Question about Princeton Tec Impact XL Overmolded 65 Lumens LED Flashlight
Will not turn off
Light is suppose to turn on and off by twisting the head. It comes on but will not turn off with a twist.
How to change the right front turn pulb? 1998 ford taurus
unbolt the headlight (4 bolts on top, one of then is a tightening bolt, a long skinny bolt, try loosening that one, you can tell which one it is 'cuz there is no bracket on it.). Remove it then go in from the side you should be able to just reach the bulb socket, I think it twists out,you should be able to twist it with your fingers.
Jul 30, 2011 | 1998 Ford Taurus
We are trying to change a head light in the truck but the head light cover looks like its sealed with glue is that normal its not comeing off easy
The head light is a lens, the bulb is replaced, the bulb is at the rear of the head light under the hood, the retainer twists off and then the bulb is removed.
Mar 03, 2011 | 2005 Ford Explorer
HOW DO I CHANGE THE HEADLAMP BULB ON MY 07 AVALANCHE
there are two rods one on each side, silver in color or black, just twist and lift them right out. the light will then just come right out
Jul 31, 2010 | Chevrolet Avalanche Cars & Trucks
Replacing headlight bulbs on 2005 volkswagen
open hood and head light bulb should be on the back of the head light casing just twist the socket to take out ,replace bulb and twist back in
Jul 06, 2010 | 2001 Volkswagen Beetle
How do you change the head light on a 98 dodge avenger?
There are clips on the lense take those clips off remove the bulb by twisting and pulling then unplug it get a new one but you are not supposed to touch them with your hands use gloves.
Mar 05, 2010 | 1998 Dodge Avenger
How do you change the front turn signal bulbs on a 2001 Mercury Grand Marquis LS?
open hood you will see a long black panel across the front. this panel is called a sight shield you will see 3 "twist clips" one on ether side of each head light and one right by the hood latch . twist all 3 and remove panel.at this point you will see the light sockets.each headlight assembly has 2 retainers. simply unlatch the retainers and the lamp assemblies come out easily and you have access to the bulbs.
Dec 15, 2009 | 2001 Mercury Grand Marquis
Fog lights turning on, draining battery 02 Jeep Wrangler Sport
just remove the wires going to the fog light bulbs. near the front of the car. dont forget to tape them
Jun 03, 2009 | 2002 Jeep Wrangler
I just bought a 99 sebring limited and didnt ask how to turn on the fog lights So how do I
On the steering column. There is the yoke to twist to turn on the head lights. Well on that same yoke, underneath the buttom side facing the dash, look for a little lever, or on some a tiny sliter. Tun on the headlights first, then move the lever. This will turn on the fpg lamps. They will not come on without the headlights on.
Mar 28, 2009 | 1999 Chrysler Sebring
How do you change the bulb for the turn signal on the front passenger side for a 2007 ion coupe
their is a cap behind the head light its either rubber or plastic pull or twist it offt and then twist light out
Jan 25, 2009 | Saturn Ion Cars & Trucks
Replace the bulb in a 95 Blazer 4WD switch on the dash
the square box that all 3 lights are held in by can be taken out, just pry it on the top or bottom with a flat head screw driver, once you get it out you should see the wires that connect to the buttons,there are four tabs, 2 on each side, that you can just push in and the back panel should come off, it will look like a circuit board. twist the light bulb left or right and you should see how it comes out, just replace the bulb, and put back in and twist. should only have to twist 1/4 of a turn. snap everything back in place and it should be working. hope this helps.
Dec 29, 2008 | 1999 Chevrolet Blazer
Princeton Tec Impact XL Overmolded 65 Lumens LED Flashlight Logo
35 people viewed this question
Top Princeton Tec Camping, Backpacking & Hiking Experts
Tom Chichester
weirdtop
Are you a Princeton Tec Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
