Question about Bosch WFMC 3200 Front Load Washer
Bosch nexxt 500 wfmc3301uc washer will not stop filling with cold water, not even when push start/pause.
The washer will not stop filling with cold water and this causes the drain to kick on and drain throughout the entire cycle. It does not stop filling even when the cycle is finished and will cause water to leak out into the floor. There is no error code showing. What could cause this problem?
  • 1462 Answers
SOURCE: my bosch nexxt 500 series washer won't spin
possibly the motor brushes.
take back panel off. disconnect motor. remove bolts holding motor in and take out motor. check condition of brushes
Posted on Oct 18, 2008
SOURCE: Bosch Nexxt 500 Series Washer Will Not Add Water
during a normal wash cycle the washer stopped and gave an e;4 error code
Posted on Dec 28, 2008
57 varieties
  • 1653 Answers
SOURCE: I have Bosch Nexxt 500
The error indicates that the machine has taken too long to drain the water. Do the following.
  1. Switch off the machine and disconnect the mains power.
  2. Remove the access panel on the lower right front of the machine.
  3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Posted on Oct 23, 2009
  • 414 Answers
SOURCE: Bosch Nexxt 500 WFMC3301UC Front Load Washer is
It sounds like it may be the hot water valve, the valve itself may be leaking or the water pressure from your hot supply may not be high enough to 'lock' the valve fully when not energized. The second problem could be rectified by using a 'y' piece splitter on you cold supply and running both valve on cold water,
Link to parts diagram valve is position 407.
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WFMC3301UC%2f16&ESHOPTYPE=S
Posted on Jul 08, 2010
Testimonial: "Thanks for your quick and accurate response. The hot water valve inside the unit is leaking and needed to be replaced. I had a service technician come in to replace the valve."
  • 414 Answers
SOURCE: Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Posted on Jul 12, 2010
Bosch Nexxt 100 washer will not fill with water.
Does the problem occur on both hot and cold washes. If not then check the inlet solenoid . If yes than check the board.
Jan 25, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch 500 series wfmc3301 bosch washer does not stop running the water during a cycle . even will do it with the spin and drain cycle. Even attempting to turn the washer off it will still run and then once...
You have a bad water supply valve which is struck in the on position-this valve is mounted inside the machine right where you attach the supply hoses-cheers Denny
Oct 24, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I can't get my bosch nexxt 500 washer to wash in cold water - even when I turn off hot, the washer won't fill
Some washers mix some hot water with the cold during filling to dissolve detergent. I had to learn that too!
Aug 02, 2013 | Washing Machines
What is error message E-02?
Check the user manual for a troubleshooting guide. There is a link attached in case you no longer possess a manual. http://www.retrevo.com/support/Bosch-WFMC3301UC-Washers-manual/id/925ci465/t/2/
May 06, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch Nexxt 500 WFMC3301UC Front Load Washer is leaking water somewhere inside the unit. It is only doing this from the hot water source. All connections are tight and there are no external leaks. The cold...
Jul 08, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Looking for part number of the Transit/transport Bolts
Hi
Thanks for using FixYa. Please check these links for the parts of your Bosch washer:
Bosch WFMC3301UC Parts
Bosch WFMC3301UC Parts-2
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 14, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Washer leaks when it isn't packed full of clothes.
check your door seal if leaking in the front if the back its probably one of the water lines leaking
Feb 24, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Dec 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosh washer won't dispense softener. cleaned the tray and tested it by filling with water and it drained completly out, so i know its not clogged. washed another load and softener still there at end of...
I had the same problem. the only thing that works for me is fulling the fabric softener compartment all the way to the top with water then it will syphon down! it adds it to the load at the start instead on the rinse cycle but its better then nothing!
Jul 28, 2008 | Bosch Washing Machines
Bosch WFMC 3200 Front Load Washer Logo
87 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
