Question about Microlife Health & Beauty
What does flashing heart symbol mean - Microlife Health & Beauty
2 Suggested Answers
  • 5221 Answers
SOURCE: what does the "heart beat" symbol/light mean?
I assume you mean the symbol that has a pair blackened circles and then a pulse up and then down below the starting line before returning to the starting line.
That is the paper jam symbol. If the continue light is on (steady) and the paper jam light is on, then you have a paper jam. Press Continue twice to see any secondary error message (this will show where the problem is).
See the manual for the list of the lights that show where the jam is occurring. Different groups of lights will be lit. The manual is available as a PDF at the bottom of this page: http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN . An example: if the Continue, Toner Low and Paper Jam are all on, then the jam is in the fuser area under the print cartridge assembly. For a paper jam, even a small corner of torn paper could be in the mechanism.
In all cases, you should check the entire paper path. When you pull out any paper, grip it so that you can gently pull the sheet straight out. Remove all paper from the output tray. Then remove the paper tray if you are using it. Pull any paper from this area. Press down on the green duplex flap and remove any paper from there Reinsert the paper tray. Open the front door of the printer and remove the print cartridge assembly. Lift the green flap and remove any paper from the area. NOTE: the fuser and the fuser area may be hot. Open the rear exit door and remove any paper from that area. Use a flashlight to check for small pieces of paper that may be stuck. Once all the paper is removed, reinstall the print cartridge assembly and close all the doors. Press Continue to reset the printer.
The page that jammed may be reprinted.
I hope this helps.
(please note that frequent paper jams may be a sign of excess humidity in the paper. Put less paper in the tray at each refill and keep the remaining paper in a dry location. If the paper jam light is coming on when no paper jam is present, one or more of the paper jam sensors may be bad. Contact Lexmark for more information.)
Posted on Nov 30, 2010
What does hand symbol mean?
it is your heart beat or your pulse. If you notice there is another number just below the blood pressure reading. that is your pulse.
May 07, 2017 | The Health & Beauty
A heartbeat symbol like on an EKG showed up by the pulse. What does this mean?
Check Owner's Manual. Most likely it means IRREGULAR HEART BEAT.
Nov 07, 2016 | Medical
When I took my blood pressure SOMETIMES there's a heartbeat symbol next to my pulse reading, but SOMETIMES NOT! What does that mean and what the difference?
If you give me the make and model I can try and find your instruction manual. Reply as a COMMENT.
Blood pressure monitors can also give you your pulse rate. When the heart symbol is there, it has found it and is counting and when the heart symbol is missing it hasn't. This would normally be caused by the cuff not being placed on the upper arm in quite the right location.
Apr 27, 2016 | Health & Beauty
What does the heart on the monitor means?
The blinking heart symbol indicates that the unit is slowly decreasing the pressure in the wrist cuff. This is when the unit is finding your Diastolic blood pressure. This is a normal symbol on most automatic blood pressure monitors. When a nurse or doctor uses a manual blood pressure cuff and listens to the blood flow, they will record the systolic pressure when they first hear the heart beat. Then they record the diastolic measurement when they can no longer hear the heart beat.
The manual for the KS-7902 is available here: http://pharmasupply.com/wordpress/pdf/wristman .
I hope this helps.
Aug 08, 2014 | Advocate Wrist Blood Pressure Monitor...
How do i get a heart symbol ?
Hi ls campbell! Where do you want to put your heart symbol? If you mean the ASCII code for heart symbol like this ♥ , then it is ALT+3 : just press ALT key (hold it) then press 3 (release alt and release 3) and you will have this: ♥
May 24, 2011 | Computers & Internet
I've lost the directions for the Mabis Wrist Monitor 04-235-001
The heart symbol means your pulse rate and the page is the memory page
Mar 28, 2009 | Mabis Blood Pressure Monitor Smartread...
Heart rate monitor reading "lo"
to shutoff HR out of range alarm - when selecting the ranges in the HRM Steup mode - press the START/SPLIT button to toggle the alarm on and off. (use the start/stop button on the pro fitness model). page 14 in my manual
Dec 12, 2008 | Timex Ironman Triathlon Heart Rate Monitor
Health & Beauty Logo
55 people viewed this question
Top Microlife Health & Beauty Experts
Colin Stickland
Colin Stickland
Steve
Are you a Microlife Health and Beauty Expert? Answer questions, earn points and help others
