Question about Kodak EasyShare V610 Digital Camera
Kodak service manual for V610 - Kodak EasyShare V610 Digital Camera
5 Suggested Answers
mads_aye
  • 58 Answers
SOURCE: Kodak Camera V610 easy share
Hi!
This is what I need you to try..
If you're using a 5v ac adapter to charge the camera's battery - please hook it to the camera WITHOUT THE BATTERY in it. The 5v ac adapter can be an alternative power supply.
Turn on the camera - check if it would do the same thing - like lighting up, making a noise (attempting to extend the lens) and closes. If it does, the camera needs to be sent in for repair.
visit www.kodak.com/go/itg to arrange repair
If you are using a photoframe dock2 or camera dock series 3 to recharge the camera's batt - use its 5v ac adapter. It will work with the cam. Make sure, the batt is not in it to check the cam's condition, isolating the possible interference of the battery.
If the camera works fine - when the AC adapter is attached, no battery in it - consider buying a new battery.
V610 is a very nice camera, but it was manufactured in 2006. If you have not replaced the battery yet, it might just need to be replaced. Even Li-ion rechargeable batteries wear out eventually - it can only last up to 300 charging cycles.
If you're using a batt that is less than a year old, the cam might just need to be sent in for service.
Posted on Nov 29, 2008
praky16
  • 744 Answers
SOURCE: Kodak V610 Camera error #45
hi...
The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Posted on Aug 18, 2009
  • 415 Answers
SOURCE: ERROR E45 KODAK V610
please see this
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=8962/7269&pq-locale=en_GB&expression=e45
Posted on Jan 22, 2010
lock123
  • 6831 Answers
SOURCE: Kodak EasyShare V610 "Camera Error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Dec 14, 2010
Cannot format a 4 GB SDHC Card for in my KodakEasyShare V610
The V610 works with MMC and SD cards, not with SDHC cards.
Aug 12, 2011 | Kodak EasyShare V610 Digital Camera
Kodak V610 Easyshare won't turn on
You have a board power supply issue which would be covered under warranty. (Hopefully you still under warranty)
Aug 19, 2007 | Kodak EasyShare V610 Digital Camera
Camera error #e45 kodak digital camera v610
Hello :
This means the lens alignment of your camera is messed up and it will take repair service to fix it. The cost of this might be equivalent to replacing the camera- Better to call KODAK and see what they're willing to do for you.
Not supported solution is to smack the side of the camera . That helped some people with the same error .
Please read this useful link carefully : Kodak cam errors forum
I hope this will help .
please don't forget to rate !
Apr 06, 2010 | Kodak EasyShare V610 Digital Camera
My shutter is broken on my Kodak V610
I'm afraid your camera needs a repair. There's no other way. Contact Kodak under 1-800-421-6699.
Mar 10, 2010 | Kodak EasyShare V610 Digital Camera
E45
"E45" appears on your camera's display when your camera requires service or repair. It also something to do with your camera lens
**Kodak support line at 1 800 235 6325 (23KODAK) or visit the website www.kodak.com/go/stepbystep
Nov 17, 2009 | Kodak EasyShare V610 Digital Camera
My camera error # e 45
This is a lens fault and unfortunantly the cam. needs a repair.
In order to arrange the repair: Pls. contact your dealer or KODAK directly:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=4248
Sep 27, 2009 | Kodak EasyShare V610 Digital Camera
Camera blanks out with message- error 45 and its not coming on
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 02, 2009 | Kodak EasyShare V610 Digital Camera
Kodak V610, Lower lens not working
I had the same problem. The lower lens wasnt working, but if i zoomed enough the screen would turn back on.. Heres what worked for me.. go into menu, select setup menu, then select digital zoom. and select "off" . now the botton lens should work. take a picture, and then go back into digital zoom menu and select on, and all the zoom views should work!
Oct 07, 2008 | Kodak EasyShare V610 Digital Camera
Kodak EasyShare V610 Digital Camera Logo
50 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
