Question about Whirlpool GHW9150 Front Load Washer
Constantly getting F-H setting, can't correct
I have done everything they say in the book to correct this problem.  My machine isn't even 2 years old and I have had numerous repairs on it.  Any suggestions?  I have reset, u nplugged, over and over to no avail.
  • 1 more comment
  • gotdonkeys Dec 24, 2007
    I am also Constantly getting F-H setting, can't correct problem.
  • Anonymous Jun 01, 2008
    this unit does not have a flow meter ,already clean screens on water inlet ,cleared strainer at pump,checked echo valve .replaced pressure switch and hose ,still have f -h error code and cn not run diags on it any tips ???
  • Anonymous Jan 29, 2009
    Could be the motherboard. My motherboard on this model has blown up twice in the span of a year.
Are you using gthe right soap? (he) ,fh is related to volume and quantity of water getting in the machine ,first look at the screens on the water valves,then the flow meter,then check the echo valve and pump for no leaks or obstructions,then the pressure hose and the pressure sw.if all of these does work ok then prepre to replace ccu ;mcu and interfase boards this is a terrible code good luck
Posted on Jun 01, 2008
I have a craftsman Air-cooled, 2-cycle mini tiller.
first make sure the motor isn't engaged when trying to start it, and If it has been sitting for awhile, (in between seasons), It's likely that the carb is clogged, try cleaning it out, make sure the spark plug is firing correctly. And if it's getting spark, and its getting fuel, but still wont start, then the carb may need adjusting.
May 08, 2012 | Craftsman Garden
Frigidaire FRS26R2AW5 Refrigerator too cold on fridge side.
If the dampers are closing when you select warmer temp with the fridge temp control, there really isn't a way for the cold air to enter the fridge. Check to make sure the damper isn't opening back up after a while.
Feb 29, 2012 | Refrigerators
I have a Frigidaire ATF7000ES1 model. It's about 5 years old. Today when I did the laundry, it stopped by itself. I turned the knob, nothing happened. After awhile, the power was back on. I set it...
could be many things... possibly the starter capacitor is gone (google what this is if interested), but lets start simple... If the machine isn't getting water, this will make it stop. Check the taps are on, hoses hocked up, test hot and cold cycles, even pull out soap draw while ur at it and give it a good clean as soap always builds up anyway. But i am getting a feeling that ur machine is getting water otherwise you would have mentioned it. The other thing is to check that water is getting out ok. Is the pump blocked? Give it a clean anyway because everything you put into your machine goes through the pump, so it works hard. The good thing about these exercises is that you'll start to get to know ur machine. A good friend of mine once told me some advice when trouble shooting... "get to know how it works, and then you might find why its broken". And then check the switch on the door. The trip switch on the door prevents someone putting the arm in machine while its spinning at 1400 rpm. Hopefully by now you've opened up the machine to marvel at its inner workings... Check the obvious that wires seem connected and hose clumps are in their correct position. Lets turn our attention to the motor. Is there a belt? Is the belt on? Can u turn the drum around manually? (Do this with power off which you should have well and truly done by now). If these are all yes, lets check the motor on spin cycle - which we probably could have done before pulling case off. If it isn't spinning at all, check to see if there is a fuse in the cpu board (this is the brains of machine). If fuse blown, this could be due to motor gone or starter capacitor gone. let us know how you get on
Aug 16, 2011 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
My Front Loader washer will not fill with water, It makes the sound but water does not go into the machine. I was having a problem with the washer pausing itself continously and then making draining...
This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
Good luck,
John C
Apr 11, 2011 | GE WSXH208A Front Load Washer
BRand new installation of 1 year old machine we
hi,
I am a novice at front loaders but it sounds like it needs new suspension parts, namely springs, sounds like the machine had a hard life before you got it. since its used anyways it cant hurt to take the back off and see and study how it works and how the drums suspension works. you can try to find the springs at an appliance store. Im not sure if you can get springs directly from LG. LG's are a pretty good name brand, probably worth fixing..
good luck!
jm
Dec 28, 2009 | LG WM-2277HW Front Load Washer
Washer won't run, error code 8.8. and everything just blinks...
Un plug machine wait 1 min. plug back in... Should reset if not call the 800 number in the owners book
Jan 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool GHW9150 Front Load Washer Logo
50 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
