Question about Toshiba Office Equipment & Supplies
F350 error code
Next to a FW update i got a F350error code on the front panel
2 Suggested Answers
  • 60 Answers
SOURCE: Trying to upgrade H/D on IBM T43 laptop, get 2010 error on
Error code 2010 is definitely hard drive problem.
Did you get the firmware from the site below?
Link to hardware maintenance manual for reference:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/39t2393.pdf
Here's the fix straight from the maintenance manual:
If in the primary bay the customer is using a non-IBM or non-Lenovo hard disk drive (HDD), or an old generation IBM HDD which is not supported by this system, with the risk in mind, the customer can still use it by pressing ESC. If in the primary drive bay the customer is using a supported IBM/Lenovo HDD with an old firmware, the customer needs to update its firmware to the latest. The latest version is available at http://www.lenovo.com/think/ support
Posted on Apr 07, 2009
Wrong code : 00000018-4489-957-0000 what to do ?
The erorr code 00000018-4489-957-000 which you can see on the LCD is problem connected to the lens block.You can try download lates FW for R727 from google.(Last FW version is 3.02.15).
Then extract exe file and copy FW file to the SD card.Put SD card into the camera and close battery door.Hold Shutter button and power on camera.After FW update is complete just power off camera.If the problem still stay you can try to remove covers and disconnect and connect again Flexi Print Cables (connection between Lens and main board).Then you can try again FW update.If this solutions will not help you will need to send camera for repair to the repair shop.As your camera will be probably out of warranty repair will not be economical and maybe will be better to buy new camera.
Hope helps.
Aug 05, 2011 | HP Photosmart R725 Digital Camera
Need the tv code for a vr-4085df
Hello Rickd971, there is a FW update that will allow you to program your remote to the TV. Please send me a quick email to westytech@westinghousedigital.com with the serial # TW# and a contact # in the event I need any other information and I will forward you the FW along with installation instructions.
Feb 15, 2011 | Westinghouse Electric VR4085DF TV
How do you reset an HP R727 camera?It comes up saying it has experienced an error 5555AAAA-61EE-14B-031 as soon as you switch it in. Battery is fully charged.
Normaly the repair service reset camera by using special file on the SD card.This file is impossible to find it on the internet.But you can try to update FW maybe it will help to this error message.You can try download lates FW for R727 from google.(Last FW version is 3.02.15).
Then extract exe file and copy FW file to the SD card.Put SD card into the camera and close battery door.Hold Shutter button and power on camera.After FW update is complete just power off camera.Then try it again to swith on.If it will not help the only way is send camera into the repair service.
Best Regards
AIOS
Apr 17, 2010 | HP Photosmart R727 Digital Camera
IBM Autoloader 36232sx error code A027 & A060
A0= Error occurred during carousel movement (position not found). Could be caused by a carousel motor power issue, a missing or misaligned cartridge carrier, an obstruction, or an unexpected cartridge in the carousel path.
I also advise you to update the FW of the loader.
Are you having tapes get "Stuck" in the unit?
Feb 01, 2010 | IBM Computers & Internet
Macbook pro does not find canopus acdv110
How did You connect Canopus? Canopus has 2 Firewire slots - on the back and on the front. If You connect FW cable to a front slot, then, Canopus will not work. Only with external power supply. I´m offering the next proceeding:
1. Connect ADVC with FW cable 6 to 4 to Your macbook via back FW slot. The ADVC lights will now on. On front panel by default light is on mode "digital". If the light don't work - it's a Canopus problem. If light is up and working, then next step.
2. Go to apple menu-about this mac - more info - firewire. You MUST see here Your Canopus a a device. If so, go to the next step.
3. Connect Your VCR to analog inputs, on the front panel of Canopus.
4. Run FCE. If it says "apple firewire device is missing" then is something wrong with Canopus. If not, proceed to next step.
5. On the top of the front panel of Canopus, press button. The light changes from digital to analogue.
6. Press apple+8, then capture settings. Set the firewire device as uncontrollable device. Make sure that in capture window is "vtr ok". Turn the VCR on
7. Press the play button on capture window. In the window appears the screen of Your VCR. Then press play on VCR and then "capture now" on capture panel. Voila! Must to work.
Aug 30, 2009 | Televison & Video
SPL-C ERROR-Including Corrupt Data position : 0x16091 (90257) System : src/xl-image Line : 531 Version SPL-C 5.24 06-28-2006
It's a printer Main Board Problem, maybe you can try to make a FW Update.
When the problem is still their after the FW Update you have to call the service.
Greetings from Germany
Aug 07, 2009 | Samsung CLP 300 Laser Printer
Mar 13, 2009 | IBM ThinkPad T43 Notebook
Getting dadadada error code on psp? how do i fix?
Hello Sir =)
DADADADA - Running a FW Update in DAX custom FW
Jan 10, 2009 | Sony PlayStation Portable (PSP) Console
61 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
