SOURCE: On the LG VU CU920, how do you set ringtones as message alerts?
After going through the manual and talking to an AT&T rep, I found that it is not possible to set your own ringtone as a message alert tone. You can only use your own ringtones for calls and ringer ID's. We're stuck with the 10 pre-loaded rings for the message alerts. :(
SOURCE: I cannot change the message
It took me many hours to work it out!
- Menu.
- Settings.
- Phone settings.
- Phone profiles.
- Select (highlight) the one you want &.
- Select OPTIONS with the left soft key.
- Click Edit (1).
- Use the directional key (right) to highlight the New Messages.
- Scroll down to Message Alert.
- Left soft key OPTIONS & select edit (as above).
- Then click the directional key until you hit either Downloaded Music or sounds (depending on where you stored your sound file).
- Select your file.
- Left soft key & select SAVE.
- Then that's it, done!
Please email me with if it works for u or not. [email protected]
SOURCE: message alert tone for cect sciphone i68
If you have version 3 software there is no way that you can use mp3 or downloaded tones as message tones, best thing you can do is upgrade your firmware to version 4. Type this on the dial screen to check your version *#8375#
SOURCE: ringtones to message alert tones
for this check out this website www.lg-vu.com
but to do so make sure you have a data cable
SOURCE: changing ringtones and alerts on sony satio
I believe that you go into settings/personal/profiles. There you can highlight an existing profile or create a new profile. When you highlight a profile you can select option button, then tap personalise and this with give you options to change ringtones, ring type, message alerts etc. Hope this helps
Testimonial: "thanks mate thats done the trick."
