricoh Aficio 450 copier
FINISHER MEANS... A STAPLE SECTION...IF YOU DO NOT WANT TO USE THIS UNPLUG THE PINISHER... REMOVE THE WIRE WERE CONNECTED.
Posted on Jul 06, 2007
Bubbabear64
  • 2794 Answers
SOURCE: I forgot login password for Ricoh Aficio MP2000 copier
Try getting into service mode and see if you can reset the user passwords by turning them off in the settings.
Do you know how to get into service mode?
Posted on Nov 20, 2008
Nic61
  • 1073 Answers
SOURCE: I NEED Ricoh Aficio 1018 Printer/COPIER AND SCANNER DRIVER
http://support.ricoh.com/bb/html/dr_ut_e/ra/model/x1015_18/x1015_18en.htm
There you go M8!
Just selcet your OS and download the files you need
Good luck to you
If you find my answer helpfull, dont forget to vote
Posted on Dec 15, 2008
  • 161 Answers
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
Ricoh Aficio 1018D copies are light
buy a Photo conductor unit and then initialize it after you put new unit in.
Aug 14, 2014 | Ricoh Aficio 1018D Copier
How do i clean the dirty white plate in a ricoh aficio 1018d copier
Remove the exposure glass. The white plate is on the underside of the left scale. Clean with water or alcohol.
May 31, 2014 | Ricoh Aficio 1018D Copier
Ricoh aficio 1018d toner not detected
oooh i think u need to replace devoloper gears there are five gears must be replacees. u need a tech. to do that
Feb 18, 2014 | Ricoh Aficio 1018D Copier
Ricoh aficio 1018D all in one printer is showing problem. No. SC 194
sc194 is an error with the scanner. It could be a bad exposure lamp, but it could also be a circuit board that needs to be replaced (either the SBU board or BICU board).
Mar 05, 2011 | Ricoh Aficio 1018D All-In-One Laser...
Hello, ricoh aficio 1018d error code display sc 925 what can i do for it.
IMB non-connected error
Symptom:
IMB is not connected. This SC only
appears with B040 and B043 version
machines.
Possible Cause:
• IMB is not connected
• Poor connection between BiCU and
IMB
• IMB defective
• BiCU defective
Sep 27, 2010 | Ricoh Aficio 1018D Copier
I have a problem with my ricoh aficio 1018d copier. It is printing very faint. let me how to go about it
after every 60 000 copies the drum must change, if the drum changed inspect laser module and clean if dirt
Sep 07, 2010 | Ricoh Aficio 1018D Copier
I have ricoh aficio 1018d can it fax or print and i cannot find connection points on machine
Sir,
You can fax or print with the aficio 1018d provided that you have the fax and printer options. these connection points are located at the back of the machine.
Mar 06, 2010 | Ricoh Aficio 1018D Copier
Can MAC OSX 10.5.x use Ricoh Aficio 1018D? Do you now alternativ drivers for ricoh aficio 1018D. HP LaserJet 5-Gutenprint v5.1.3 is o.k. for A4 but not for A3
this is an older model copier, however try going to www.savin.com and click downloads then drivers. there will be a tab for drivers, this is 10.5 though not snow leopard. Ricoh/Savin/gestetner and Lanier are all the same copier, but savin site has more mac info than Ricoh site. Usually I have better luck using already installed Mac drivers than Gutenprint, if you type in the ip it should give you a list of preinstalled Mac drivers. I believe the Ricoh 1018 corresponds to a Savin 2518 if that helps. Also use print daemon, not ipp. hope this helps somewhat as Macs are difficult with options and such on most printers. also must use PS3 for best results.
Jan 09, 2010 | Ricoh Aficio 1018D Copier
Ricoh 1018d not print with lan conection
Hi Usama,
I had the same proplem as you when i installed pcl6 driver on my ricoh 1085
I solved but by uninstalling pcl6 driver and installing pcl5e
for your 1018d try this driver for windows XP D O W N L O A D H E R E
BTW.
about using 1085 as a scanner ,
I don't know what is "scanner interface drive board" ?
more help please.
Oct 23, 2008 | Ricoh Aficio 1085 Laser Printer
Ricoh Aficio 1018 photocopier
MY PHOTOCOPIER IS ASKING FOR CODE SC194
Nov 30, 2007 | Ricoh Aficio 1018D All-In-One Laser...
Ricoh Aficio 1018D All-In-One Laser Printer Logo
37 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
