Question about Miele W4840 Front Load Washer
Lost diamond in Rubber seal of front loader
Help! My ring got caught in the rubber seal and ripped the diamond out. I could see it stuck but when I tried to retrieve it I heard a metallic sound and it drop into the drain?? It was not in the filter at the bottom and we flushed it with a hose but no diamond. We then ran a rinse cycle and checked filter again. No go. Running a cotton cycle now to see if more water will help. Wondering where it would go once it drops between the rubber seal and the barrel and can we check ourselves or do we need a Miele technician. Thanks :)
4 Suggested Answers
bd8078
  • 12 Answers
SOURCE: miele incognito not draining
at the bottom left corner their is a manual draining system maybe you need to use that with a bucket.
thats all i can think of unless it still has warranty just trade it in.
Posted on Oct 03, 2008
  • 70 Answers
SOURCE: miele front loader rubber door sela has small tear
No.
At the beginning of every cycle water enters appliance via top of door seal this is connected to the inlet water supply
Posted on Jul 08, 2010
  • 40 Answers
SOURCE: About Miele novotronec washer w
Here is the part number for the seal 6816000 As far as the trick, depending on your level of skill, there will be a tab on the seal itself and that should be positioned at 12 o'clock. You press the seal firmly onto the drum until you hear a pop. The clamping ring which holds the seal on is 8 mm bulb which reusable. The seal has to be stretch over the outer metal casing.
Posted on Aug 21, 2011
We have a Frigidaire "Affinity" front loader it is leaving a puddle on the floor when we use it. I assume the rubber ring is bad has anyone changed it themselves? Is it a hard fix?
Are you sure it's the door seal? If it is they are normally just held in place with 2 metal rings, 1 at the edge of the seal at the door opening and one at the outer drum. Once you remove the front ring from the door opening you can gain access to the one at the drum. Removing the lid of the machine will also help and give you a bit more light.
Anyone with a bit of DIY know how should be able to replace it, an hour tops for a beginner.
Dec 29, 2012 | Frigidaire ATF6000ES Front Load Washer
Maytag epic z-ripped piece of door seal
I would say that the rubber may have gone into the system, and is probably clogging up the water outlet hose, and or the Pump. This is a bit of a "Fix' it will require the taking off of the motor and Hoses, connected to see where that bit of rubber is.http://www.letsfixit.co.uk/html/washing_machine_faq.html
http://www.appliancerepair.net/apnet/frameset?http://www.appliancerepair.net/apnet/washer/toc.htm
If you do not choose to repair this yourself, using those links above. Then please get a "Quote" for repair.
Mar 24, 2010 | Maytag EPICz 3.7 cu. ft. Washer
The rubber seal came off of the inside during the spin cycle - behind door against the tub -- and a wire ring came out. I put the rubber seal back on but have no idea where the wire ring would go? Is this...
The wire ring is the seal retaining spring, it fits in a groove at the rear of the door seal.
Double the seal back in the drum, and fit the spring around the seal at the rear of same, it fits inside a groove, it is difficult, so persist and be patient.
Please rate my solution.
Thanks.
Nov 03, 2009 | Bosch WFMC 3200 Front Load Washer
Lost Engaement ring in Washer
Non infield involvement rings are now pretty fashionable and a lot of women are point to realize their beauty. Amidst the knowingness of umpteen, non tract work rings were also the praise during the ancient and mediaeval nowadays. In fact, many gems are advised solon momentous than the diamonds. Emeralds for one were valued by ancient Moguls, business it their unspeakable designer. Rubies are also really rarified and are, until now, considered vocalist of all gems because of its unmated title and unrivaled exemplar.
Non Diamond Engagement Rings
Aug 17, 2009 | Frigidaire GLTF2940ES Front Load Washer
Wire ring that holds rubber seal on next 100 washer has come off
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer how to put back on wire ring, with a spring for tension, that holds the inner rubber seal in place.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to get back on, the metal ring around the seal.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 24, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
BOSCH: How to replace rubber seal (boot) of front loading washer
remove soap draw take screw out lower right.
remove boottom panel screw in filter flap push to the right panel comes off undo 2 x screw,take front lip off door seal off 2 screw from door interlock then front panel will come off you will beable to whole seal and spring cilp
slightly longer but easy you can see what you are doing.
Jun 30, 2009 | Washing Machines
Washer is ripping my clothes
yep, I have that problem too. My son's winter coat got wripped to shreds.
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE 110.4751 front load
soild metal part fits in groove around door boot spring goes in at bottom they can be tough to get back on after inserting in groove around seal you'll have to stretch the spring and pop it under at the same time band will try to come back out and roll seal back off lip..good luck
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
Miele W4840 Front Load Washer Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
