Question about Pride Health & Beauty
Scooter controls seem reversed
I have a Pride Pathrider XL scooter, which I bought 2nd hand. When I pull on the RH throttle back the scooter reverses.. Pulling on the LH throttle sends the scooter forward. I believe this is the reverse of normal. The wiring all looks OK, but looks as if the throttle pot has been replaced. The red wire from the pot is connected to the red wire on the plug. Similarly for the black and blue wires. However the wires on the matching socket have different coloured wires. Can you help? Regards John Hartland
  • 32 Answers
SOURCE: no movement, forward or reverse
sounds like it is in neutral, look for a lever on the bottom, rear of the scooter to pull up
Posted on May 07, 2009
FixinFax
  • 3085 Answers
SOURCE: Forward/Reverse switch not working Revo Pride
Could it be in free-wheel mode. Most Prides have a pull up knob at the rear of the scooter.
Posted on Jun 18, 2009
  • 13 Answers
SOURCE: golden companion 2 scooter moves slow in reverse
i would suggest there is either a loose connection or the speed control has failed, the scooter will still run but at a slow speed, the part is fairly standard in all scooters. if i can be any furthur assitance please email me rick @ lxrixta.co.uk (remove the spaces)
gewiz
  • 1271 Answers
SOURCE: My Pride Legend 3 wheel scooter will not go
Hi, sounds like the speed pot that is attachment to the throttle lever is worn and needs replacing, this is normally a 5K pot,
Regards
GeWiz.
Posted on Feb 19, 2010
  • 46 Answers
SOURCE: Pride Celibrity 3 wheel electric scooter. The motor isn't working
the click is the electric brakes releasing , most likly the problem you are having is the brushes in the motor may be shot cheap easy fix on each side of the motor there should be what looks like a flat head screw those are the brush covers remove them and check them replace as need , otherwise the motor may be shot
Posted on Jul 11, 2010
Stops suddenly, immediately restarts
Look for a loose connection on the throttle pot. really sounds like a a connection that is loose. Scooter Doctor App
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Apr 09, 2016 | Pride Mobility Legend XL 4 Wheel Electric...
Why does my scooter stick in reverse when i push forward & stop when i push reverse
Hi, it could be that the throttle has turned around within the throttle lever therefore no longer centre, look under the throttle stem, you should see a cross head now that should be in align with you when sitting on the scooter...you will need to loosen the throttle and realign if that is the case...
Regards
Rob
www.gewizrepairs.co.uk
Apr 24, 2014 | Pride Mobility Products Pride Mobility...
I have a cosco 57-410 4 wheel electric scooter, seems that the electric brake is not functioning right. Scooter wont free will or run with power on. give an electric break code. Swtich on electric...
The brake is controlled by the position of the fwd/reverse throttle paddles.
There is a pot inside that the paddles attach to..if the pot is not
centred the brake doesn't work properly when the paddles are
released. I had the same problem on my Pride Legend XL..
had to order the throttle pot from MonsterScooter,com.
Installed it myself and that cleared my electric brake problem.
Apr 08, 2014 | Pride Mobility Products Go Go Ultra X 3...
My Pride scooter bought in '97 doesn't run
Hello, my name is Mike.
Here is a couple areas that would cause this:
A faulty throttle pot ( Wig Wag ). I have changed many throttle pots for this reason.
Also check battery and motor connectors. Sometimes even if the meter is not dropping poor batteries can cause surges which would cause this. Sometimes you get lucky where you take key out, and let set for a bit. Then put key in with out depressing throttle. But that is rare this works. Most times it going to be a battery issue, or a faulty throttle pot. Best to have service place replace this if your not really mechanically inclined in electronics. Thank You , MIke.
Sep 19, 2011 | Pride Celebrity Xl 4 Wheel Scooter
Hello my pride scooter beeps 6 times which in the manual it tells me i'm still plugged into the charger when it is disconnected,so it wont move,can you help
The Legend 4 wheel XL scooter has a S drive controller. This is an assumption based on the model described. I would have to run the serial number to be certain. With the S drive controller a beep code of 6 indicates a bad throttle potentiometer or a throttle potentiometer which is out of neutral on start up. You can test for this by turning off the scooter and attempting to try various neutral positions of the pot, and turning the scooter on with your other hand while maintaining this neutral position. This usually works by trial and error.
The more technical way is to remove the front console covers and inspect the pot mechanism visually checking the spring and movement and electronically using a digital volt meter.
If you do indeed have a code for the charger plugged in (and of course it is not), then you have a bad charger. These chargers are notorious for going into drive inhibit when they burn out and the computer will give a code of charger plugged in. To test for this, you need to remove the cover to get to the charger and unplug the charger on the output side. If the scooter runs you have a bad charger that is stuck in drive inhibit (electronically equivalent to the scooter being plugged into an AC wall outlet). Hope this helps.
Apr 23, 2011 | Pride Mobility Products Pride Legend XL -...
Could you please tell me where i will get forward& reverse throttle for pride victory
Throttle potentiometers are a frequent part that is replaced on scooters due to wear. This part is available from the manufacturer Pride or from a company called Monsterscooterparts.com.
At the Monsterscooterparts home page click on mobility scooter parts, pride scooters, pride parts click on Pride Victory XL SC270 , select throttle pot assembly. Verify SN and compatibility remarks. They have an 800 phone number for questions and they ship worldwide. The Pride part number is ELEASMB 1511 for Victory XL 4 wheel scooters after the year 2000. Looks like the price is about $80. Labor is about 1/2 hour and can be done by an experienced mechanic or do-it-yourself. The part is available from the manufacturer if you are a dealer or have an account.
First remove the throttle lever by loosening the allen set screws. Separate the front console covers by removing 8 or more screws holding it together. Locate the throttle pot, unplug it and install a new one. Be careful not to over-tighten or strip the screws holding the potentiometer housing tabs to the plastic. Check the alignment visually before reassembling it. Don't pinch any wiring when you put the console back together. When you reinstall the throttle lever make sure it is even left to right and does not bind on the plastic console housing. Tighten the lever set screws firmly but do not strip them, this repair will need to be done again and you want to be able to remove these set screws. Hope this helps.
Nov 07, 2010 | Pride New Mobility Victory XL 4 Wheel...
My scooter when I press the throttle to go forward it like breaks or stops. I have a Legend XL. It goes OK in reverse but, when you press to go forward it breaks like bad gas.
hi i hsave a pride legend classic mobility scooter it will run ok for a few yards then suddenly stop but if u wait for a bit it will go again whats the problem thanks
Mar 02, 2010 | Pride Legend XL Heavy-Duty 4 Wheel Scooter...
My pride go go elite scooter dies
it is either a bad throttle pot, or the set screw that holds the thumb forward/reverse paddle is loose causing the speed to slip, allen wrench to tighten if setscrew is problem
Apr 17, 2009 | Elite Pride Go Go Traveller 3 Wheel
Need to change mobility scooter controls back to right handed
Open up the front shroud (unhook batteries first) and switch the wires going to the throttle pod, its just 2 thin wires and if they were switched already you will probably be able to switch them back. The throttle pod is what the thumb throttle lever is hooked up to.
Feb 10, 2009 | Pride Mobility Products Celebrity X...
Health & Beauty Logo
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
