Question about Tablets & eReaders
Iluv mobitour will not pair with my ipad
Iluv mobitour /isp202
Can I pair my vivosmart3 from ipad
I can pair mine with my iPhone using the Garmin connect app from the app store, so I would guess that the iPad would work, but I don't have an iPad.
Dec 04, 2017 | Tablets & eReaders
How do you use the Apple Pen with the iPad pro
hi marilyn.
The first time you use your Apple Pencil, take off its cap and plug it into the Lightning connector on your iPad Pro. When you see the Pair button, tap it. After you pair yourApple Pencil, it will stay paired until you restart your iPad, turn on airplane mode, or pair with another iPad Pro.19 Sep 2017
Use Apple Pencil with iPad Pro - Apple Support.
How do you use the Apple Pen with the iPad pro Google Search
Nov 01, 2017 | Apple Tablets & eReaders
My iPad won't pair with my cricut air 2. It had paired before at my old house
Delete the entry and re-pair it. Make sure you press the button on the Cricut that sends the signal to the iPad. This is the part that people always forget. The iPad says searching, but it is searching for the signal that the you have told the device to send. If you don't do that, they will never pair.
Dec 24, 2016 | Apple iPad Tablets & eReaders
How to pair lg Bluetooth headset with ipadair?
on your iPad go to setting-> then down to bluetooth. on your headed set Press and hold the multi-function button for 10 seconds until the indicator light turns blue. It is now in pairing mode. it should show up on your iPad, click on your headset and it should pair.
Nov 26, 2015 | Apple iPad Air
Cannot get bluetooth keyboard to connect
Make sure the keyboard does not have a pairing relationship with another device in the room.
If there are any devices listed on the iPad, in Bluetooth settings, tap 'I' and forget Device.
Place the keyboard in pairing mode with a 5 second depress on power from the 'off' or no power state.
Type the keys on the keyboard that the iPad wants for the pair.
Aug 13, 2015 | Apple iPad Air
Cannot get ZAGG keyboard pair to iPad
Check that the keyboard's battery is working and it's on. Turn on Bluetooth on the iPad (Settings > Bluetooth). Press the keyboard Connect button. Choose the ZAGG Keyboard on the iPad, and type the code on the keyboard.
This doc describes the process: http://cfprod.zagg.com/downloads/ZAGGfolio%20instructions/ZAGGfolio%20instructions.pdf
Good luck! :)
Mar 25, 2014 | Apple iPad Tablets & eReaders
How do I connect my iPad with another iPad via Bluetooth
You have to have the 2 iPads basically side by side. Then you go to the bluetooth section on both. Then on each one it will come up with the name of the other iPad. The beside the name on each one it will say "not paired". Click the name on both iPads. Then it will pop up asking if you want to pair with the other iPad. Hope that helped.
Sep 06, 2013 | Apple iPad (16 GB) WiFi Tablet PC
Imm727 will not charge ipad, i phone.
I have the same problem and found no solution. I realized this issue after upgrading to iOS7 iPad. With iOS 6 functioned normally to load, then not.
Mar 09, 2013 | iLuv Creative Technology iLuv iMM727...
Tablets & eReaders Logo
66 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
