TV/DVD Neon 3770F instruction manual
Acquired the above tv but with no instructions on how to set it up.
scrodamoon
  • 659 Answers
SOURCE: F2-1000T Digital Set-top Box.
Red light is displayed when the product is in the Standby mode.
Green light is displayed when the product is in operation. if the unit is red press the power button.
DTV button on the remote controls your receiver
TV button well, that controls the tv
you are probably needing to click on the
AUX button on your remote to get your dvd player to be activated.
and the
TV/Radio button switches between those two.
When powering on your receiver for the first time after purchasing, the Installation Wizard is
automatically started. It immediately performs Channel Search.(You can run the Installation Wizard
in Default Setting.)
Please wait for finishing the Channel Search. If you want to stop
the Channel Search, select the OK button.
If the Channel Search is stopped or finished, the result of
Channel Search is automatically saved.
so if your not getting all the channels you should this would probably be a good step to do.
You can switch the current channel using one of the following methods.
1. Press the CH-/CH+ button.
2. Enter your desired channel numeric using the NUMERICAL (0-9) buttons to move to the
channel directly.
3. Press the TV/RADIO button to switch between TV channel and Radio channel.
You can set Audio or Video Output Control.
1. Press the MENU button.
2. Select Preferences using the button, and press the
OK or button.
3. Select AV Control using the button, and press the
OK or button.
When you connect an active antenna to the ANTENNA IN connector on the rear of the receiver.
1. Press MENU button.
2. Select Installation using the button, and press the
OK or button.
3. Select Antenna Power from Installation menu using the
button.
4. Press the OK or button to select On or Off .
On
5V power supply from the active antenna cable.
Off No power supply.
Posted on Aug 05, 2008
SOURCE: says "no disc"
I've found it works after the set has warmed up. I don't know what the problem is. The other thing is I will just keep ejecting - just hit the eject button over and over - open/close etc and after a while it plays. It's REALLY annoying
Posted on Aug 18, 2008
SOURCE: Lg LH-D6230. How to hook up? PLEASE HELP! NO INSTRUCTION MANUAL!!
je kan met 2 tulp aansluitingen via de dvd speler audio out naar je tv gaan en dan de instelling aux van de dvd speler gebruiken zo kan je surround tv kijken
SOURCE: Where can I download an instruction manual for the Grundig GUVCD2800
my tv can't turn on.power unit working but fly back transistor base voltage transformar no voltage.
please provide me solution and service manuan.
Thanks and best regard
Khan
Posted on Oct 17, 2008
  • 14 Answers
SOURCE: need instructions and manual for Tevion 8 in one control
u need to get a universal remote and a code book,then your most likely wont have any more problems
Posted on Feb 21, 2009
Total Control Universal Remote. URC 4140. What is the 4 digit code to operate the above TV
Search Results
    [PDF]Total Control URC-4140 - Universal Remote Control Codes
    www.remotecodelist.com/remotes/URC_4140_B00_and_B01.pdf
    UNIVERSAL. Remote control. URC - 4140 ... Your TOTAL CONTROL can operate four devices: a Television, ... The TV, VCR/DVD, SAT and AUX keys select the device.... 4. Enter your four-digit code using the number keys. The red light will blink twice.... To set up your other devices, follow the same instructions above, only.
    Codes and links for a number of universal remote controls, including Sony, RCA, ... GE Remote Codes, General instructions for GE Universal 3 and 4 digit remote controls. ... This manual may work for a number of Philips-Magnavox remotes. ... Total Control URC-4140, PDF Instruction Manual (remote also known as Crest .
Jan 13, 2016 | Sanyo 42 in. LCD TV
I have just acquired a Beko TV set,and need an instruction book to operate it. May I have oneplease?
if you please visit the link below you can find the user manual for your TV ..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
http://www.beko.co.uk/Manuals.aspx
Jun 13, 2011 | Beko 17WLB450S 17 in. LCD TV
I have a dvd player drc212 that i have no
Hi Tana,
If your TV is supplied with a video input, you will need a set of Composite Baseband video cables commonly known as RCA cables (Yellow, Red, White).
See the last paragraph if your TV is not supplied with a video input.
You will connect the Yellow (Video) from the DVD's video output, to the Yellow (Video) input on the TV set; example is VIDEO 1 or AV1.
You will connect the Red (Right Audio) from the DVD's Red Audio output, to the Red (Right Audio) input on the TV set using the same input number as example above.
You will connect the White (Left Audio) from the DVD's White Audio output, to the White (Left Audio) input on the TV set using the same input number as example above.
Turn on DVD, and TV set. Select the proper input on the TV set using the input button (video, source, AV select, etc.)
If your TV set is not supplied with a video input only a coax cable input, you will need an RF Modulator which can be purchased at any Best Buy, Radio Shack, Wal-mart, etc. You will also need a small coax jumper (3 to 6 foot should do it), and a set of RCA cables (Yellow, Red, White) as described above. The RF Modulator comes with instructions on how to connect it. It has a coax input, RCA input and a coax output that will connect to your TV set.
I hope this helps. Cheers.
Feb 09, 2010 | Televison & Video
Sony rdr vx410 dvd player playing some dvds in black and white
  • DVD's are standard definition video sources. Number of lines output is 576 lines, whereas your HD TV set has 720 or 1080 lines. This difference may result in a poorer image. However some DVD players are able to “upscale” picture to obtain a very good picture. Check if your DVD player has the following connectors: YUV, DVI or HDMI. For more information, refer to the instruction manual of your DVD player.
  • Some HDMI or DVI featured DVD players also have an internal processor that can upscale pictures from a DVD to 720 or 1080 lines to provide an excellent picture from a standard definition disc to your HD TV set. Those settings are available from the setup menu of your DVD player. Please refer to the instruction manual of your DVD player.
  • If your DVD player does not have those connectors and only has a SCART connector, or S-VIDEO, or composite, there is not much to do to improve the picture quality. Just make sure that you are not using the cheapest cables and that the picture settings of your TV set are correctly adjusted.
  • Some high end TV sets have a picture improvement engine that can soften a noisy image. Make sure that it is activated from the setup menu of your TV set. Please refer to the instruction manual of your TV set.
  • If people and objects have weird white outlines around them. This may suggest that your TV sharpness is set too high. Make the correct sharpness adjustments from the setup menu of your TV set.
  • Make sure you use good quality cables and that your cables are not too long (less than 5 meters long).
Jun 15, 2009 | Sony RDR-VX420 DVD Recorder/VCR
Missing instructions and no cables to attach to T.V.
yes, you can use generic cables to get camcorder picture in tv to burn dvd in dvd recorder attached to tv.
Please intimate model number of Panasonic camcorder to look for instruction manual for you.
Apr 09, 2009 | Panasonic Palmcorder PV-DV53 Mini DV...
Need instructions to set up Cyberhome DVD 1200 player
Useing RCA cables -(yellow video out) on the dvd go's to yellow video in on the tv. Then (red -right) out on dvd go's to red audio in on the tv . And white-left out on dvd go's to white-left audio in on the tv! and thats it
Dec 24, 2008 | Cyberhome Televison & Video
Unfinalized DVDs
What sort of "recognization" is your TV showing? Do you get a blue screen but no AV?...accordianman
Jan 15, 2008 | Samsung DVD-VR320 DVD Recorder/VCR
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
