Question about Dewalt Drills
Dewalt dcd785 18v power good but when pressure is applied drill or screwdriver, nasty grinding sound occurs. Transmission?
Drill was dropped , noe exhibits a grinding sound when pressure is applied. Samr wirth Hammer drill selected same with either speed 1 or 2. I didassembled and could see no obvious breaks in the housing. BAttery and motor seem ok.
4 Suggested Answers
  • 313 Answers
SOURCE: dewalt dc 988 cordless drill
posible motor problem, the built in magnetic ring in the motor may broken inside or just to much dust in it. advice when replacing motor also replace th switch for the cost $132.00 plus tax canadian. thanx
Posted on May 24, 2008
emissionwiz
  • 79847 Answers
SOURCE: Dewalt cordless drill
You have burned out the drill motor, it is shorted, the battery smoked due to a direct short, one thing I don't understand why the thermal limiter didn't trip in battery pack, I would contact manufacturer and try to get hem to buy you a new drill.
Posted on Aug 29, 2008
rowdy45176
  • 2176 Answers
SOURCE: I have a DeWalt DW927 cordless drill. It's lost
the brush assembly slides out of the back of the motor. I suggest going to Dewaltservicenet.com and downloading a breakdown for this tool before starting. I don't think that the brushes are going to be your only problem though.
Posted on Dec 22, 2009
My dewalt 20v liion dcd780 just started making a funny noise. that sounds like the chuck is engaged but it is still spinning.
N267879 or N384357 its where more numbers to order i have found BUT LOOK for the right neccesary type number of your dcd780 tool because of maybe possible marketing technical differences noches and other to fit or mounting differences of this planet gearbox (transmission assy) should be defect on one or 2 gears its only one part to order and its thinking also not cheap
Detail
Oct 01, 2015 | Dewalt Drills
Under heavy load, driver slips, makes grinding noise. How to fix?
Sounds like the gears are worn out. Not worth fixing. But if you buy a drill that uses the same battery pack, now you will have a spare battery and charger.
Jul 18, 2014 | Dewalt 18v Cordless 1/2" Adjustable Clutch...
Grinding noise at high rpm
Have you had fuel pressure tested, as well as exhaust for possible plugged catalytic converter?
May 20, 2014 | 2004 Kia Sedona
Dewalt 18volt drill was dropped 4 ft on floor. now wont work. time for a new one?
You can actually send it back to Dewalt and if it is still under warranty they will fix it or if not under warranty they will fix it for 40 bucks
Apr 10, 2012 | Dewalt Drills
THE CHUCK WON'T TURN WITH THE MOTOR RUNNING. YOU CAN HOLD IT IN YOUR HAND AND FEEL IT CLICKING AND HEAR IT WHAT COULD BE WRONG WITH IT?
The DCD950 drill has a chuck that does not require the reverse-threaded lock screw. It is put on with lok-tite and a good deal of torque. It is hard to remove without the Dewalt vice tool to hold it but not impossible. Some can be removed by tightening the chuck in a vice and, using the drill handle for leverage, apply steady, even, strong pressure until it breaks free. Using this method usually bends the part of the chuck in the vice making it useless. Another reason for the chuck not turning when the motor is turning is a broken transmission. If the chuck works properly in tightening down and releasing bits, your problem may be in the transmission. If you go to http://www.ereplacementparts.com/ and search for your model number you can look at a breakdown of your drill and what you're looking at to replace the transmission.
Feb 12, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
Problems with torque clutch in new DeWalt tranmission
hi
like most clutches on hummer unit after the assembly has been done you will a way to tighten the spring clutch look for adjustment to make the spring looser and tighten
Mar 10, 2017 | Dewalt DC925 Cordless Drill
Dewalt drill won't work in 1st gear then it kicks in and works
You could have lost one teeth on the gear wheel . Once it is rotating the system will not miss the lost teeth, until you loose some more teeth then you will loose power and the drilling will become jerky and might even stop on applying pressure
Mar 08, 2011 | Dewalt DrillRecip Kit 18V
Dewalt 28v drill/driver making screeching noise
No, this is not normal. Take it back to your retailer and let them know about the problem.
I have a few tools that will get a little noisy and it is cold out - as in lower than 15 degrees - but it goes away as the tool warms up.
Your problem sounds like clearance issues within the drill, and just dealing with the noise could be damaging the tool further.
Oct 12, 2009 | Dewalt Drills
DW988 1st and 2nd gear doesnt work, 3rd gear works
You may have put it back together wrong, but you may also need a new transmission. 99% of the power tools I work on where the gears are slipping is caused by the transmission or gear box (both names are used interchangeably).
Good luck to you!
Don-www.toolsandmachinery.com
Feb 19, 2009 | Dewalt Drills
Drills Logo
57 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
