Question about Radio Shack Pro-95 Handheld Scanner
Keypad does not respond - Radio Shack Pro-95 Handheld Scanner
The smart wash light on my kenmore elite model 66513753K602 is flashing. I have tried the suggested button sequences to reset it and they have not worked. How do I troubleshoot it to determine which...
From the tech sheet:
CHECKING KEYPAD
OPERATION
A rapidly blinking LED over
one of the keys of the keypad
(or sometimes a "dead"
keypad/console) indicates one
or more key switch lines are
stuck or shorted on either the
control or the keypad. To
determine if the control or
keypad is faulty, do the
following test:
1. Unplug dishwasher or disconnect
power.
2. Open the dishwasher door.
3. Open console and disconnect the
keypad ribbon connection from
the control (at P1). Make sure all
other connections are made.
4. Put console back together. Do not
close the dishwasher door.
5. Plug in dishwasher or reconnect
power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
? If the control is OK (no longer
sees shorts with the keypad
unplugged), it will respond by
turning on a Drain Motor for
2 minutes. Check and/or
replace the keypad if the
control responds OK.
? If the control is not OK (still
unplugged), then the drain
motor will NOT respond and
will remain off. If no response,
replace the control.
Jan 21, 2015 | Kenmore Dishwashers
My gas range keypads will not respond to what i press and displays se error
You might well have a bad control board. I will suggest you to get a spare and go from there. The prices can easily be the same as a brand new range. Good Luck!
Jan 13, 2014 | Samsung FX510BGS
Whirlpool quiet partners II normal light flashing
CHECKING KEYPAD OPERATION
A rapidly blinking LED over one of the keys of the keypad (or sometimes a "dead" keypad/console)
To determine if the control or keypad is faulty, do the following test:
1. Unplug dishwasher or disconnect power.
3. Open console and disconnect the keypad ribbon connection from the control (at P1).
Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 seconds.
If the control is OK (no longer sees shorts with the keypad unplugged),
it will respond by turning on a Drain Motor for 2 minutes.
Check and/or replace the keypad if the control responds OK.
If the control is not OK (still sees shorts with the keypad unplugged),
then the drain motor will NOT respond and will remain off.
If no response, replace the control.
Dec 18, 2013 | KitchenAid 24 in. KUDI02IR Built-in...
Keypads will not respond. Either can't turn on or
Possible power supply problem--low voltage from master unit or dead batteries at each switch. Good luck!
Jul 25, 2010 | Lutron Electronic Low-Voltage...
Keys are not responding
Hello, what makes a phones keypad not to respond is when the IC that controls the keypad inside the phone is bad, it makes the keypad to freeze.
Also if there is dirt in the keypad, it can also cause the phone keypad to freeze.
To rectify problem you will assistance from a phone technician.
Jul 03, 2010 | Nokia 6120
Craftsman keypad not responding
On the back of the motor unit near where all those white wires go you will find a button. Press and immediately release that and then walk over to your keypad and enter a four digit code of your choice and press enter. You should be good to go.
Jun 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
W600i keypad won't respond
The PIN code is a code that unlocks the sim card. You can get this code from your mobile operator.
May 02, 2008 | Sony Ericsson W550i Cellular Phone
Radio Shack Pro-95 Handheld Scanner Logo
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
