Question about Panasonic Office Equipment & Supplies
How to reset memory of panasonic kx-ft931
Can not receive and send only display connection them return to normal display
leroyal
  • 2120 Answers
SOURCE: ''Document Jammed'' error message
Open the document feeder and look for a switch actuator stuck in the down position.
Posted on Nov 20, 2008
FixinFax
  • 3085 Answers
SOURCE: Fax Memory Full?? Panasonic KX-FHD331 -- just
Unplug the power cord for 2 mins.
Posted on Aug 29, 2009
  • 68 Answers
SOURCE: My Panasonic Fax machine KX FHD331 is not
Make sure there is no additional error messages on the screen - they usually show in a sequence one after another - maybe paper not loaded correctly,or machine is jammed or out of thermal film.
Posted on Oct 04, 2009
  • 567 Answers
SOURCE: hello , \r\ni call from iran . I WANT reset the
Hi
  • Plug the power cords in, push the power buttons on and get everything up and running. Sounds simple, but lack of power is the culprit quite often.
  • Step 2Check for a phone connection in the correct input jack. Some printers with fax capability have more than one phone jack so you can hook up an answering machine or another phone "downstream" from the printer. Consult your instruction manual to determine the right connection for your printer.
  • Step 3Swap out the all-in-one printer for a working phone to find out if the problem is in the phone line coming from the wall. Once you hook up the phone, you should get a dial tone if the line is working. Remember to reconnect the all-in-one printer after you're done.
  • Step 4Open up the machine and examine the feed path for the documents that you fax. Clear any obstructions you may find. Repeat this process with the paper tray and the path that copy paper takes through the all-in-one printer.
  • Posted on Aug 08, 2010
    SOURCE: panasonic fax kx fp342 regarding
    Hallow just test to check feeder roller for input tray if is function
    Posted on Dec 31, 2012
    CO problems
    Check your Phone if connected to Jack 01 to do programming below:
    on KX-T7730 phone Press Program *# (enter Password) default is 1234
    Press 400 SP-Phone(CO NO.? will be displayed) Press *(Mixed or Connect will be displayed), Press AUTO ANS/MUTE untill (NOT Connect will be displayed) Press AUTO/STORE. Press HOLD(SYS PGM will be displayed) Press 400 (CO Connection will be displayed) Press SP- Phone(CO NO.?) Press SP-Phone (Not Connect will be displayed) Press AUTO ANS/Mute until (Connect will be displayed)Press AUTO/STORE PRESS PROGRAM to return to NORMAL Display.
    For the incoming Calls PRESS Program *#1234 (ENter Sys PGM will be displayed) PRESS 408(Day IN CO will be displayed) Press SP Phone (CO No? will be displayed) Press SP Phone (CO1:#01:DISABLED if this is displayed PRESS AUTO ANS/MUte the Enabled will be displayed) Press AUTO/STORE. Press Program to return to normal display. In this Manner All Calls will ring to extension which is connected to Jack 01. you dont need to press the button anytime there is an incoming call.
    Dec 04, 2013 | Panasonic KX-T7730 Corded Phone
    Panasonic kx-ft77 paper jammed and fax im memory
    I have a problem with the fax machine in question is panasonic kx ft77 . When receiving a fax error expel warm up and stop receiving the document. Or does anyone know what the problem is and how to fix it ? Thanks in advance
    Aug 16, 2013 | Panasonic KX-FHD331 Plain Paper Thermal...
    Display screen shows "Will return soon" Would like
    You need to cancel absent message on your phone. The method depends on which Panasonic phone system your phone is connected to. Following are the methods for three different Panasonic phone systems. Once you cancel absent message, your screen should return to date and time, if not then press * until it does.
    KX-TA624 Phone System
    Press intercom button, dial 750#, lift handset then return handset to cradle to end.
    KX-TA1232 Phone System
    Press intercom button, dial 7500, lift hanset then return hansdset to cradle to end.
    KX-TDA100 or KX-TDA200 Phone Systems
    Press intercom button, dial *7500, lift handset then return handset to cradle to end.
    Jan 27, 2011 | Panasonic KX-T7633 Corded Phone
    Panasonic KX TG2237 - Handset lights up but displays message "no connection to base unit"
    Unplugged and reinstalled all components. In the process I discovered a GFI circuit had tripped. When I reset the circuit breaker all was well. Problem solved.
    Jan 06, 2010 | Panasonic KX TG2237 Cordless Phone...
    I have a problem with panasonic kx ft938 showing "fax memory full". How can i clear it?
    The memory is full of received documents due to a lack of paper, or a paper jam.
    Install paper or clear the jammed paper.
    or, unplug the unit for about 5 minutes.
    or, to clear the RAM, try one of these procedures:
    (If the first one doesn't work, try the next one)
    1.
    Press menu 7 dial dial dial dial * 6 start
    Press up-arrow key until the display reads shipment set then press start
    The display will read reset counter
    Select yes or no then press start
    2.
    Press # 7 dial dial dial dial * 6 enter
    3.
    Press standby set dial dial dial dial * 6 start 9 9
    On success, a long beep will be heard
    4.
    Press menu 7 monitor monitor monitor monitor * 6 start
    Parameter 65 for memory collation should be set to invalid to maximize the memory page rating
    Nov 27, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
    Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
    Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
    Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
    189 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    CheckitRight
    CheckitRight
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Mitch S
    Mitch S
    Level 1 Expert
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
